Nolan Wood Mosaic
8,474
121
8
About: I'm a part-time builder/blogger that loves tinkering in my shop on woodworking projects, fixing stuff around the house and tending to our flock of backyard chickens. For more projects check out my site at ww...
This tutorial is going to be a little different. Rather than show you how I built this exact wood mosaic, instead I'll show you how to build your own unique one. Every snowflake is different (ask Elsa and her frozen fractals all around) and so is every wood mosaic. But I'm not going to leave you high and dry, check out the video first on the build and I'll give you the details after the break (oh and the music is funky this time so crank it).
Welcome back!
So how about those sweet baby angles? The way us numerically challenged folk handle these varying degrees is to crank your saw around to the 45 degree mark and leave it there. That's it, that's the secret. Don't make it difficult, just go with the 45's and don't make it more difficult. You can very easily use a speed square to check your work too if things get crazy.
Another trick I used is I designed the entire thing in Sketch Up ahead of time, that way I could see the design and have everything worked out and estimated before I gave it a go. Sketch Up is a free program, so don't panic. There is a learning curve but it's great for all sorts of builds.
Tools Used
Material Used
  • 2' x 4' Project Panel Plywood
  • 1" x 2" x 8" select pine boards
  • 1" x 4" x 8" select pine boards
For more tips, tricks & tutorials, follow me on Instagram @LazyGuyDIY or on the website: www.LazyGuyDIY.com
Supplies:
Step 1: Step 1 - Sweet Baby Angles
Maybe this is overkill to start this project, but I'd rather have things go smoothly than wing it and have my end project show up on the Epic Fails of Pinterest website. Using the material from the actual project, I traced out my lines on to the sheet of plywood I'm attaching the planks to. AND IT'S ALL AT 45 DEGREE ANGLES! Heck, you don't even need a plan, just start drawing lines and go crazy. Just make sure your lines are the same width as your material. Sort of important.
Step 2: Step 2 - a Cut Above
I gave about a half inch overhang on one side though. That way I had a little extra to work with later if anything went south. And not in a good way going South like traveling to New Orleans for Hurricanes and Beignets. Like, I cut this too short and now my entire project is ruined south. What's nice is that you can cut all 4 pieces of each section in one sitting. Wait what? Doesn't the mirrored section have opposite angles? Yes, but flip your material over so the pretty side is down and make your cuts so you don't have to constantly change your saw angle from left 45 to right 45. Mind blown... I know. If you have no idea what I'm talking about... look over there a bird!
Step 3: Step 3 - Make It Pretty
Paint and stain your pieces. This is where having a plan actually matters. Especially if you want things to be all symmetrical or you know... to look good.
Alright, this might seem like a no brainer but... you know... do we have to bring up the first time I used a Kreg jig and put wood glue into the hole instead of the joint? Paint and stain your pieces before you attach them to the project. My paint took two coats and my stains just one with a poly seal afterward. Save yourself some time and do all your same color pieces at once. Or heck, really save yourself some time and limit the number of colors or stains you use. There's a lazy tip for you.
Step 4: Step 4 - If You Haven't Already...
Assemble and support the backer board. I swear this is 100% not because I'm lazy, but more so because I don't have a truck so I hate hauling plywood. I buy those 2'x4' project panels a lot because they are so much easier to transport.
In this case I made a support frame out of 1x2's and gate brackets. I originally thought I'd pocket hole the two sheets of plywood together and then have the external frame hold it together... but guess what? I didn't buy 3/4" plywood. Improv time! This turned out to be extremely sturdy. Since this monster piece is 4' by 3' wide... it needs a solid base.
Step 5: Step 5 - It's Hammer Time...Err... Pneumatic Nailer Time
Here comes the fun part! Nail gun time! Yes I work with Ryobi, but I freaking (yes, I said freaking like a 12 year old) love my AirStrike nail gun. It's like going from a corded phone where you're tethered to the wall in that room, to a cell phone. FREEDOM! (sung like George Michael or yelled like William Wallace)
In addition to the 1" brad nails I'm also using wood glue. Don't just rely on the nails to hold this thing together. I do use my Rockler glue applicator to smear it all smooth, but you don't have to.
You will notice there's a slight overhang on my pieces, remember that was intentional so I wouldn't have to be exact with my cutting earlier nor would I have to remember exactly which piece went to which side of the panel. I might be lazy... but it also means I try to make my life easier.
Step 6: Step 6 - Trim the Fat
If you take anything away from this entire tutorial I hope it's that you realize how much training goes into being a competitive endurance tickling champ... or how to avoid tear out when you're using a saw. Experienced DIY'ers probably cringed when they saw (ha!) I was going to use a saw on a piece that already has a finish on it. Tear out is when the saw blade causes little splinters at the edge of your cut. Which means it shows like crazy when that surface has been painted.
You might notice the piece has added a fashionable blue belt to it's outfit. That's actually painter's tape to protect the surface. Pair that with a saw blade with 40 TPI (teeth per inch) and you can kiss your tear out goodbye. In the picture above I'm just lining up the blade, but I actually use that scrap piece as a guide for a straight cut.
Use the tape and guide method on all four sides and then...
Comes the MOST satisfying reveal. Pulling tape off is almost as fun as peeling glue off your hands. It's worth mentioning though you need to make sure your paint is fully dry or you're just going to peel it off too.
Step 7: Step 7 - Living on the Edge
You have two options for finishing off the piece and both look good. I personally like the piece without a frame. With the pancaked plywood between the support 1x2's and the planks on the top, the circular saw method makes for a smooth edge that you can leave as is.
I actually ended up adding a stained frame around this piece with 1x3's with mitered corners to meet the client's needs, but the pieces looks good either way. The frame also adds stability, but it gives an already heavy piece a little more junk in the trunk. Yes, I said those jeans made my wood mosaic look fat.
That's it! You're finished! Set it on a mantle, hang it on a wall, turn it into a table. Enjoy it. And then plan your next one because they are so fun to make!
  • IoT Challenge
    IoT Challenge
  • Fandom Contest
    Fandom Contest
  • Party Challenge
    Party Challenge
8 Discussions
frosso89
2 years ago
I wish this tutorial was made in January, while I was making mine :) (I still have to make a frame for it).
I didn't use plywood or a nail gun (I don't have one) . I was afraid that the nail holes would be too visible, but yours turned out cool :)
LazyGuyDIYfrosso89
Reply 2 years ago
Yours looks fantastic! I was worried about the nail holes too, but they are small and I made them uniform so you really don't see them.
LazyGuyDIYevanandkatelyn
Reply 2 years ago
Awesome! Do it! They are extremely easy to do. You'll be ready for the next one before you even take a picture of your first. Ha!
