New DIY Idea to Run Universal Motor POWER TOOLS Without Electricity
4,016
28
8
About: Its all about life hacks, tools, scientific & creativity instructables ~ electron7m
Hey Guys!!!!
In this instructable you will learn how to make emergency electricity option to run you universal motor power tools
when there is no electricity at home.This set-up is mind blowing for operating power tools in remote areas or even on the way.
Even though many of us already have battery operated Power Tools but they are not that strong and fast when compared to recorded high power tools.
In this system a volt 12 volts UPS battery will power up the high voltage Power Tools DIY.
Full Video : https://www.youtube.com/watch?v=1In-QROElHk
Credits : Mr. Electron
Step 1: Connecting the Capacitors:
Get 3 electrolytic capacitors rated at 250 volts and 10000 microfarad each.Connect them in parallel.
You can also connect the car jump start cables to the tapping point of these capacitors.Stick the capacitors together in one place to some wooden base like I did as you can see in the picture.Take a bridge rectifier and connect the DC output of the rectifier to the respective positive and negative of the capacitor Bank.Attach the rectifier to the wooden board as well.
Now take a bulb holder and place it on the wooden board.You will also need a two pin plug that is to be attached to the inverter box as you can see in the picture.
So 1 wire from the two pin plug will be connected to one of the AC input terminal of the rectifier and the other wire will be connected to one of the wires of the bulb holder.The other wire of the bulb holder will be connected to the other AC i/p terminal of the rectifier.
Step 2: Completing the Circuit:
Now what you are going to need is a 100 Watt 12 volts to 220 volts inverter. Connect the two pin plug to the output circuit of the inverter and connect a 100 watt bulb to the bulb holder.
Take a multimeter and connect the positive terminal of the metre to the positive terminal of the capacitor Bank and the negative to the negative terminal of the capacitor Bank.Move the pointer to 1000 volts DC and place it somewhere where you can see it.
Now all you should be left with just 4 terminals 2 of which are the jumper cables connected to the capacitors while the other two are the input terminals of the inverter.
Step 3: Connecting Drill Machine & Battery :
Now the jumper car cables come with pre-attached crocodile clips.Take a drill machine and connect it's plug to the clips of the jumper cables.Place a cardboard in between the two clips to make sure that they are separate.
Make sure that you are drill machine is turned off.
Now take your 12 volt 7 Ah UPS battery and connect the positive input terminal of the inverter to the positive red terminal of the battery and the negative input terminal which will be the black one to the black terminal of the battery.
Your 100 watt bulb should be glowing brightly.The multimeter display will keep on indicating the voltage value to which the capacitors have been charged that is a bulb luminescence will keep on decreasing with the increase in voltage displayed on your multimeter display until it becomes zero.Keep charging the capacitors at least up to 200 volts.
Step 4: Testing:
After the multi-meter indicates 200V or 200+ volts, pick up your drill machine and press the ON switch and it should start performing as if it is connected to your home socket.
Take a metal piece and try drilling a hole through it.You should be able to go through it easily.
Perform the same test with your angle grinder and it should perform great.
So guys, that's all for today's instructable.
Thankyou!!!!
    • Trash to Treasure
      Trash to Treasure
    • Pie Contest
      Pie Contest
    • Pocket Sized Contest
    8 Discussions
    rafununu
    1 year ago
    The rectifier and caps aren't needed with any device that normally works on mains.
    TypeNameHererafununu
    Reply 1 year ago
    electric motors require alot of amps when they first start up.... if the inveter couldn't output enough he may have put the caps there to get it going initialy.
    Without that though this project would have just been "plug tool into plug into premade device to convert dc to ac"
    FlyboyronTypeNameHere
    Reply 1 year ago
    Exactly. But in either case, it certainly isn't "without electricity" as the title says.
    CuspissN
    1 year ago
    This is ridiculous. Just Click Bait.
    Flyboyron
    1 year ago
    I don't know about everyone else, but I think I see electricity there.
    Did I read the title wrong?
    I assume you mean "without wall outlet power" or "without mains power", but if you touch those two battery clips together, you're definitely going to learn that this is hardly "without electricity".
    rebeltaz
    1 year ago
    Why would you need the capacitor or rectifiers? The inverter is DESIGNED to run power tools off of 12v DC batteries. It you are REALLY worried about needing the cap, it should be - in the correct voltage/capacity - on the INPUT side of the inverter, not the output.
    john12692rebeltaz
    Reply 1 year ago
    He is trying to boost the power rating of the inverter by using it to step up the voltage and charge the DC capacitors and then run the tools in bursts off DC.
    Before anyone says anything about the tools being AC tools, you can run tools with brushed motors on DC but they don't like it. They have extra vibration, produce more heat, and have half the power as compared to AC.
