Nerf Modulus Modification Guide for Beginners
7,517
13
About: Welcome to the F.A.N.G., the world's largest and most advanced tactical Nerf team, and the founder of the GFDC. We are The Bite Force, and we're here to have fun! This account will share all of the F.A.N.G. ...
The Nerf Modulus was released in 2014 as a beginning to the Modulus customizable blaster line. While it is a interesting blaster, it has a number of flaws common to electronic Nerf blasters, including inability to dry-fire and an inability to fire without the jam door completely closed.
These problems can be fixed with a number of simple modifications*, which we (a Nerf war team) will show you in this guide. These mods include:
  • Blaster disassembly.
  • Trigger lock removal.
  • Magazine switch disabling.
  • Jam door switch disabling.
  • Blaster reassembly.
  • A few extra tips and tricks.
This project is for beginners, and while it involves an electronic Nerf blaster, there are no electrical skills, tools, or knowledge necessary to complete this project. We have found workarounds for you. When you learn more about electrical work, feel free to go back into your blaster and do things such as complete rewires, motor replacements, resistor and thermistor removal, and more.
Interested in seeing what we have to say? Click the "next" button to begin!
*Please note that our Nerf team does not accept any responsibility for any broken blasters or injury associated with modifying this blaster. Modify at your own risk.
Supplies:
Step 1: Tools and Materials
To modify your Nerf Modulus, you will need:
  • A hot glue dispenser.
  • Hot glue.
  • Scissors.
  • A small Philips-head screwdriver.
  • A small piece of cardboard.
  • The blaster itself.
Step 2: Opening the Blaster
In order to get to the mechanical parts of the blaster, we will first need to open up ("butterfly") both halves of the shell. Here's how:
  1. Remove any stock, tactical rail, and barrel attachments from the core blaster.
  2. Flip the blaster over so that its left side (the side with all screws) is facing upwards, as in picture one.
  3. Remove the screw in the battery compartment cover, as in picture one. Remove the piece by pulling it downwards at an angle off of the blaster. Remove any batteries.
  4. Remove the two screws in the stock attachment point and pull it backwards off of the blaster, as in picture two.
  5. Remove all other screws in the blaster shell as in picture three.
  6. Carefully pry both halves of the blaster apart as in picture four.
Step 3: Memorizing the Internal Layout
Before beginning any modifications, it is critically important to familiarize yourself with the internal mechanism of the blaster. Three reference photos have been provided.
Step 4: Exposing Locks and Switches
In order to customize the performance of the blaster, we will need to get to, remove, and/or disable a number of locks and switches. Here is how to get to them:
  1. Locate the large plastic plate underneath the trigger arm, undo the two screws holding it in place, and pull it out of position, as in pictures one and two. The trigger lock and magazine switch will now be exposed.
  2. Locate the small plastic cover near the top of the blaster, remove its screw, and pull it out of position, as in pictures three and four. The jam door switch will now be exposed.
Step 5: Removing the Trigger Lock
The trigger lock does not allow the trigger to be pulled on the blaster unless a magazine is inserted completely. To remove it:
  1. Locate the trigger lock, and remove the larger piece as shown in pictures one and two.
  2. Pull both the acceleration trigger and the main trigger to expose the remaining portion of the trigger lock, as in pictures three and four.
  3. Remove the final piece, as in pictures five and six.
Step 6: Disabling the Magazine Switch
The magazine switch does not allow any electricity to flow through the blaster unless a magazine is inserted. To disable it:
  1. Cut a small (approximately 1cm X 0.5cm) rectangle of cardboard, as in picture one.
  2. Add a dot of hot glue to one side, as in picture two.
  3. Glue it over the magazine switch, making sure the switch is completely depressed, as in picture three.
Step 7: Disabling the Jam Door Switch
The jam door switch does not allow any electricity to flow through the blaster unless the jam door is completely closed. To disable it:
  1. Temporarily remove the jam door, as in picture two.
  2. Carefully pry out the jam door switch, as in picture three.
  3. Cut another small (approximately 0.25cm X 0.5cm) rectangle of cardboard, as in picture four.
  4. Glue the rectangle of cardboard into the bottom of the box housing the jam door switch, as in picture five.
  5. Replace the jam door switch, as in picture six.
  6. Replace the jam door, as in picture seven.
Step 8: Blaster Reassembly
At this point, all internal modifications to the blaster are complete. To reassemble your blaster:
  1. Check to make sure you have done all modifications correctly and removed the correct pieces, as in pictures one and two.
  2. Put both halves of the blaster back together, and tighten all screws, as in picture three.
  3. Replace the stock attachment point, and tighten its screws, as in picture four.
  4. Add batteries, as in picture five.
  5. Replace the battery compartment cover and tighten its screw, as in picture six.
Step 9: Project Complete!
If you have made it this far, congratulations! You have successfully modified your Nerf Modulus! You will now be able to enjoy being able pull the trigger and rev the blaster whenever you wish!
We hope your modified blaster gives you many years of pleasure, and we wish you the best in the future of your Nerf modding hobby!
Want more Nerf stuff from us? Find us on Facebook, Twitter, Instagram, and Instructables!
-The Innovation Department atF.A.N.G. Nerf Club
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    2 Discussions
    tinyhooman
    2 years ago
    bruh you can just remove the mag lock
    EricM244
    2 years ago
    great guide! It is all perfect except for the mag lock. For me cardboard and hot glue wouldn't work, but leaving everything in but the spike thingy, and then taping the large plastic plate against the sensor worked. Good guide, and it got me into modding.
