New Rocket Powered Matchbox Cars! - Extreme!
75,475
89
170
About: Tinkerer, hackster and prankster. Hit me up on Facebook: https://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
First of all my inspiration for this project came from zjharva. This is a new version of Rocket Powered Matchbox cars with video! Now you see what they really do on rocket power! I used Hot Wheels cars but I felt they really needed to be called Matchbox because of what were about to do to them!
Step 1: What You Need!
First of all you will need a package of Estes A10-PT model rocket engines. You can find these at most Walmart store, hobby shops or other stores that carry model rockets.
Step 2: You Also Need...
Something to attach the 'engines' to the cars. I used 32 gauge wire that you can wrap around the vehicle and secure the 'engine' safely during ignition.
Step 3: And...
you need something to guide the car on it's track. Without this, the rocket shoots the car and rolls it, flipping and tumbling across the 'track'. I used a coffee stirrer and after cutting a small groove in the bottom of the car, cut it to size & glued it in place. This is the perfect diameter for the string that the car rides on.
Step 4: The Controller...
I picked up an Estes Race Controller that runs on 4 "AA" batteries and has a long enough wire with alligator clips at the end. These will attach to the rocket igniters and fire the rocket!
Step 5: And Now the Final Test Results!
This was wicked fun!! We brought them to a tennis court which was the perfect really flat surface and tested them out...here is the video!! Enjoy!
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    170 Discussions
    teknohawk
    6 years ago on Introduction
    You cannot build the igniter. It is a Estes rocket igniter. For $5.00 you can find them at almost any hobby shop. To make your own, you can (safely) build a fuse to go into the engine, or salvage some Nichrome wire and hook that up to a battery-It gets HOT because of it's great resistance applied to the batterys voltage.
    cj8675comodore
    Reply 6 years ago on Introduction
    I get 2 20 foot pieces of wire with alligator clips on one end clip the clips to the fuse and touch the other ends of the wore to a 12 volt cordless tool battery
    hunter1125estab
    Reply 8 years ago on Step 5
    do you mean a hoby store that sells estes rockets or a website that sells estes rockets? i have never seen a hoby store that sells official rocket cars.
    cowmanpokecomodore
    I opened one up once and I'm pretty sure it's just 4 AA batteries in series. No circuitry.
    yapoyo
    I did this with a C6-5 a few years ago and the car almost flew away! I los the car, but a few hours later, i found it about half a mile away from the launch site!!!
    build52
    we did that but we did't do the string and we also lost it
    asarris
    Awesome, modded your design with 500 yards string and 3 stage rockets, (used bigger car of course) for the stages i used a simple stopwatch that had (2nd stage .4 seconds and stage 3 which had 2 rockets on side at .8 seconds) clocked speed at 210 miles per hour :D destroyed the car afterwards and forgot to video it :c but it was fun. (for the stopwatches, when the initial current comes i sautered a wire so that it activates start and then another wire so that instead of beeping it activates the stage, sorry for long comment.
    pufferfish9108
    8 years ago on Step 2
    well about the rocket car, you could put 3 engines on top of eachother and then use 3 stages. Stage 1 would be connected to stage 2 with a piece of fuse string, and the same would work with stage 3. Or you could get a big ballon of hairspray or butane and have another fuse connected to that.
    TO THE PYROS OF THE WORLD
