Nifty Tool Bag
17,702
276
33
About: DIY maniac from South-Estonia! I love to inspire and to be inspired.
Being a maker is not easy! The constant need for new tools and ways to organise the old ones is a big headache. Especially if you are a one that travels a lot.
With the summer arriving if faced a real problem - how to keep my most essential tools with me at all times. I needed something that could hold all my tools, would be rigid enough and at the same time look classy and original.
I had a vision of a compact little tool bag made out of leather-like material with wooden handles.
To begin with, I have to say that I am not a skilled sewer. I am just a guy who reads some instructions, watches some YouTube videos and experiments a lot. So no need to say that if you feel that you would do something differently than me, do it!
Up to today, my bag has held up really well - no signs of wear or tear! I am also pretty pleased with the design and looks of it, although I would change the dimensions if I could do it again. To be honest the bag is too small for all the different stuff I want to keep in there. Somewhere in the not do distant future, I will make another tool bag. It will be bigger and will have organising pockets.
If you like my work be sure to follow me here on Instructables or on Instagram @kammsuhu
And of course, this project is taking part in a few competitions, soooo........ *wink,wink* ;)
Supplies:
Step 1: Tools and Materials
List of tools and materials for this build is not long, but some things are essential.
I have added some amazon links if you are interested ;)
Total cost of the project for me was around 40-50 euros
Materials
Tools
For the material, I chose synthetic leather because it is thick, strong and is made without causing any pain or suffering to the animals. And it is if course cheaper than real leather.
In the materials picture, you can also see few things I did not use in my build. I planned to also add a belt to easily carry my bag around, but it turned out not to work with my design, so I decided to leave it out. Also on the finished product, I added little plastic feet, which keep the leather from touching the floor.
I am pretty sure that many of you think there has to be a better way to work with leather. You are right! There are special leather working tools and techniques (that I still know nothing about). See the Instructables Leatherworking class or Jessica Ratfinc's Ibles if you want to know more about working with this material.
Let's get started!
Step 2: Preparing the Materials
To start off I made a paper template of the bag. This was just to make sure that it would turn out somewhat the right shape. Also, my cat really loved it!
I took my wooden dowel and cut it to the desired length. Then I eyeballed a straight line and cut it in two (lengthwise). I did some sanding and it was almost done.
After that, I moved on to the fabric. I carefully traced out the dimensions on the inside surface and then cut it out. I also cut two smaller pieces that would later become the ends. I should have made the sides of the main piece higher, as right now not too many tools fit in my bag. The length and the "floor space" of the bag are quite OK.
When this was done I moved back to the handles. I wanted my bag to be so that the handles clip together on their own to avoid dust and woodchips getting in there. To do this I glued in four pairs of strong button magnets. First, I drilled a small hole through one side of the dowel and slightly in the other side too. I did this to mark the magnet centre points on both sides. They have to line up correctly, otherwise, the handle would clip together crooked. Then I drilled holes for the magnets with a spade bit. The only thing left to do was to add epoxy to make it permanent. At first, I thought that four pairs of magnets would be too much, since they are really strong, but in the end, it turned out to be just fine (could have even added a few more)
Step 3: Assembly
I started by cutting a thin strip of leather and gluing and sewing it to the edges near the handles. This was to add strength to it. Then I sewed three lines to the end pieces - the middle one from the outside and two outer ones from the inside. I did this so that when I close the bag, the ends would neatly fold together each time (instead of randomly being pressed together) .
Then it was just the matter of sewing ends to the main section. Once again to add strength, I glued and sewed a thin extra strip to the edges. This time, I could not do it with my sewing machine anymore since the material was getting so thick. I moved to hand sewing. I did "cross stitching" (not sure if it is called that way), where I used two needles. At first, I just pressed the needles trough with a thimble, but at some point, it got so hard that I had to purchase an awl to punch holes. It made it a little bit easier. Still, it was a really time-consuming, painful and hard thing to do. At times like these, one really wishes he had the right leatherworking tools.
Step 4: Handles
Finally, I attached the handles. Once again first with contact cement and then sewing just to be sure they can hold the weight.
Apply the glue to both surfaces and let it dry for five or so minutes. Press together firmly and you are done. Different glues may vary so read the instructions on your glue tube.
Step 5: Finishing Touches
I also decided to decorate my bag with a few patches. Mine were iron-on patches but with only glue these never seem to hold on really long. And the Instructables iron-on patch is really weird. I have never been able to stick it to any surface by ironing it. It does not show a sign of sticking, so I always sew it.
Be careful when ironing synthetic leather as it melts really easily!
The bag on its own would not hold its shape (when carried around) so I added a 12mm plywood to the bottom.The material could be anything (and it does not need to be so thick), but plywood was the only thing I had.
As I mentioned earlier I added small plastic feet similar to these. It turned out to be a really great idea since it keeps the bag off the ground (less wear and won't get wet so easily)
Step 6: The End
Like always I am quite happy how it turned out.
As I said the size is bit small, so if you plan on making one, be sure to take it into account.
If you have any comments or questions let me know in the comments. I would gladly answer them!
I hope I have inspired you!
Cheers,
Andu
Tandy Leather Contest 2016
Runner Up in the
  • Arduino Contest 2019
  • Party Challenge
    Party Challenge
33 Discussions
carryc2
2 years ago
awesome
Maggs♍️
2 years ago
Well done . Did you use any special needles or an industrial sewing machine to sew this bag together? Would a regular sewing machine work ok?
CraftAnduMaggs♍️
Reply 2 years ago
Thank you! I did ask the ladies at the crafting shop for some special leather needles. They are not round but triangular. I do not know though how much it helps. I also purchased a heavy duty thread, but it did not work with my sewing machine (kept breaking), so for hand sewing I used this and in the machine I used regular one.
I did it all with regular Singer sewing machine, but at one point the material got so thick that I had to do hand sewing.
Take care!
HollyMannCraftAndu
Reply 2 years ago
Are you using pleather? I Just ask because it does not look like leather...and leather is super hard to sew through. Either way, it turned out awesome. I Love the style and you did a great job. I'm also in this contest...:) Good luck with it - results should be out soon. Even if you aren't using real leather, hopefully you can win some! I love Tandy and their leather and supplies! Good luck!
CraftAnduHollyMann
Reply 2 years ago
Thank you for everything!
Yes this is actually synthetic leather.
Yeah I hope the results will be out soon (though they seem to have some complications with it). But I am not really getting my hopes up as there are some extraordinary projects in the finals.
Good luck to you too!
JeffM15
2 years ago
Nice
TomMcIn
2 years ago
I had the same size problem with some tool boxes I built decades ago. When I built a bigger box that would hold everything, I couldn't lift it. Be careful what you wish for.
IzzyM3
2 years ago
hi,
Love the design so traditional and simple and so adaptable. I was thinking if you made it without the ends and put a tool roll liner so that sharp or delicate tools could be put into pockets then rolled up inside as all one piece. Or even just to hold say screwdrivers and pliers etc for easy access. Really love the look and will be trying it out for my self. Thanks
CraftAnduIzzyM3
Reply 2 years ago
Wow, this is actually a fantastic idea you got there! I will definitely give it a try once I get my hands on more chisel, screwdrivers and any other flat tools. It could be a fine woodworking burrito tool bag!
Awesome!
kas227
2 years ago
Ok you guys, move over. Sorry if it ruins your street cred, but I would love this as ... dare I say ... a handbag! So cool for a fellow crazy crafter! ???
CraftAndukas227
Reply 2 years ago
YEAH! I actually thought that too and few of my friends also mentioned it!
Thank you!
hammer9876
2 years ago
Two things about tool bags. 1) They are never big enough. 2) If they are big enough, they are too heavy to carry around.
Excellent Instructable.
CraftAnduhammer9876
Reply 2 years ago
I know exactly what you mean! Solution would be different bags for different jobs. Wouldn't that be awesome, eh?
Thank you!
