Nerf Maverick Video Modification Guide
35,868
180
37
About: A tech and gadget enthusiast who enjoys building and creating DIY projects. Check out my projects and tutorials on Instructables and x2Jiggy.com!
A series of videos showing how to modify your Nerf Maverick blaster in various ways including assembly, disassembly, laser sight, penny mod, russian roulette mod, slip clutch / reliability mod and air restrictor removal. The Maverick happens to be a cheap and easily modifiable Nerf gun that's perfect for inexperienced modders. Hopefully these videos can assist you in your Maverick modification adventures.
Please consider subscribing to my YouTube channel or liking my videos.
Step 1: Disassembly
Runs you through the processing of pulling the Maverick apart in preparation for some modding. Just make sure you keep an eye on all the parts as some are easy to lose.
Step 2: Assembly
If you're going to pull the Maverick apart, you better know how to put it back together. There's a couple of things to look out for but it's an easy process. This is where having all the parts comes in handy.
Step 3: Laser Sight Mod
This tutorial shows how to install a laser sight using a laser pointer, AAA batteries with holder, wire and a switch. This is the most difficult of the mods however the result is pretty entertaining. If you're comfortable with soldering and a drill you can add a little more ease to your aiming.
Step 4: Penny Mod
The penny mod involves adding a few coins behind the spring to increase your firepower. Although it's called the penny mod, a variety of coins will work. I've used Australian 5c pieces in this one.
Step 5: Russian Roulette Mod
This mod allows the cylinder of the Maverick to release further from the gun so you can load it easier and spin the cylinder 'russian roulette' style. Basically involves cutting and sanding a few tabs preventing the release of the cylinder.
Step 6: Air Restrictor Removal
Air restrictors are installed in the Maverick to limit the range. This guide shows how to disassemble the cylinder and remove these restrictors.
Step 7: Slip Clutch / Reliability Mod
There's a clutch in the rotation assembly that will slip when too much resistance is met. This protects the internal parts and makes the Maverick more durable however it also causes the occasional misfire. Gluing this clutch will prevent misfires from occuring but you can't manually rotate the cylinder while it's not released or you risk breaking the join. If this occurs the blaster will return to normal operation and may misfire again. You would need to repeat the tutorial.
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    37 Discussions
    pyromaniac123456789
    5 years ago
    Does the AR removal mod actual help? I am modding my brothers maverick and if I break it i have to buy him a new one.
    Inventor Xtyler303047
    Think of the word "restrictor". It sounds a lot like "restriction", doesn't it?
    So the purpose of one's "Air restrictor" is to control the amount of air that pushes the bullet out of the chamber. By removing such a device, it unblocks the small amount of air that is usable to fire the bullet forward. This makes the bullet travel, consequently, a lot further than normal.
    I did the AR mod and penny mod, didn't chop the orange sticks off but my maverick isn't shooting any further.PLZ HELP somebody! VRY VRY thanx in advance. also my darts dont fly strait after travelling 5-6 feet they tend to go down and dont hit the target! I just wanna know if this same prob is happenin 2 everybody??????
    dragondane
    My Maverick is now broken, any suggestions on why it might be broken? When pulling back the slide it automatically fires, with no bullets being shot? I don't even need to pull the trigger. Please suggest some helpful tips how to fix it. And the spring underneath the plunger, connecting to the little sticking out piece may be the problem. I only tried the penny mod and the AR removal.
    Thanks in advance.
    x2Jiggydragondane
    If you're pulling the slide and the gun fires without pressing the trigger, the plunger is not being secured when you pull the slide back. I've attached an image that highlights the plunger catch/release mechanism. When you pull back the slide, the orange plastic ring should catch on the plunger and secure it in place. When you press the trigger, the ring moves and the plunger is released, firing the maverick.
    Open your maverick and check that these parts are assembled as shown in the image. The assembly video also shows the correct way to install the plunger release. Also ensure the plunger is slotted firmly against the cylinder as shown at 2:05 of the assembly video. Hopefully this helps you out. Happy modding.
    dragondanex2Jiggy
    Thanks a heap!! All good. Proves 12 year olds, (with some help), can mod a nerf gun. Turns out the spring underneath the orangey thing was connected to the ridge, not just pushing against it, (Hard to understand, sorry)
    But thank you!!!
    DaDerp
    6 years ago on Step 7
    I have done the penny mod, the Russian roulette mod, and the air restrictor removal. They helped my maverick a lot! shooting people in the forehead is much easier!
    Thekellygang
    6 years ago on Introduction
    i used the penny mod with 4 5c coins and now my maverick works amazingly. Thankyou!
    pwooten
    6 years ago on Step 6
    you really should sand down the posts
    dragondane
    Hey again,
    I've done heaps of Nerf Modding now but i'm kinda stumped on something.
    My Maverick is a model from 2009, (Don't know if that has anything to do with it) but anyway when I try to quickly load it, say pull the slide back and let go, it just kinda jams, skips a barrel on the turret. So when in a war I don't want to spend time slowly cocking the gun while being shot at. I've checked the catch spring, the slide spring and the plunger spring and it's still not loading well.
    Thanks for your answers.
    nimrod316dragondane
    Reply 6 years ago on Introduction
    thats the back side of the barrel mod. learn the technique, then u can actually put it back in place with a cool move with the hand that holds the gun. works well when u get the hang of it. then again, when it jams during a war, u are buggered. ^^
    nimrod316
    one of the best instructables i have seen. thank you very much.
    that said, i would advise everyone to not to apply the air restrictor mod.
    for two mavericks i applied the russian roulette, penny (cr2032 battery works perfectly) and clutch mod. the last one does make a huge difference and is definetly a must. the penny mod is nice too, go for it. to have the barrel come out more makes u reload quicker, but putting it back again is tricky sometimes. it is optional really.
    now, for one of the guns i removed all air restrictors. them arrows won't fly as far and straight as before. actually i would even go that far saying, it gives you a disadvantage. keep the restrictors i say.
    GASSYPOOTS
    uhh my pull back thick is made in reverse of yours so how do i put it back on???
    Farrelbark
    okay, just found out the pin caps on the cylinders were put in backwards....
    Problem solved.
    Farrelbark
    I just did the Air Restrictor Mod, the Penny Mod, and the Russian Roulette Mod.
    The first two work wonders, and the last one comes out correctly, but it's very wobbly when it's popped out and it sticks on something when popping back.
    the poodleo
    AWESOME!!! these mods worked great. I used the one to make the barrel go out further, the penny mod, and i removed the air restritors. i also painted it- gold, and im doing some brush work with black and silver right now. this was a great instructable, i would love to see mods for the nerf barricade. ill post pics when i finish my gun too.
