Object Tracking Robot
53,183
419
102
About: Hi, my name is Nikodem Bartnik. I'm 19 years old. I am into designing, making, programming and electronics. In the future, I want to start a company and make my own products. As for now, you can find my work...
Few weeks ago I thought to make robot that can track object with android phone. At the beginning I searched about it in google. I found some articles but none had source code of android app. My first thought it's "it too hard for me" and I gave up. But I could not stand that I can't make something that I want. So I tried again and after week of hard work with android code I finished my project.
Please if you like my project, vote for me in move it contest. Thanks!
Step 1: Parts
All parts (without smartphone) costed $60:
- arduino LINK TO BUY
- smartphone with android LINK TO BUY
- robot chassis LINK TO BUY
- cables to connect it
- H bridge for DC motors (I use pololu TB6612FNG) LINK TO BUY
- bluetooth module HC-06 LINK TO BUY
- If you want to do PCB go to step 4
Step 2: How Does It Work?
The best way to make it, it's to use android phone with special app which check view from camera recognize position of red color and sends it to arduino over bluetooth. App uses openCV library to image processing. It calculate arithmetic average to check where is red color. Below I added piece of android code to see how it work:
bitmap = Bitmap.createBitmap(mRgba.cols(), mRgba.rows(), Bitmap.Config.ARGB_8888); Utils.matToBitmap(mRgba, bitmap);
int x = 0;
int y = 0;
int all_x = 0;
int all_y = 0;
while(x < 176) {
while(y < 144){
int pixel = bitmap.getPixel(x, y);
int redValue = Color.red(pixel);
int blueValue = Color.blue(pixel);
int greenValue = Color.green(pixel);
if(redValue > 200 && blueValue < 70 && greenValue < 70){
points++;
all_x = all_x + x;
all_y = all_y + y;
y++;
x++;
y = 0;
y = 0;
x = 0;
x_center = all_x / points;
y_center = all_y / points;
Step 3: Connection
Above you can find schema with connection. In next step I added .sch and .brd file from eagle.
I added some jumper wires on the top of the H bridge to do PCB.
Step 4: PCB (optional)
Needed parts to make PCB:
- Everything that was mentioned in first step
and
- Atmega 8 or 128 or 328
-resistor 1,2 K Ohm
- LED diode (no matter which color)
- linear stabilizer with 5V output
- some female headers
- everything to do PCB read here
- Driller, soldering, etc.
Step 5: Program for Arduino
Arduino code is very basic. It gets data from serial and change it to numbers.
String bluetoothRead, Str_x, Str_y, Str_p;
int x ;
int y ;
int points;
int length;
int pwmMotorA=11;
int pwmMotorB=10;
int ForwardA=8;
int BackA=9;
int ForwardB=6;
int BackB=7;
void setup() {
Serial.begin(9600);
pinMode(pwmMotorA, OUTPUT);
pinMode(ForwardA, OUTPUT);
pinMode(BackA, OUTPUT);
pinMode(ForwardB, OUTPUT);
pinMode(BackB, OUTPUT);
analogWrite(pwmMotorA, 140);
analogWrite(pwmMotorB, 140);
void loop() {
int i=0;
char commandbuffer[200];
if(Serial.available()){
delay(10);
while( Serial.available() && i< 199) {
commandbuffer[i++] = Serial.read();
commandbuffer[i++]='\0';
bluetoothRead = (char*)commandbuffer;
length = bluetoothRead.length();
if(bluetoothRead.substring(0, 1).equals("x")){
int i=1;
while(bluetoothRead.substring(i, i+1) != ("y")){
i++;
Str_x = bluetoothRead.substring(1, i);
x = Str_x.toInt();
Str_y = bluetoothRead.substring(i+1, length -1);
y = Str_y.toInt();
Str_p = bluetoothRead.substring(length - 1, length);
points = Str_p.toInt();
i = 1;
Stop();
if(x < 40){
Left();
if(x > 140){
Right();
if(x < 140 && x > 40){
if(points == 1){
Forward();
if(points == 0){
Stop();
if(points == 2){
Back();
void Left(){
digitalWrite(ForwardA, LOW);
digitalWrite(BackA, HIGH);
digitalWrite(ForwardB, HIGH);
digitalWrite(BackB, LOW);
void Right(){
digitalWrite(ForwardA, HIGH);
digitalWrite(BackA, LOW);
digitalWrite(ForwardB, LOW);
digitalWrite(BackB, HIGH);
void Forward(){
void Back(){
void Stop(){
Step 6: Android App
Instruction how to install app:
1. the first step is download FollowBot.apk file
2.Send apk file to your phone
3.Open file manager and find FollowBot.apk file
4.Click on it and click install (if you have enabled the option to install applications outside the google play you need to turn it on)
5.You have finished the installation, you can run the application
Step 7: Android App (source Code)
Bellow I added source code of my app. This app uses simple bluetooth communication to send data to arduino. OpenCV library is very simply, at the beginning I had some problems with use it but I read about it on internet and easily understood everything. If you have problems with understanding the code, leave comment or send PM.
Step 8: Conclusion
So at the end I can say, that my project works great and that my first thought: "it's too hard for me" was very, very bad.
Any comments welcome. If you have problems, leave a comment and I will try to help you.
Sorry for my English :)
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
102 Discussions
DINOBLADER
Question 2 months ago
App keeps crashing on all devices I tried. What do I do??
ebag1010
Question 11 months ago
Hello, I was also wondering about the connection between the Arduino and the Motor Control. If you could assist in anyway that would be great. Any other information regarding the connection of the compenents would also be appreciated. (I'm not using a PCB) My email is ebag1010@gmail.com, thanks.
AhlemK
Question 12 months ago on Step 7
please how can i edit the code source on android studio?
AmnaA16
12 months ago
Hey
What’s the value of R2 ?? In the diagram
saif102
12 months ago
hello mr Nikus the APK application is not working can you help me to solve this problem because it is very important step for my senior graduation project in order to accomplish it .
AhlemK
1 year ago
I just realized my project of the end of the year, a robot object follower (red color), I am interested in your project , first, how can i implement the application code in android studio? and the second if i use shield to control the engines how will it be the arduino code?i'm very grateful
BikashK18
1 year ago
Hi! Nikus. You have been an inspiration to me. And I have been trying to use the same method for object detection for a while now; I guess I haven't search hard enough. But, I would be very grateful if I could know how to modify the opencv program to detect bright colors with a predetermined maximum cross-section area so that it could ignore the background. Also, I would like to know where to write the code and how to link with the arduino mega 2560. I would be indebted to you. Please contact me at bikashkangabam2@gmail.com
YeT7
1 year ago
Hello, I am trying this project and i can't download the android source code. Would you kindly email me the android source code. My email is "yelintun1996@gmail.com". Thank you so much.
Ryuuaoi
1 year ago
How do you know if the robot is working? I think I have everything set up and the code downloaded but I don't know how to work it. Please help me. Thank you very much!
Ryuuaoi
Question 1 year ago
Hello, I am trying to do a similar project and was just wondering what the hook-up is with arduino uno and a hb-25 motor control. Can you help me? Thank you so much. My email is rachellinwarren16@gmail.com
Doni MartG
1 year ago
Hi nikus. i want to know what 7000 mean in android code
int direction = 0;
if(points < 7000){
//forward
direction = 1;
}. thank you
iozsi
1 year ago
Hello. I noticed that you do not use external quart to mount. Does it work with internal? How did you load the code on atmega? Thank you.
stark jose
1 year ago
Sir I did everything as you said but the app isn't working
Why?
AmalB14
2 years ago
sir,
can you please explain logic of how the car is turning using arduino program i can understand the logic
please please help me
TirtoW
2 years ago
Thanks Nicholas , it's chase red object , need bright red or enough light for camera to recognize and follow ..when I move the red object , my robot make cirlcle move, like trying to find the object . I was using promini and powering all boards with 5v ubec & 2s lipo
NikusTirtoW
Reply 2 years ago
Congratulations! It's nice to that somebody made my project. Thanks a lot for picture!
z_huma
2 years ago
hi Nikus, can i track a shoe so it can follow a human being..
hoping for your reply.
