Nojo Design: Large Step Cabinet: February 2012
25,564
378
32
The largest single piece of furniture I’ve ever made is this stepped cabinet.  Finished piece is 8 ½’ tall and over 10’ long.  This project has been great, although it almost fell over on top of me at one point
Step 1: Getting Started
1. I started with several client meetings and design iterations for the cabinet.
2. Once the design was finalized, I did some calculations and headed to the lumberyard and bought 5 12’ 8/4 boards of black cherry to build the frame of the piece.
3. Back in the shop, I cut down all the rough boards except for one, which I made the longest members with.  Then I straightened one face and one edge of each board on the jointer and then sent them all through the planer to get even and consistent thickness of 1 13/16”.
4. After that, I ripped all the boards on the table saw down to 1 13/16” squares and sent them all through the wide belt sander to achieve even 1 3/4” square stock.
5. Then I carefully calculated a cut list for the stock and cut all parts to length on the table saw.
Step 2: Beginning Joinery
6. Moving to the horizontal mortiser, I carefully set up an exactly centered mortis in the stock and begin cutting mortises in the ends of all the short pieces and then on the longer pieces, I took time to lay out the mortise location.
7. Once all mortises were cut, I dry fit the carcass to see the shape of things to come.
Step 3: Making Panels
8. Then, I measured for all the panels to fill in the backs, dividers, and sides.
9. Using 1/16” thick veneer I cut panels for all the back panels and interior dividers.  For the outer walls, I carefully book matched some of the same material into 9’ x 22” panels so the grain followed up the ‘treads’ and also the ‘risers’ as you look at the unit from the side or top.  This effect is subtle but was worth doing. This detail only takes some careful planning and labeling as you go.   To make a tight/straight joint on the veneer, run it across the jointer set very low.  This trick will only work with the extra thick veneer.  I then secure the joint with regular masking tape.
10. For the substrate, I used ½” ultra light MDF.  Since the panels aren’t structural, the less weight will be appreciated later.  I cut pieces to match the laid up panels on the table saw.   Using a foam roller I applied an even coat of yellow glue to the veneer and one side of the substrate and slid it into my vacuum bag face down.  Some prefer to glue both sides at once; I’ve never had any problem doing one side at a time.  I leave each side to dry a minimum of 4 hours.  There are a lot panels – this takes a few days.
11. When the panels were all done, I scraped the tape with a cabinet scraper.  If you don’t have a widebelt sander I strongly recommend looking into renting an hour on one at a local cabinet shop.  This will give you consistent thickness and uniform sanding pattern.  You’ll still need to finish sand prior to assembly, but this is unavoidable.
12. With the frame still dry fit together, I labeled all of the parts.  I also marked where every panel went.  Take the extra time to double check that every part is labeled and the position of each panel is well marked.  I have never not missed one, so triple check.
13. Back at the table saw, I set the dado blade to the thickness of the sanded panels plus a ‘hair’.  Just loose enough to get piece bit of paper into the slot with the panel.
14. Now, I cut all the dados in the members as marked.  There are some that required stopped dados.  When you do this, PLEASE TAKE YOUR TIME!  Stopped dados need extra special care on the table saw.  I did mine on a Saw Stop and was glad to know I had that extra security.
15. I made some ½ loose tenon stock and sized them to fit the exact width of the mortises.  Then I set a stop on a miter gage and cut a enough for all the front and back mortises.  I cut them 1/8” shorter than the combined depth.
16. I then glued the front frames together.  I choose to do this in stages when possible.  It’s nice to be able to just have a few elements to have to control and square up.  As each element is glued together I take careful care to check for squareness.  Tight and straight work is imperative at this stage.
Step 4: Glue Up
17. I measured off the front frames for the sizes of the back panels.  Adding for the depth of the dados, I cut the panels starting with the largest ones first and took care to choose pleasing grain placement.   Then, I finish sanded all panels to 220 grit and eased all the edges.  This is important to avoid chipping the veneer during construction.
18.  Next, I glued up back panels.  Now it’s coming together!
19. For the last time, I dry fit the cases together and measured for the missing panels.  I sized and sanded all panels taking careful care to label the riser and tread panels to keep them in order.
20. I sanded the front and back frames, preparing for the big glue ups.   I took an extra minute and ran some 180 grit along each dado.   This helps the parts come together when the heat is on and the glue is setting.
21. Now I gathered clamps, a couple of glue bottles, some rags and a rosary.  I cleared the workspace and carefully laid out all the parts needed and devised a plan for applying glue, inserting tenons and panels as smoothly as possible.   At the start of your glue up, take a deep breath and get going.  If all goes well – congratulations, if not pull it apart.  It’s not worth getting it wrong.  Take it apart, wipe off the glue and try again the next day.
22. Now invite friends and family to tell you how clever you are for making such a cool thing.
Step 5: Doors
23. With a sharp chisel and a random orbit sander, I cleaned up the extra glue and smoothed the joints and was sure not to round over any of the nice square pieces.
24. On a piece of paper, I laid out the different paneled doors. Then, taking care with my measurements off of the case, I created a cut list for the necessary parts.
25. I milled necessary stock to a strong 3/4” and also laid up the necessary door panels as described earlier. Once I milled the stock, I checked the original dimensions carefully and sized all stock on table saw.
26. Then, I cut mortises in all the necessary joints – this should only take one setup on the mortiser.
27. I put panels in the veneer press one side at a time. After pressing, I removed all glue from the press panels and sand panels. As with the frame, I cut dado’s to allow for panels. Once again, you should be very careful with the stop dado’s.
28. I glued up the doors, taking care that they were flat and square.
29. For the sliding doors, I repeated all the same steps, but made the stock 5/8” thick.
30. Using a calculator, I devised a symmetrical layout for the decorative latticework.
31. With decorative lattice strips prepared, I created ‘layout’ blocks to help evenly space the strips. I marked all joints with a pencil and cut on a mortising machine.
Step 6: Setting Doors
32. I glued up the sliding doors – same as the regular doors. Then, I sanded all doors, paying close attention to the joints; making them nice and even.
33. On the regular swinging doors, I bored for 32mm cup hinges. At the same time, I took a sacrificial piece of wood – the same vertical size as the door – and bore that as well.
34. I mounted cup hinges in the sacrificial member in order to align the cabinet hardware of the hinge.
35. Now, I placed the sacrificial stick in cabinet with a ¼” setback, taking care to keep the stick perfectly vertical.
36. I attached the door hardware into the cups and placed the doors in the stepped cabinet. Are you still with me?
37. Then I made adjustments for even spacing for optimal 1/16” reveal all the way around and smooth swinging.
Step 7: Sliders
38. On to the sliders; I installed the decorative latticework of the sliders.  My first step was to size all the sticks, disregarding the need for joinery.
39. Then, in two stages, I marked for the joinery. First I installed all the vertical sticks at once and with a long straight edge and marked all the necessary dado’s.
40. I remove the horizontal sticks and repeated the steps above for the vertical sticks.
41. With a miter gauge on the table saw and my blade just coming out of the table, I cut all necessary dado’s, taking time to fit each one.
42. I glued it all together with the assistance of a little hammer.
Step 8: Drawers and Finish Work
43. Then I moved on to drawers. I decided what size I wanted my drawers to be and sized my stock. I like ½” wall drawer boxes.
44. I cut dovetails (use whatever method you are comfortable with) and glued the drawers together. Then, I decided what kind of drawer fronts and handles I wanted. I fabricated, sanded and attached to the drawers after they’d been sanded.
45. After, I final sanded all my parts – case and all. For this, I suggest you wear your dust mask and turn your radio really loud, this step is going to take a while.
46. Time for finish work. I chose to spray all my parts. You may choose the same or to oil. As with all steps, take your time here. Any piece of furniture is only as good as the finish that you put on it.
Step 9: Full Instructions
Furniture Challenge
First Prize in the
Furniture Challenge
ShopBot Challenge
Finalist in the
ShopBot Challenge
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    32 Discussions
    vicra
    6 years ago on Introduction
    this would be perfect to match the new stairs i have to install in the house.. either next to (so the tops can serve as more space) or tucked under the stairs... all i can say is WOW!!!!
    studleylee
    7 years ago on Introduction
    I notice your handsome/pretty(?) dog there and wanted to add that this would be perfect for helping an older pet get to the high places they loved when younger. I could see cats loving this. -Lee
    luvfunstuff
    7 years ago on Step 9
    Fabulous projects like what you have accomplished here is the reason I wish I knew woodworking. This is really unique and looks really well made! Way to go!
    nojodesignluvfunstuff
    Reply 7 years ago on Step 9
    Thank you. It's a very satisfying feeling to design something, build it and live with it. If you ever get thr chance to experience making something with wood, I'm sure you'll enjoy it.
    luvfunstuffnojodesign
    You're welcome! : ) I think I'll start with some bluebird houses. Would probably be hard to goof them up, but if I do, I don't think the birds will mind too much ;) Have been dieing to use these antique wooden clamps that were my husband's grandfather's tools. He was a carpenter to the royal family of Bohemia, when it was still a country. (not fooling!) If his grand-dad were still alive, I bet he'd like to see them being used again. Thanks for the suggestion, I'm sure this will be fun!
    Obviously very lovely stuff, I wish I had your shop. Anyways I was wondering if we could see this in its final resting place? Id love to see what this looks like in your house.*
    (Disclaimer: I skimmed most of the instructable so if you mentioned it somewhere in there I didn't see it, sorry!)
    tn.
    i LOOOOOOOOOOOOOOOOOOOOVE tansu cabinets!
    just a bit of background for those who don't know: the tansu is supposed to be modular, able to be broken down into individual chests and cabinets and tables and whatnot, then reassembled into the step formation.
    what happened was that taxes were levied on second-floor living spaces. so the poorer citizens devised this ingenious method of cheating the tax man: go into the home, it's a simple one-floor bungalow with everybody lying around cheek-by-jowl, typical poor peasants. once the tax collector was out of range, they reassembled the step chest and revealed the trap door hidden in the ceiling that led to the upstairs living quarters.
    DDW_OR
    very nice, lots of storage and can be build to match my stair case.
    yes i know i cannt not walk on this
    i also like your shop.
    in the photo in step 1, what are the long things hanging on the wall??
    nojodesignDDW_OR
    Thanks for the kind words. The cabinet could function as steps. However this one is not going to be.
    My shop is in a old vaudeville theater I renovated 11 years ago. So the goldish thing on the wall is a pressed tin column that framed the stage. The project made for a wonderful work space.
    DDW_ORnojodesign
    I am refering to the right of the column, and under the wood cabinets.
    i will be renovating an old 60x60 pole barn to make a shop. looking for all Usefull ideas.
    nojodesignDDW_OR
    Oh, those are just rows of my lighter duty clamps. I feel strongly that all tools need a home in shop. Good luck with your project, sounds like lots of fun.
    TigerMoon
    So beautuful, so practical, my cats would LOVE this! And me too!
    Gosumdoji
    Fantastic piece of work you've put together there! I've made a couple of smaller tansu myself, but this definitely puts them to shame.
    Would you have/be interested in sharing measured drawings, or at least a few of the 'box' dimensions? This looks like something I'd like to try for myself.
    Excellent project!
    Rich99
    is that a printer's tablesaw that you use for crosscuts? i haqve one in my basement,m collecting dust. it has the dial micrometer stop on the fence.
    nojodesignRich99
    Rich99 - It is a printmakers saw, I found they can be nice additions to a fully equipped wood shop (with some modification). Let me know if you have any questions about it. If you are not interested in using yours, please let me know; I may be interested. Thanks for looking at my posting.
