No Mess Yogurt Making
65,026
211
85
About: Mother of two, one seven month old and one husband. I love to make things and to collaborate with other crafters.
This is the easiest way to make your own fresh yogurt. I make it everyday- it's just that simple! It has saved me so much money and you can also just as easily make a spreadable yogurt cheese from the technique.
Whole milk produces a bit more than non-fat and is also quite a bit thicker when finished. I like a really thick yogurt so I usually strain out a lot of the whey when I'm done. The whey strains out quicker in the non-fat than the whole, but again you're left with less of a yield that way.
Step 1: What You Will Need.
All you need to make your yogurt is:
- milk
- a large pot
- a glass jar with a lid (sterile)
- a starter (can be a couple tablespoons from store bought yogurt with live cultures)
- a spoon (sterile)
- a candy thermometer (optional)
- a wash cloth (optional)
Step 2: Preparing the Milk.
The next step is to bring the milk to a temperature that will kill any bad bacteria that is already present. You do this by scalding it.
1. Pour milk into jar.
2. Put jar into pot of water on stove. Make sure the water line comes to about half way up the jar of milk.
3. Turn stove on high.
4. Periodically check milk until it reaches the temp of 185 F, or if you don't want to use a thermometer just wait until you can see tiny bubbles starting to form around the edges of the milk. It will also begin to form a skin on the top.
Step 3: Removing the Jar to Cool.
Remove the jar from the stove top and let it cool for about 45 mins in the refrigerator. It will be between 100 F and 125 F.
Also, take out your starter from the refrigerator while the milk is cooling to bring it up to room temperature.
I also turn my oven on warm at this point to make sure there is no temperature fluctuation while the yogurt is in incubation phase.
Step 4: Adding Starter.
So it's been about 45 mins and your milk is ready for the starter! Just add it with your sterile spoon and stir.
Step 5: Incubation Phase.
Now the trick is to keep your milk at a temperature between 90 F and 130 F. You have to do this to keep the cultures doing their thing.
My oven vents it's warm air through the back stove top burner. Which works perfectly when I have the oven on warm to incubate my milk into yogurt.
Step 6: You Got Yogurt!
Let your yogurt incubate anywhere between 4 to 12 hrs, it just depends on the tanginess and thickness you want. More time means more of a tangy flavor and a thicker yogurt, but you can always thicken it up by straining it for an hour or so.
I usually get my jar incubating right before I go to bed and wake up in the morning to strain it in the fridge.
Remember to remove some of the yogurt for your next batch. I remove a few tablespoons before straining.
Step 7: Straining the Yogurt.
To strain the yogurt just lay some coffee filters in the bottom of a colinder fitted inside a large bowl, pour in finished yogurt, and cover.
I usually let it sit in the refrigerator for an hour with non-fat or a few hours with whole, but then again I like a really thick yogurt. If you leave the yogurt straining overnight you get a nice spreadable yogurt cheese.
After it is to the thickness you want, just spoon into a storage container and you're done.
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    85 Discussions
    velveteen22
    3 months ago
    Hello! my name is Ana and I'm a product designer. I'm doing my final degree project and I'm looking for people with experience doing yogurt, kefir or growing other foods to ask some questions (a survey). Please, if you have few minutes it will be very helpful!
    This is the link:
    https://goo.gl/forms/TCqXh2LCDX3soYKC3
    I'll be very greateful! Thank you :)
    MagnusD1
    3 years ago
    Too complicated. I have developed a much simpler method: 1. Mix a spoonful of cold starter yoghurt with cold ultra-pasteurized milk. 2. Put the milk in a place that is 110 to 115 degrees Fahrenheit until it has thickened, from 8 to 24 hours. 3. Chill and enjoy. I have done this many times and I have not had a batch fail yet. I make half a gallon at a time and it has always turned out perfect.
    Notice the absence of of the messy heating and cooling step. The milk is already ultra-pasteurized when you get it from the store, which means it was already heated to 280 degrees F at the dairy--so why would I re-pasteurize and re-denature the milk by heating it again?
    I use milk from a carton that has not been opened until I'm ready to make the yogurt. My incubator box is my oven, which I am able to set to any temperature above ambient. I like to use 46 degrees F for 24 hours because I like my yogurt really tart.
    Remember that yogurt was made for hundreds of years, long before thermometers and refregration was invented. It can't be that complicated.
    boostme
    3 years ago on Introduction
    I have been making yogurt for several years after having been through oral cancer treatment and finding it one of the few protein sources I can use. Do not like the taste texture or cost of store bought yogurt. After much thought and trial and error I discovered the best method for myself. I had an old deep fry cooker with a dial thermostat sitting in the cupboard not being used. I do not trust the thermostat dial, so I use a candy thermometer. Put 4 about quart size glass jars w/lids in the cooker. !/4 cup of sugar in each jar. One cup half and half over the sugar. 1 Tbsp extract of whatever flavor (I'm afraid more might kill the starter w/alcohol). Stir and fill up the jars the rest of the way with whole milk. Put a water bath around the jars. Heat the bath to 200 F, turn it off to cool to about 100 F, add store bought starter, set the dial to maintain 100 all night. Next morning I have what I wanted, my yogurt, my way..
    Takelababy
    6 years ago on Step 5
    I use my small slow cooker to bring to temp. then turn it off, then remove the ceramic dish with the milk and lid and wrap thickly in towels and set in a picnic cooler and leave overnight.
    Yogurtdad
    7 years ago on Introduction
    I needed a reliable method to maintain temperatures for my bread making. I ended buying a brot &Taylor proofing box, http://brodandtaylor.com/purchase/buy-it-now/, and it has allowed me to make yogurt in a much simpler and reliable way. Most all yogurt maker machines in the market are too small for a family of four and the proofing box has allowed me to do large batches. It is also used for germinating seeds. I was not being very succesfull with the other "artisanal" methods. It is all about the right tool for the job. Great Comments from all. Thank you!
    Ray Power
    Thanks spuds, for the great instructable (the simple ones are the best). I've made a few batches already but I'm wondering: If I use UHT milk can I skip the milk heating step? I believe UHT stands for ultra high temperature and refers to the pasteurization of the milk. It has a fairly long shelf life and is not refrigerated until opened.
    Kringlurquinault
    Add sugar and vanilla? People normally add sugar to plain yoghurt when eating anyway.
    Poe-tate-oquinault
    Try a very very fresh starter or get a a starter from the a health food store. It helps quite a bit.
    coorodden
    7 years ago on Step 2
    Did as you said with towel on the bottom and water half way up. Broke my jar. Lost my good rich raw milk. What did I do wrong? I started with cool water in the pot, turned the ceramic burner on medium, then on high. It was fine at medium.
    Blaik
    7 years ago on Step 5
    Another method that works well and especially in making bigger batches (I normally do about a half gallon at a time) is to get a cheap styrofoam cooler and put your jars in there and then fill with warm/hot water to keep the temp where you want it. The insulation of the cooler keeps the water at temp w/o any need for adjustment (at least with mine) for about 2 hrs, but I keep my water on the lower end of the temp range, so if you did it warmer I'm sure it'd stay warm longer,
    jamina
    8 years ago on Step 2
    If you're using unpasteurized milk, heating it to 185 essentially defeats the purpose of using unpasteurized milk to begin with. Most sources state that heating to just under 110 is perfectly fine for raw milk, and you retain the benefits of the raw milk cultures.
    Store bought milk is full of weird stuff though, so I'd heat the hell out of it just to be safe.
    roulopa
    What a WAIST of energy! Using your oven vent for 4/12 hours, warming the milk before processing and then putting it straight into the fridge to cool down (doing so, warming up the whole fridge!). Where do you think global warming comes from.... Why not using a yoghurt machine that will keep your yoghurt starter / milk base warm for the same time? It's much more energy efficient and you don't end up wasting your money and proper energy. Please, keep things simple and efficient.
    oakspoorroulopa
    Simple and efficient doesn't involve buying yet another single purpose machine.
    roulopaoakspoor
    This is very true, unless you can use this type of low heating machine for yogurt, cheese or just keeping something warm (yeast).
    That being said, a yogurt machine can easily be found at car boot sales for under 10$.
    I make yogurt or cheese every week and it's only the two of use.
    oakspoorroulopa
    My point is that wrapping in towels, placing the ferment in a cooler is more efficient and much simpler. If you want to complicate it a bit, put a container of hot water in the cooler as well to act as a heat sink. I use this process with great results for fermenting yogurt, wine, sauerkraut, raising dough, etc. I love my yeasties!
    When you are finished with the yogurt, you can take the towels and cooler out to the beech or for a picnic.
    Yes I've seen those yogurt machines cheap at yard sales. I couldn't justify even this small expense and energy use compared to insulating methods that have served our ancestors so well.
    ms_janeroulopa
     too bad you misspelled "waste". apparently you "waisted" 18 years of teh edumacatshunz.
    good instructable!
    roulopams_jane
    misspelling when you are originally a none English speaker is not that important, you got the point, didn't you?
    And btw, can you speak any other language...?
