My Very Own Cryptex
45,333
144
37
In this instructable I'm showing the pictures of my own cryptex... I followed the steps from "How To Make a Cryptex" from this link: https://www.instructables.com/id/How-To-Make-a-Cryptex/ made by merijnvw.
I'm just posting this so that you can see that you can change any instructable to make it your own and use different tools (you can make almost anything even if all you had was a kitchen knife!!!
Supplies:
Step 1: Tools Used
Here are to tools I used, you can use you own imagination to make yours!
One thing missing... lots of sand paper!!!!
Step 2: Materials Needed
The materials used for this project are:
4 tubes that fit into each other... the two smallest ones metal the other too either way.
Lots of imagination...
Step 3: Puting It Together!
The pictures show the steps...
Step 4: Final Product
Here is how mine looks
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    37 Discussions
    antonia27
    8 years ago on Introduction
    i had a lot of difficulty with the step where you cement the smaller ring of pvc pipe into the larger one. the cement wouldn't go that even and it was gloppy and wouldn't stick to the pipes (even though it was supposed to be designed for pvc). i came up with an alternate way that is more effective/non-messy. very few things stick to pvc pipe, but duct tape does, so i lined the inside of the large ring and the outside of the smaller ring with duct tape then superglued a rubber band clamp ( a really thick rubber band that happens to fit perfectly between the two pipes) into the crevice. it came out perfectly and my cryptex is gorgeous and works very well. i hope this helps for anyone getting discouraged on that step
    myckroantonia27
    Thank you for your comment.... we want to see some pictures when you are done!
    Kaelessin
    Hey! I liked your idea so much that I ported it over to an all copper design. Had to do some tweaking to make it work properly but enjoyed what I feel great results!
    Here is mine.
    Thanks for this ible!
    myckroKaelessin
    WOW, looks awesome!!! keep up the good work!! post more pictures of the process if you have any... Thank you for sharing!
    antonia27
    9 years ago on Introduction
    What kind of filling did you use between your two largest pipes? I bought PVC pipes which are extremely hard to stick together and have them stay that way
    myckroantonia27
    I don't know what it is called but it's the one that you mix two together then it hardens after 10 minutes.... I hope this helps!
    myckrojohnnymendez
    that is the gap where the tithes slide when you are searching for the letter... hope you can make your own!!! good luck!
    johnnymendez
     are the black lines that go around painted on or are they tubing glued in place?
    This really looks amazing
    myckrojohnnymendez
    I painted the rings (made of tubing) black, then I glued the letters... I measured the perimeter then on word I used the ruler to make a table that long... then printed it out and it worked perfect...
    strontzakj
    Very nice! I like the black balls at the end of the cryptex very much! Were did you get them? I think I am going to make a cryptex like this tomorrow. But are the tithes really hard to make?
    myckrostrontzakj
    Hi there, thanx, You can get the balls at any hardware store, this are wood ones (actually used for curtains). Nothis is hard to make if you have the tools :-D I recommend buying a lot of filling since everything has to fit nice together. Good luck! and post some pics when you are done!!! (It took me 3 days to make and paint).
    myckrokeywii
    Thank you... well the pipes... I don't really know the sizes I just went around trying pipes that would fit into each other... two metal ones (small ones) and two plastic ones (bigger ones)... you can get them at home depot... or any hardware store! good luck!!
