Arduino NodeMCU ESP8266 Based WIFI Smart Strip 4 Relay Switch Board With Raw TCP/IP, Mqtt & Android App
The Node MCU is an open source ESP8266 based Wifi enabled IoT platform for everyone. What we have done is created a four relay board for it and the coolest part is that board also has a 100-240V-AC to 5V-DC Power supply on board so you will be able to connect it directly to AC mains while creating a Wifi enabled switch board. It also has a header where you will be able to connect i2c based devices(Something like an I2C based OLED ) although we will still need to test this .
A brief specification of the board is as mentioned below
  • It comes with a header where you can plug in Node MCU Module .
  • Four Relays to connect four AC/DC loads and both NC/NO connectors of the relay are provided
  • SSID and Password can be set directly from the mobile app
  • Can be pre-programmed with MQTT for Networking/Home automation integration.
  • 100-240VAC or 5VDC select able input.
  • LED for Testing which is connected to a GPIO and also as indicator when the relay go on /off
  • Dimensions of the board are 145 X 60 X 18 mm
Step 1: Wiring the Relay Board to Four Two Way Switches and Four 3 Pin Sockets
I have created a few diagrams to help you out with the wiring .The first diagram is a logical diagram .You will find on one side a red colored vertical line that is the AC phase/Line and on the right there is another vertical line which is the neutral. On the four relay board both NC (Normally Closed Circuit) and NO (Normally Open Circuit) of the relay are available. The two way switch has three terminals - NC, NO, Common and is usually as shown in one of the diagrams.The reason for using a two way switch is to have both physical as well as using you mobile phone to turn on/off some appliance.
The logical diagram shows how the connections are made. Let me show you the status and the load condition based on the status of relay and the switch
Relay Switch Load Relay & Switch
NO NC NO NC Status Status
0 1 0 1 OFF BOTH OFF
1 0 0 1 ON RELAY ON
1 0 1 0 OFF BOTH ON
0 1 1 0 ON SWITCH ON
I hope this is clear. The load here in my case will be the three pin socket you may also connect the load(Fan, TV, light etc) directly but make sure you take appropriate measures while connecting to the main .
Step 2: TCP/IP Based Android - Arduino Code to Control the Switch Board
You can find both android app and the arduino code on our GITHUB page
I have shared some images and video for your understanding
The initial set up is simple just install the apk on your android phone
Search for ESP/AI-Tinker Hot spot on your phone.Connect to it. After that start the app Wifi Four Relay board
Enter 192.168.4.1 in the ip text box
Enter 80 in the port text box and then press connect .Here you will find four buttons you can click it and the light/load should turn on/off
If you want to connect it to your wifi router without changing the program you will need to send the following command
SSID:xxxx:yyyy:
xxxx will be your Wifi SSID
yyyy will be your Wifi Password
Step 3: Mqtt Basic
MQTT (Message Queuing & Telemetry Transport) is a publish-subscribe based "light weight" messaging protocol for use on top of the TCP/IP protocol.
It is designed for connections with remote locations where a "small code footprint" is required or the network bandwidth is limited. The publish-subscribe messaging pattern requires a message broker(Some thing like a server). The broker is responsible for distributing messages to interested clients based on the topic of a message.
For details you can visit this site http://mqtt.org/
In My application I have used a board called Onion Omega
Its a good board if you wish to install just the MQTT Broker but if you wish to develop a full fledged Home automation system I suggest you do it using Raspberry Pi and Open HAB
Onion Omega runs a flavor of linux called Open WRT (Its a custom Linux flavor which is popularly used on many routers) .You will need to install the broker on this using terminal via ssh (Use Putty on Windows)
Refer this link to install MQTT broker Mosquitto on OpenWRT
http://mosquitto.org/2011/08/mosquitto-on-openwrt/
Here are the steps
opkg update
opkg install mosquitto mosquitto-client libmosquitto
This will install the broker and client on Onion Omega. After it installs you can try simple commands using two terminal /putty windows.On one of the window/terminal just type
mosquitto_sub -d -t msg/box
And on the other just type
mosquitto_pub -d -t msg/box -m "Hello World"
you should get "Hello World" on the other first window(Where you entered mosquitto_sub -d -t hello/world).
Here "msg/box" is called a Topic this can be any thing (eg. can be sensor/analog or sensor/digital or RelayControl etc) .One can either subscribe to a topic(first command did that) or can publish to a topic(second command published "Hello World" to the topic msg/box) once that is sent to the broker all the devices will receive message "Hello World" if and only if they have subscribed to that topic.
Also note if you are using some other device where your broker is not installed on you will need to add the broker ip in the command as shown below
mosquitto_sub -h YOUR_BROKER_IP -d -t msg/box
mosquitto_pub -h YOUR_BROKER_IP -d -t msg/box-m "Hello World"
Step 4: MQTT Code and Linking It With Other Devices Like Onion Omega or Pi
Please Watch the video to get some idea
What I am trying to achieve here is I have two types of Esp8266 based board one is the node mcu four relay board and the other is Attiny85 +Esp-01 based board ,both of them should communicate with each other through the broker .You can refer to this instructable for details regarding the Attiny85+Esp-01 Board.I have loaded both with MQTT client code.
Attiny85+Esp-01 Board has an additional gpio free which I have used and have connected a PIR sensor .One of the image will show how the box looks.
The Broker is installed on Onion Omega which runs Open WRT .
The preferred android mobile app is My Mqtt but most of it is text based . I also do have a modified app but its is not full proof. Will upload the code once it is usable
Here are the commands I have integrated
+ATon --will turn on the relay of the Attiny85 +Esp-01 board
+AToff --will turn off the relay of the Attiny85 +Esp-01 board
+ATstatus --Will give you the status of the PIR sensor (High /Low)
+ATstart ---Will start notifying to the topic "Relay_Control" change in status of the PIR sensor (you will receive PIR HIGH ,PIR LOW message on your mobile ) .It also turns on/off the relay of the Attiny85+ Esp-01 board
+ATstop ---This will stop the above notification and also makes the relay independent from the PIR sensors output
R4_ON ---Node MCU four relay boards first relay turns ON
R12_ON---Node MCU four relay boards second relay turns ON
R13_ON ---Node MCU four relay boards third relay turns ON
R14_ON ---Node MCU four relay boards fourth relay turns ON
R5_ON ---Node MCU four relay boards led turns ON
R5_OFF ---Node MCU four relay boards led turns OFF
R4_OFF---Node MCU four relay boards first relay turns OFF
R12_OFF---Node MCU four relay boards second relay turns OFF
R13_OFF--Node MCU four relay boards third relay turns OFF
R14_OFF ---Node MCU four relay boards fourth relay turns OFF
the number attached to R represents Gpio on nodemcu/esp
The above commands can also be sent or see by publishing or subscribing from a mqtt client machine using the below command
mosquitto_sub -h YOUR_BROKER_IP -d -t Relay_Control // to subscribe to Relay_Control Topic
mosquitto_pub -h YOUR_BROKER_IP -d -t Relay_Control -m "xxx" //to send commands to Relay_Control Topic
xxx here will be any of the previously mentioned commands eg off01, on01 etc
plz make sure you have installed at least mosquitto-client, libmosquitto packages on the client computer
I will still need some time to update the content will do that as I develop the application .As of now just posting it .If you have any question plz do comment and probably I will modify the instructable to clarify your doubts
Thank you
Step 5: Safety Warning
Safety Warnings
You probably already know all this but in the interest of your safety, we feel compelled to state all this clearly. So take a few minutes to read it carefully .
AC mains are very dangerous -- Even a 50 V AC supply is more than enough to kill you. Please switch off the mains before making or changing connections, be very very careful.If your are not sure of anything related to the Ac supply lines please call an electrician ask him to help you our with it . Do not attempt to interface to mains unless you have adequate training and access to appropriate safety equipment. Never work on high voltages when you are alone by yourself. Always ensure that you have a friend/partner who can see and hear you and who knows how to quickly turn off power in case of an accident. Use a 1A Fuse in series with the input to the board as a safety measure. Basic Wiring diagram is available on our instructables page and github. Please go through it. If you are not very sure on how to wire it but wish to play with it use and external 5V DC 1Amps adapter with a micro usb connector and connect it to the boards micro usb connector to power the board on . Test it by configuring the board (Youtube Link https://www.youtube.com/watch?v=imY7AlIaPLQ ) and triggering the relays without any load Also use appropriate external snubber circuits on connecting inductive loads
Fire Hazard:
Making wrong connections, drawing more than rated power, contact with water or other conducting material, and other types of misuse/overuse/malfunction can all cause overheating and risk starting a fire. Test your wiring and the environment in which it is deployed thoroughly before leaving it switched on and unsupervised. Always follow all fire safety precautions.
    • Remix Contest
      Remix Contest
    • Pocket Sized Contest
    • Tape Contest
      Tape Contest
    32 Discussions
    MárioV18
    5 weeks ago
    Can you tell me how can i do to turn ON or OFF the relays over app BLYNK? After programming the board, i change he dip switch to 1-2 and 3-4. I can´t make the relays work.
    ArmtronixMárioV18
    Reply 26 days ago
    Not familiar with blynk . Currently the gpios used for the relays are gpio 4, gpio12,gpio13,gpip14
    Jaganbecse17
    Question 9 months ago on Step 5
    Can we use this project without internet to on off the switch
    janakbhada
    10 months ago
    Could you please suggest connection for this circuit board. If we would like to program it.
    Do we need another 5v power supply to this circuit for programming using arduino?
    Kool Engineer
    1 year ago
    Hi
    First of all I must say nice project. I wanted to know how to make PCB board. Can you please share PCB layout diagram? Thanks in advance :)
    ErA10
    Question 1 year ago on Step 5
    I am using 4 ssr board find wifi mqtt apk on GitHub but it's not given apk please help for Mqtt example
    1 answer
    ArmtronixErA10
    Reply 1 year ago
    Currently we have only http app. You can use third party app like my mqtt
    Generally mqtt command will be
    R4_ON
    R4_OFF
    R12_ON
    R12_OFF
    R13_ON
    R13_OFF
    R14_ON
    R 14_OFF
    You can use these commands and trigger
    For http app
    https://github.com/armtronix/Android_App_Home_Automation
    MohiddinB
    1 year ago
    Hi,
    This is Mohiddin Basha sk , with Order AWB# 59627437785 from Ebay.
    I have Ordered "Arduino NodeMCU ESP8266 Based WIFI Smart Strip 4 Relay Switch " on 27th Oct 2017 and received 30th Oct 2017.
    I have followed steps as per instructions provided at "https://www.instructables.com/id/NodeMCU-ESP8266-Based-Switch-Board-with-Raw-TCPIP-/".
    I was unable to Switch ON/OFF lights as shown in your Instructions and sample videos.
    Step by Step i followed for reference:
    1. I have Done wiring for Circuit Board / Switch Board as mentioned in instructions.
    2. Tested manual Light On/Off. ( With Switches ) , Its working.
    3. I have Installed app Provided at Githib Link.
    https://github.com/armtronix/NodeMCU_four_relay_board
    https://github.com/armtronix/NodeMCU_four_relay_board/tree/master/androidapp
    4. When i switched on the device. I got "Armtronix-c7:8f:de" instead of "ESP/AI-Tinker" as Wifi.
    I have connected to Wifi "Armtronix-c7:8f:de".
    5. From App provided, I have entered the IP address as 192.168.4.1 , Port: 80 as mentioned in instructions.
    I tried switching on/off with the app but it did not work.
    To make sure the communication from device and Smart phone working.
    For Testing purpose,
    I switched off my "Armtronix" device and tried to connect with my app. I have got an error "Unfortunately four relay board has stopped".
    When i switched on back my "Armtronix" device, I was able to access my app without any issue which shows communication aspect is working and device command aspect is not working.
    Can you please guide the right way to make it working for me.
    Thanks & Regards,
    Sk mohiddin basha.
    Mobile: 9848207948.
    Email: basha.contactme@gmail.com.
    ashishagravat49
    1 year ago
    hello,i make 4 channel relay board for automation purpose But,when i m give command to 1 relay then all relays goes to on so please help to make my code perfect.
    SammyS1
    1 year ago
    VERY VERY poorly explained and written article ..... pity. And I am not a noob I have done my own Automation Project with Rpi and 4 channel relay and also with sonoff with tasmota firmware communicating with another Rpi running Home Assistant and MQTT server, and THIS myfriend is the worst tut I have even read. Why I landed up here was because I am planning to another project this time based on NodeMCU and 4 channel relay instead of using Rpi and your article did not help at all ....
    AhmadM164
    2 years ago
    it is not helpfull :(
    bharata15
    2 years ago
    hello armtronix,
    Can i show status of light bulbs in mobile app?
    nitin4212
    2 years ago
    Two way communication is possible through this board .when on or off
    through physical switch then any notification message in mobile.
    hot-chili
    2 years ago
    The electrical box says "Oreva". Where did you get this box? I tried to find a similar box in the U.S., but could not find any.
    Armtronixhot-chili
    Reply 2 years ago
    we can provide it or you can get it form the manufacturer
    AXR AMAR
    2 years ago
    Awesome..!
    NishaM15
    2 years ago
    Can someone please provide me with the PCB design schematics for this project??
    ArmtronixNishaM15
    Reply 2 years ago
    Related documents that can be shared
