No-Sew 10 Minute T-Shirt Tote
239,493
346
48
About: Hi, I'm Jen! In my free time I'm a crafter, food lover, and cake decorator. I also can't stop taking photographs! I have a genuine love and appreciation for all things creative and handmade.
Did you know that about 100 billion plastic bags are used annually in the US alone and only about 2% of them are recycled? Check it out at www.droptheplasticbag.org.
It's a scary statistic but we can all do small things to help our earth! Using reusable bags or totes is a very easy way to do your part. It is a great alternative to buying reusable bags or taking merchandise home in plastic bags from stores and much more fashionable! They are durable and will last a long time.
Everyone at some time or another has probably had an old t-shirt that they didn't need or like anymore. This is a way to improve that favorite old tee so instead of tossing it make it into a reusable tote in about 10 minutes.
All you will need is an old t-shirt and a pair of scissors.
Step 1: Cut Sleeves Off of Shirt
You can use a short or a long sleeved t-shirt. It won't matter since you will be cutting the sleeves off anyway.
Lay your t-shirt out on a flat work surface. Using a sharp pair of scissors cut the sleeves off of your t-shirt.
Step 2: Cut Neck Out of Shirt
You can use a large bowl and draw around it on your fabric to get a nice rounded scoop shape or just eyeball it and cut the scoop. I just eyeballed it.
Step 3: Cut Slits and Tie Knots
At the bottom of the shirt cut slits about every inch through both layers (length will depend on the size of the shirt so you will have to make the call) long enough that you will be able to tie them twice. Remember the shirt will stretch with weight so try to make sure your tote isn't going to hang to your feet with filled with goodies!
Keep the slits lined up and starting with one end tie the aligning front and back pieces together in double knots until you have done the entire row.
If you don't want the knots to show you can tie them on the inside for a less fringed look.
Step 4: Tie Decorative Handles
This step is optional but I chose to cut small strips of extra fabric and tie small knots on the tops of the handles for a more decorative look.
The tote is finished and ready to use! Go shopping!
4 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
  • Classroom Science Contest
48 Discussions
wold630BarbaraF41
Reply 3 years ago
Yay! I'm so glad you made one! It looks great!
it took 12 minutes with my 3 year old watching. From the cut away collar you could make a child's sun shade by the way. We had such a great time!
I am going out to buy some groceries right now and will tell you how it went :-)
RobinP43icelandinthesun
Reply 3 years ago
That is exactly what i done , but i am using it for a head band for when i put my hair up at work
I'm so glad to hear you made one. You should post an instructable for the sun shade. I have no idea how to make one and would love to see it!
RobinP43
3 years ago
I used one of my uniform t shirts,, so when i work i can match !!
TiffanyT16
3 years ago
Really awesome way to reuse my husband's old t-shirts. The parts I cut off I'm reusing as cleaning rags or stuffing for future plushy animal/pillow project.
RafałH
3 years ago
Very cool it looks, the same I have also done so. At the moment I tried the simplest but much less nice http://www.open-youweb.com/how-to-make-at-shirt-bag/ see how this will come out again.
CalvinY2
3 years ago on Introduction
Piece of Advice: Don't trim down t-shirt at bottom before tying it, other wise it will look too short.
kensmaxi
My first attempt making Tshirt tote but practice makes perfect..
mlevitt
3 years ago
Can knot on the inside and turn inside out for a kind of finished look.
you could probably do this idea as well to making pillow cases... except cut off the top of the shirt under the arm pits, if you have a picture in the way, just curve around it. Then knot fringe the end the neck and arm holes used to be and slip it over a pillow. :-D
MelissaS1
4 years ago on Introduction
I made this as a lunch box. A good variation of this is to get a 100% cotton shirt, tie-dye it, then make the shirt.
Southpaw69
5 years ago on Introduction
Just finished making one of these, and it was super easy!
This will be perfect to use, now that they are charging for bags now.
jhyland
LOVE THIS! Going to do with an old Sweatshirt... should up the heavy duty factor of the bag!
AmyCat59
6 years ago on Introduction
I've got a Serger (4-thread overlock sewing machine), so will probably use this basic pattern but sewing the bottom together and reinforcing the handles with strips of fabric from the cut-off parts for extra strength...
Another idea: save one of the cut-off sleeves, sew (or tie) it closed at the cut end, and use it as a "stuff-sack" for the bag when it's not in use. You can even run a drawstring through the sleeve-cuff with a tapestry needle threaded with heavy yarn or crochet-cotton...
wold630AmyCat59
Reply 6 years ago on Introduction
Unless you are hauling around weights (and I'm guessing your aren't!!!) the tote doesn't really need reinforcing. The t-shirt fabric is surprisingly strong but I guess it couldn't hurt.
My shirt sleeves were too small to make a 'stuff sack' but that is a GREAT idea! I love it.
