Oil FIlter Cutter
3,439
18
10
Why cutting the oil filter open?
It's an standard procedure especially in aircraft or racing engine maintenance. After opening the filter you gain access to the filter material and you can inspect it for any signs of metal pieces/filings and assess internal condition of the engine. If any, the metal particles will be small, that's why it's important to not contaminate the inside of the filter while opening it using i.e. angle grinder.
There are specialized oil filter cutters available on the market but they aren't cheap.
It's quite a simple tool, so I've tried to make one myself.
Based on https://bobistheoilguy.com/forums/ubbthreads.php/...
Tools used:
  • MIG welder
  • angle grinder
  • drill
Parts:
  • cutting wheel
  • 628 ZZ bearings
  • engine valve stems
  • spring
  • piece of small steel tube
  • bolts, nuts and washers
  • random bits of scrap metal
Supplies:
Step 1: Support Rollers
Size of the side brackets was precisely eyeballed.
I've used old engine valve stems as bearings axles - they were 8mm in diameter and fit perfectly inside the bearings.
Everything was spaced with thick washers and drilled out nuts.
I've tacked the axles in place and boxed the side brackets.
Step 2: Cutting Arm
Two flat bars create a pivot arm with cutting wheel sandwiched between them.
A threaded rod and butterfly nut is used to press the cutting wheel to the filter.
The spring was used to provide additional tension during cutting.
Step 3: Cutting Wheel
First cutting wheel did not do the job.
It had an integrated bearing, but the angle of the blade (~90 degrees) was too big, it was leaving an indentation instead of cutting the sheet metal.
The second one had narrower blade, it was also a bit bigger so I had to drill new hole for the axle.
Step 4: Final Touches and Testing
I've changed the pivot arm bolt for a longer one and added small piece of steel tube - it made rotating the tool much easier.
It still needs some additional changes like
  • handle for easier filter loading - it's hard to grip and compress the spring
  • some kind of retention bracket for filter - support rollers and cutting blade are not perfectly in line and at first it cuts a spiral
But it works!
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    10 Discussions
    batvette
    1 year ago
    Hopefully this will enable more people to get on youtube and cut new oil filters apart then use their useless unscientific observations to declare how lousy fram oil filters are.
    You know the ones.
    That said I bought my first Wix filter the other day, it looks impressive. If only the oil cared.
    RzooqToga_Dan
    Answer 1 year ago
    Yes, it's a replacement wheel for brass/copper pipes cutter.
    I hope it won't get dull quick while cutting thin sheet metal.
    The first one was from bathroom tiles cutter, but it didn't work well.
    NeilRG
    1 year ago
    As Ed Norton said to "Chef of the Future" Ralph Cramden, "Can it core a apple?"
    Nice build.
    gm280
    1 year ago
    I totally understand what you made and I think it is a clever idea and construction. However, why cut used oil filter apart anyways. Seems a really messy job, and I honestly can't think of any good reason myself.
    Rzooqgm280
    Reply 1 year ago
    I think I've answered your question in response to Laspiblov question below :)
    RzooqLaspiblov
    Reply 1 year ago
    LaspiblovRzooq
    Reply 1 year ago
    Thank you very much for your explanations.
    cordially.
    Alex in NZ
    1 year ago
    Neat! A nice little tool.
