Nail Polish Flowers
About: I like to try anything once and dabble in a bit of everything.
In search of a craft that could use my excess of nail polish, I have come across these cute flowers. These flowers can be used to decorate items you already own, or can create new items.
Step 1: Supplies Needed
What you need is:
Floral wire (and wire cutters)
A pencil or a similar tool to shape the wire
Nail Polish (it really doesn't matter what kind)
Foam or Clay so your flowers can safely dry
A ventilated area - nail polish stinks
Step 2: Cut Your Wire
Cut a length of wire approximately 15 cm long. Try to keep the wire straight without too many kinks.
Step 3: Forming Petals
With the aid of a pencil or some other tool, form 5 petals. Wrap the wire around the centre after forming each petal. Make sure you leave a tail of wire so you can stick the end in a piece of foam or clay to dry.
Step 4: Nail Polish Filler
Starting with the inner edge of one petal, paint on some polish. Add a bit more polish and "paint in" the centre. Essentially it will create a film just like what you see with a bubble wand. Fill in each section with polish.
Some nail polish is thinner that others. I find that a semi-transparent (a thin polish) doesn't work so well unless you start off with a more thicker polish.
Step 5: Set Aside
Once you have the petals filled in, stick the flower in clay or foam to allow it to dry. You can add a centre to the flower in another colour if you wish. You could also add a second layer if you want, but it's usually fine with one coat. If you wanted to add a clear glitter layer, you could do that too. Let it sit a while to dry.
Step 6: Finishing Up
After leaving them to dry (I usually wait until the next day... just to be sure), cut the stem part off.
Don't they look cute? If you have no idea what to do with these, the next few steps will hopefully give you some inspiration.
Step 7: Ornaments
Grab some glue (I am using E6000) and glue the flowers on. I also added some leaves with a permanent marker.
Or go nuts and glue them everywhere.
Step 8: Hair Clip
Using some ribbon, a hair clip, and craft glue, you can make some cute hair accessories.
Step 9: Using the Process in Other Wire Wraps
Why not use this process with other wire wrapped projects? These "Tree of Life" pendents have sections coloured in with nail polish.
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    2 Discussions
    NoBoxEver
    8 months ago on Step 9
    Can you use a lighter weight wire, or does it have to be floral wire? How about shaping wire into stars? or hearts? or circles?
    Violet-PersonNoBoxEver
    Reply 8 months ago
    For those pendants I used a lighter weight. A heavier guage was on the outside.
