Nest Thermostat With Gas Fireplace (or Other Millivolt System)
18,299
19
69
About: I would rather learn how to do it myself rather than pay someone else to do it for me.
This short tutorial will help you use your Nest thermostat with your gas fireplace or other millivolt type system. I found some other tutorials online but none really seemed to cover everything you'll need so here you go!
Supplies:
Step 1: Purchase a 24v AC Adapter
Your gas fireplace or other millivolt system does not operate using 24v AC like most HVAC systems. You have to supply the 24v using an external transformer. I got mine at Lowes for $7.99 (item number 168261).
Step 2: Purchase a Fan Relay
You will need a fan relay. I got mine at Grainger for $9.05 (item number 1N184). The Nest is going to switch the 24v source and this relay is going to switch the millivolt system in your gas fireplace.
Step 3: Install the Nest and Connect the Wiring
First, disconnect the thermostat wires from the gas fireplace -- you will use your existing thermostat wiring -- and it's always a good idea to disconnect things when working with electricity. Install the AC adapter -- I placed mine behind the wall in the laundry room (very convenient there was an outlet right there for me) and ran the wiring up the wall and through the same hole as the thermostat wire.
Connect one lead from the AC adapter to the RH terminal on the Nest backplate (you will probably have to tin the end of the wire so the Nest can sense there is a wire connected), splice the other lead from the AC adapter to the existing RED thermostat wire and finally the WHITE thermostat wire to the W1 terminal on the Nest backplate.
Step 4: Connect the Relay
Install the relay in or near the gas fireplace. You may need to have some female spade terminals handy for this step if you don't already have them. Put those on all the wires -- two wires from the Nest and the two wires in the fireplace -- first if needed.
Connect your existing thermostat wires from the Nest to terminals 1 and 3 on the relay. Connect the thermostat leads from the fireplace to terminals 2 and 4 on the relay.
Step 5: Plug in the AC Adapter and Connect the Nest
Plug in the AC adapter. Connect the Nest thermostat to the backplate.
If all is well, you should now have a fully functional Nest thermostat to operate your gas fireplace. It took a while to fully charge the battery in the Nest so that I could configure the WiFi network settings and access the thermostat from the app.
3 People Made This Project!
  • Classroom Science Contest
  • IoT Challenge
    IoT Challenge
  • Party Challenge
    Party Challenge
69 Discussions
wkrueger
Question 2 months ago on Introduction
I followed the steps and it works! The only weird thing is how much noise the relay makes... I can hear it all over my house. Any recommendations?
1 answer
bobby_mcgrath
2 months ago
i'm going to try this with a pellet stove....stay tuned. If anyone knows this to be a horror story waiting to happen, please chime in.
msenn77bobby_mcgrath
Reply 2 months ago
This set of instructions should work with any heat producing device as long as the relay is used to isolate the 24v circuit to the Nest from the circuit in the heating appliance including 120v or 240v. The 24VAC adapter powers/charges the Nest and the Nest is a temperature switch which activates the switch in the relay to open or close the secondary circuit. With some minor modifications, you could use this with a space heater, a Dyson fan, a kerosene forced air heater, etc. Enjoy!
goo2
Question 4 months ago
I set this up but recently had a power outage and the nest thermostat stopped working showing the wiring diagram and a link to tech info. Should this setup still work off the nest battery?
msenn77goo2
Reply 4 months ago
When AC power is lost the Nest will show an error code. That is normal and would happen whether the device is powered by your HVAC system or using this power adapter "hack". This "hack" is basically invisible to the Nest and the battery that powers the Nest for a brief period of time during an outage is no different than the battery in any other device you have in that it has a limited amount of storage capacity and a limited life span. I would check the appropriate error code here: https://nest.com/support/article/What-do-Nest-s-error-codes-mean. Unfortunately, you probably won't get any tech support from Nest if needed because i'm almost 100% sure they won't officially support this "hack".
goo2msenn77
Reply 3 months ago
Just to make sure I understand. Should the nest actually run the fireplace during an outage while the battery still has life? From what I can tell that is not the case.. but maybe I’m doing something wrong? Also during an outage does it not get any power from the thermopile?
msenn77goo2
Reply 3 months ago
That does appear to be one drawback of the Nest in that it requires a very full battery to function normally. For example, it dosen't take much of a drop in voltage to lost its ability to connect to wifi. So no, it won't control the fireplace after a power outage regardless of an outage caused by supply to your home of the adapter comes loose and falls out of the wall. Of course, in the even of a full power outage the fireplace isn't going to work either so it wouldn't be an issue with the Nest at that point.
msenn77goo2
Reply 3 months ago
Nothing. But, as I state in my instructions I wasn't able to find a complete tutorial that included a full list of parts, a description of them and the purpose they serve in the system and details about how to connect them.
goo2
Question 3 months ago
For some reason my battery stopped charging and it won’t connect to WiFi out of the blue anyone else had this issue?
msenn77goo2
Reply 3 months ago
The only thing that I can think is that you may need to tin the ends of the wires from the AC adapter. I had the issue when I first put it together because they were not making good contact in the base of the Nest as they were too small a gauge.
goo2msenn77
Reply 3 months ago
FYI I realized that the transformer plug was in a power outlet that was loose and I must have knocked it loose.. so it stopped charging. I used a different outlet where I won’t knock it and it’s been fine since
Bingobob44
3 months ago on Introduction
This is amazing, thanks for sharing! Will this work with the app on phone?
I have two gas fireplaces with remote thermostats and would love to be able to control both individually from phones.
msenn77Bingobob44
Reply 3 months ago
This installation "hack" should have no impact on whether you are able to access the device from the app on your phone.
Krzy56
4 months ago
Recently I purchased two Nests of 3th generation and while connecting it and setting up in my primary home in Mississauga, Ontario, Canada, installing it in my recreation house at the Georgian Bay (some 120km of north), was a bit of challenge. To heat up my cottage I have there an old style natural gas burning stove with logs. Our fully winterized cottage serves during skiing season, but going there was always asociated with way too long time to warm it up. So Nest appeared a perfect solution. But the stove does not use any external power to turn on the burner. But Nest needs some power to operate. That was easy. 24 Volt AC adapter (in fact, transformer of few wats, i.e. 15Watts) was waiting few years in my garage. Stripped wires and connected them to the proper terminals of the Nest's base. One wire to Rc and other to C. Since this is AC (Alternative Current) it doesn't matter which wire where.
Bigger problem was with only two wires coming from my stove. Voltage measured accross them was 0,570V DC (or 570 milivolts). Little exploration of internet has shown that problem can be solved with needs to use additional relay. I was wondering. Really? Lets take a little look into the Nest.
I was studying manual of Nest to find solution. One of the advise was that Nest isn't suitable for milivolts operating devices.
I did installation of the Nest simulating real conditions. Nest has started as expected. Now I could simulate installation of Nest working with different devices, which allowed me to check results of turning on and off in variety of configuration.
Important conclusion comes after. Nest does not have any relay inside which would be turning on/off gas in the stove, as the old thermostat did.
If this is not relay that means it must be a transistor. Hence, you don't need ANY additional relay. Again - ANY. That 570 of milivolt DC comes from thermocouple inside the stove. That is further used to turn on gas inside of stove, but first must be turned on by our thermostat. Our Nest.
Only what you need is to place proper wire to proper terminal. In my case I used W1 and Rh. How to check which wire goes where? Since we are dealing with milivolts of DC (Direct Current) and transistor inside of Nest as the electronic switch, POLARITY is playing here the fundamental role. So, if at random placed wires is not resulted with turning on your stove, simply flip them and you shall have positive result.
One I must say. THIS IS SOLUTION FOR MILLIVOLTS OPERATING DEVICES ONLY. And this is absolutely safe for both, your Nest and stove. And is absolutely compatible, but 24Volt AC transformer/adapter must be the source of power for Nest only. Make sure during installation do not connect AC wires with any of those milivolts carrying wires.
I am writing my post in the cottage which was waiting warm as never before the Nest era. (dated Jan. 19. 2019) Cheers!
walterw66
Question 5 months ago on Step 2
I have a thermostat hooked up to my gas fireplace
next to the thermostat is an on/off type light switch that controls the power to the fan separately
If I turn the fan switch on , the fan will not start working until the fireplace has heated for a few minutes. It will turn off if the fireplace cools off.
considering that the fan is thermally controlled and that there is a separate power toggle for the fan; how do you think i should connect power to the Nest E third generation?
thanks
1 answer
msenn77walterw66
Reply 5 months ago
considering only the information that you've provided first i would probably just recommend that you remove the light switch that controls the fan. i cannot conceive of a situation where you would want to use that as i imagine that it could seriously damage the fireplace if the unit was run without the fan due to overheating and ultimately could result in fire and injury or loss of life. secondly, i don't think this setup would make any difference in how the Nest (or standard thermostat) would be connect or function with your fireplace as the switch is not interrupting anything that controls the flow of gas, ignition, etc.
redheelerdog
Anyone know if there is a solid state replacement option for the White Rodgers 90-370 184-916 relay? Where I have mine installed the relay switch is rather loud? Thanks
