No Sew Fleece Blanket
1,581,151
594
67
Step by Step instructions to make a No-Sew Fleece blanket, brought to you by Bunyworks.net. Your blanket can be any size. Fleece comes 60-inches wide, so your blanket can be 60 x ??? Your finished product will be about 10-inches smaller than the fabric you start with.
Supplies:
Step 1: Choose the Fabric
Choose a print and a contrasting or matching solid. I like to use strong, bold contrasts. You will need a solid and a print that are the same size. My sample uses a nice dark hunter green for the back.
Step 2: Line Up the Two Fabric Pieces.
Line up the two fabrics, right sides OUT. Anti-pill solids are FUZZY on the right side. Anti-pill prints will be more distinct on the front side. Regular prints are hard to tell -- use the side that appeals to you.
Step 3: Trim to the Same Size.
Trim the two pieces so that they are the same size.
Step 4: Cut Out the Corners
Cut a 5-inch square from each of the four corners.
Step 5: Cutting the Fringe
Cut fringe on all four sides of the blanket. Cut through both layers of fabric at the same time. Fringe pieces should be a little wider than the width of your finger. Cut in from the edge 5 inches. I like to lay a yard-stick across the fabric, 5 inches from the edge so that I know how far in to make my cut.
Step 6: Begin Tying Knots
Leave your blanket laying flat on the surface, with all fringes lined up. I find it easier to start tying from the left and work right, going around the blanket. If you are left-handed, you may find it easier to start on the right and work left. These knots are called balloon knots... tie them just like you would if tying off a balloon! You can also tie a knot like you would make with a shoe lace. That kind of knot will be easier if your hands are arthritic.
Step 7: Continue Around the Blanket
Tie all the fringes together on all four sides of the blanket. You are Finished! Wasn't that easy? All the knots should be snug up to the blanket, but not too tight. The finished blanket should lay flat.
Tip: If your blanket is square (all four sides the same length) you can turn the top so that the stretch goes in the opposite direction of the stretch on the bottom piece. This gives a more stable blanket.
Use the same directions to make pillows... if you have a 12-inch pillow form, cut two pieces of fabric that are 24-inches square. Tie three sides, insert the pillow form and then finish tying the 4th side.
7 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Fandom Contest
    Fandom Contest
67 Discussions
scoops56AngelaM69
Reply 6 months ago
of course you would; you never know where it's been or who has touched it
howleyAngelaM69
Reply 9 months ago
I would wash in warm water with a small amount of suds. The fabric has probably been treated or possibly hands have been touching it.
scoops56kyleejojo
Answer 6 months ago
walmart .com also has lots of fleece
bunycraftkyleejojo
Reply 9 months ago
When I made the video I was selling the fleece! Now, you can buy fleece in just about any fabric store.
irenebearden
Question 6 months ago on Step 4
if you cut out corners how are they done why tying ?
bunycraftableakney
Reply 9 months ago
The same way you tie off a balloon after blowing it up. I don’t know how else to explain it, lol
MemaOfFiveableakney
Answer 1 year ago
Just as it suggests, as you would tie a balloon you've just blown up.
MemaOfFiveSbarnes83067
Reply 1 year ago
Yes. Whatever length you want the fringe to be is what size you cut the square. 5x5 for 5" fringe. 4x4 for 4" fringe. 3x3 for 3" fringe.
MemaOfFive
Tip 1 year ago on Step 5
You can also use masking tape in place of a yard stick to do your cutting. Just lay across fabric to do your 1" (or whatever width you chose) up to the 3", 4", 5", etc to match your square size.
ConstanceM12
1 year ago
So easy and such a nice little blanket!
Swansong
2 years ago
A friend of mine makes these as gifts and they always go over really well :)
T0BY
2 years ago
Brilliant idea!
bookwormsfg
2 years ago
I made some! They are very easy and fun, and are a great multi-tasking project (I tied mine while watching TV). I recommend 1 yard for a child's blanket, and 2+ for an adult blanket, depending on what you want to use it for. I finished making a child's blanket last night, and it only took me about two hours. I haven't quite finished the adult's blanket yet, but I think it will take between 2 1/2 and 3 hours.
Alex-
3 years ago
This is a great tutorial! The pictures are a little dark, though.
Here's a new step-by-step tutorial--with awesome pictures :)
http://blog.spoonflower.com/2016/04/how-to-make-a-no-sew-fleece-blanket.html
