Mycelial Forms
8,204
58
15
About: I am a designer, technologist, and educator exploring the imaginative use of emerging technologies. I am most curious about the intricate relationships between technology and our everyday human experience, a...
Mycelium is the vegetative part of a fungus, consisting of a branching thread-like collection of cells called hyphae. Mycelium has a complex network structure, that absorbs and distributes nutrients throughout it's environment. Mycelium is to a mushroom like an apple tree is to an apple. Another way to say this is that the mushroom is the flowering part of mycelium, it spreads spores and allows the organism to spread. This distinction is important, because in this tutorial we will be focused on growing sculptural mycellium forms rather than mushroom cultivation.
This guide explains my own process and experience growing sculptural mycelium forms. There are many approaches to cultivating this material but the process outlined here has been extraordinarily successful for me.
In my own experiments, I played around with incorporating different materials (and colors!) with the mycelium; I had mixed success with this. One approach that did work well was using natural dyes, waxes and resins to create additional structure and visual patterns. In the images above you can see a few of the results.
Step 1: Gather Supplies
  • Inoculated Grain Spawn (mycelium)
  • Coffee Chaff (substrate)
  • 5-gallon coffee pot or other large pot for pasteurizing substrate
  • Nut milk bag for pasteurizing substrate
  • 70% Isopropyl Alcohol for sterilization (alcohol wipes are also helpful)
  • Empty Spray Bottle
  • Plastic Sheet for surface protection
  • Molds to grow mycelium inside of
  • Xacto Knife or Drill for adding a hole in your molds
  • Oven for drying your final forms
For this experiment, the grain spawn was purchased from Aloha Medicinals. The spawn is 100% certified organic, grown on amended white sorghum grain. This particular spawn is Pleurotus ostreatus, also known as oyster mushroom.
*The bag with the larger grain in the photo above is from a different seller from Rochester NY, the following experiments all use the Aloha product, the bag on the bottom left in the photo.
I am using coffee chaff as the base material on which to grow the mycelium. Coffee Chaff is a lightweight and fluffy agricultural byproduct of roasting coffee. Coffee roasters produce a lot of this stuff when they roast coffee beans, and you can typically pick up chaff for free from your local roastery. Wood chips, straw, and other organic materials can be used as the base substrate. In fact, different strains of fungus prefer different substrates. You could do some research about these relationships if you choose something other than the strain I have used here.
Step 2: Prepare Molds
I used silicon ice cube molds and plastic trays for this experiment. You can buy fun molds from amazon or craft stores. Really any shape container will work, the trick is to be able to fully close or seal the mold. Any holes or gaps in the mold could let in contamination and present an opportunity for the mycellium to grow outside of the mold (we don't want this!).
Add a small breathing hold in your mold and fill it a balled up piece of Polyester Fiber Fill. Use a drill or xacto knife to create the breathing hole.
The final sculpture will take on the detail of the mold but it will shrink a bit when it dries - keep this in mind if you are interested in creating something with specific dimensions.
Step 3: Sterilize and Prepare Your Workspace
It is absolutely essential that your workspace remain clean throughout this process. The most common challenge you will encounter in growing mycelium is contamination - resulting in unwelcome mold in your experiment.
Create a sterilization mixture in your spray bottle with 70% isopropyl alcohol in distilled water. You don't need to completely fill the spray bottle, you won't use much of this.
Use plastic sheeting to cover your workspace - I like to tape the plastic so that it wraps under the edges of my table. Spray the plastic surface with your alcohol mixture and let it air dry.
STERILIZE EVERYTHING! Wipe everything with your alcohol mixture. Containers, mixing surfaces, molds, your hands, everything.
Do not let the grain spawn get sterilized by coming into contact with the alcohol. It will kill the mycelium and will not grow. The alcohol solution will evaporate quickly. Be patient.
Step 4: Sanitize Substrate
Before the chaff substrate can be combined with the grain spawn, it needs to be pasteurized (not sterilized).
You will need a large pot of hot water to do this, I had the most luck using a 5-gallon electric coffee pot since it allows me to maintain a consistent temperature. You could also use a large stock pot and a thermometer.
Bring the water to 170° F and maintain this temperature. Fill a mesh nut milk bag with coffee chaff and tie off the top. Add your bag of substrate to the the hot water and allow it to steep for 20 minutes. Carefully remove the bag from the hot water.
Lastly, you will have to press all of the water out of the substrate. We used a custom made wooden hand press to squeeze out the water, a converted cider press would also be a great option. Above all, you want to get as much water as possible out of the coffee chaff, and because it will be very hot you will want some kind of press to help with this.
Step 5: Combine Substrate & Grain Spawn
After pressing the water from the pasteurized chaff, the subtrate will be very compacted and will need to be separated by hand into small fluffy(ish) chunks before being mixed with the spawn. CAREFUL: It should be no surprise that 170F water is HOT.
Once the chaff has been broken up and cooled down, combine 4 parts chaff : 1 part grain spawn mixture. Be very very careful not to contaminate the bag of grain spawn - I like to use a sterilized spoon to scoop from the spawn bag. Dump the grain spawn directly onto the chaff and combine with your hands.
Step 6: Fill and Seal Molds
Fill your sterilized molds with the substrate grain spawn mixture. You want to thoroughly fill the mold but do not pack the mixture in too tightly - it needs some space to breathe and grow. Over time, the space between the material will be filled in by mycelium.
Be sure your breathing hole is filled with poly-fill and that all other gaps are sealed. Mycelium likes air but also likes humidity so don't let it get to dry. Use duct tape to close the mold.
Step 7: Let It Grow
Store your project in a cool, dark and ideally somewhat humid environment.
You will typically see growth within 4-6 days, and your mold will be finished when it looks completely white, which typically takes around 2 weeks.
Watch out for mold or any growth that looks unusual. Mycelium is white and dense looking, any other colored growth, or spotty growth is likely contamination. Mold can be dangerous, and is difficult to get rid of once it starts, if this happens to you it is usually a sign that you should start over and be exceptionally careful about contamination.
Step 8: Bake & Finish
After ~14-16 days, remove the mycelium forms from your mold and allow them to air dry for a few days. You will notice that the forms are moist and delicate, they will harden up as they dry.
Remember that even when your forms dry out, they are still a living material. It is a best practice to bake your forms in the oven for 20-30 minutes at a low temperature (200-220°F).
Step 9: Share Your Thoughts!
I first learned about mycelium through an interest in Permaculture and Micoremediation, and I unexpectedly discovered a beautiful, sculptural material. There are many inspiring examples of existing mycelium works, and an enormous opportunity for future projects - please share your work and ideas, I would love to hear!
I have also posted a Tumblr site with many helpful mycelium resources, books, publications, projects and more! Check it out at mycelial-space.tumblr.com. A very special thanks to Marina Zurkow and ITP/NYU for supporting my initial inquiry into this material exploration.
Happy making!
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    15 Discussions
    mrwonton
    Question 1 year ago
    Does it burn well? Could it be a sort of fire starter? (No Stephan king pun intended)
    mrwonton
    1 year ago
    MINECRAFT: that is what mushrooms grow on!
    zanod
    Question 1 year ago
    I saw a TV programme a while back that showed mycelium being used as an ecological replacement for polystyrene in packaging, and I wondered about its application for model aircraft. Can you say anything about its strength to weight ratio? How does its tensile and compression strength compare with polystyrene?
    You said something rather concerning in the instructions - "Mold can be dangerous, and is difficult to get rid of once it starts". Could you expand on that? I know dry rot is a real problem in houses, and if anybody unwittingly introduced something like that, he might regret ever experimenting with it. Then you say "if this happens to you it is usually a sign that you should start over" I would have thought it might be more appropriate to say "if this happens to you it is usually a sign that you should get your house on the market as quickly as possible",
    1 answer
    MarioB137zanod
    Answer 1 year ago
    Not the OP of that instructable, but I can answer your questions to some extent. First, dried mycelium is comparable to soft paper in terms of weight and tensile strength. To your other question I can assure you that dry rot is a completely different species than anything you grow on wet chaff or coffee grounds. If you get dry rot in the house, it probably got introduced by airflow or as stowaway on the feet of mice. Either way there needs to be phases of high humidity for it to grow and damage wood beams. Faulty insulation is mostly the prime reason there.
    Gadisha
    1 year ago
    The possibilities of mycelium as a material for a.o. housebuilding, fabrics, furniture etc. seem to be endless (just type in 'mycelium material' on youtube and you'll see what I mean), not to speak of it's medicinal properties, the way it helps clean up our surroundings and it's potential as an energy source.
    I am very interested in what mycelium can bring us in the future, so I love to read about experiments like yours, also I am very glad that you point out that this is a living material, I think that's something that we have to keep in the back of our heads at all times when we take our advantage in the properties of living things, we should not exploit them as man has been doing for so long to the environment but be sure that there is a mutual advantage for us and the organism...
    It would be cool to live in a house made of mycelium that is living and growing around us and which we nurture while it shelters us for instance :) but ofcourse this is still just a fantasy...
    P.s. the Star Trek fans among us are probably already aware of this ;), but google 'Paul Stamets', his ideas about mycelium are very interesting!
    arielleheinGadisha
    Reply 1 year ago
    Paul Stamets is a genius mycologist! I learned a lot from his books and publications. I love the house idea :)
    jessyratfink
    1 year ago
    This is amazing to look at - they're beautiful!
    arielleheingrapenut
    Reply 1 year ago
    Correct, this is most definitely not for eating!! It is a sculptural design project.
    peinkc
    1 year ago
    "absolutely essential that your workspace remain clean throughout this process". That's a deal breaker for me.
    I just wanted to say that your level of detail in the instructions was quite impressive.
    Good job.
    towellm
    1 year ago
    Google "mycelium growth patterns"....Nature is a great teacher.
    These have an interesting look but up close you begin to realize here's a lot more going on. The methods of propagation found in various bio structures has much to reveal. EX: A bee honeycomb has an interesting appearance that's crucial to it's function. How it is generated wasn't understood until fairly recently and is a wonder in itself.
    thesnowtheriver
    1 year ago
    This material is very beautiful. I was not aware of it before. What could it be used for? sculpture? a very comprehensive instructable. thank you.
    ok disregard above question. i googled it and the resulting sculptures are just gorgeous. so many possibilities!
    Penolopy Bulnick
    1 year ago
    Looks like a very interesting and thorogh experiment! Thanks for sharing what you did :)
