New Arc Reactor (studio Replica)
117,790
1,001
40
My attempt at a more authentic replica of the iron man arc reactor.
Step 1:
started with copper, but it became too flimsy...  so i tried a thicker piece of aluminum instead
Step 2: Starting to Wind the Coils
Step 3: Inner Ring
just punched a piece of aluminum with a punch press, then drilled and filled all the oval holes by hand, then made all the other little parts by hand
Step 4: More Parts
made the copper brackets using an etching machine.
Then got a scrap pcb, cut it into a circle and hot glued some components onto it.
Step 5: Intial Assembly
I used some magnet wire to hold it all together at first before i glued it all up.
Step 6: Time for Lights
Chose to go with White LEDs this time.
Step 7: Now It Just Needs a Display Box
oh, I still have to do the wires connecting the coils. .  . .
Step 8: Parts and Cost Estimate
--The only part that was manufactured by an actual program and machine were these two bracket pieces.  The cost to make these outside for the average builder could be difficult to price. I was fortunate to know some one who could do it for me. I drew out a rough sketch and just kinda eyeballed the two.  I did use card stock paper to make templates first, to see how to size everything.
--The rest of the parts were just found in scrap piles i have laying around from other projects, and circuit boards that i scrounge parts from.
--The acrylic i used can be purchased or ordered online at any plastics/acrylics site.   Because of the size of the pieces, they shouldn't cost too much.  I got mine from home depot. I made my acrylic ring by first cutting a circle out, then drilled lots of holes on the inside, and then just sanded and polished till it was to my liking.
--total cost i would guess under $100, depending on how much you scrounge and can find.
--Also above is a pic of the Led circuit that i built, using a 9volt battery as my power source.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    40 Discussions
    TharrunK
    Question 8 months ago on Step 1
    What thing you are using before winding aluminum
    PaulW322
    Question 1 year ago on Step 4
    I dont have a machine to cut oit metal like that, Ithink I will 3d print them and paint them copper. Do you have STL files for these braces?
    ShockSketch
    3 years ago
    Hi what is that clear ring in step one made of? Acrylic?
    AshleyH3
    3 years ago on Introduction
    What are the materials used for the arc reactor and the costs of it?
    You need or someone needs to explain more what it actually is. I'm presuming a mock up of a prop from the movie IRON MAN called an 'Arc Reactor' (whatever that is) that lights up with LEDs. Am correct? - What was/is it's supposed function in the movie?
    Or am I way off the mark - hence why I ask!!
    -B!LL!
    andytangtskFugitive_Bill
    Reply 3 years ago
    The arc reactor in the iron man movie runs on palladium(later vibranium) and can generate clean electricity to power his iron man suit. The tech doesn't yet exist in reality but many people still try to make a replica of the prop since it looks really cool
    This is awesome. If you have blueprints that you could send me that would be awesome.
    sarthak123456789
    4 years ago
    it is only mentioned how to make it and not thqt how it work
    abdulrahman1019
    5 years ago
    it's amazing .. can I have the blue prints please
    ponylane
    5 years ago
    Im from argentina and i think i can find all the things i need to build one. But Could you send me the blue prints? Thanks
    GoodLifeBoyz
    5 years ago on Step 8
    Hey! Could you send me this blueprints, please?
    Thanks you.
    Iggybigee
    5 years ago on Introduction
    Where did you get the acrylic rings and what kind of copper product did you use for the brackets and how can I cut them without the etching machine?
    LITTLEski
    5 years ago
    Wow this is awesome!
