Oil Lamp From a 35mm Film Canister
7,860
23
22
About: Hmmm, I'm a Junior in highschool and am in the marching band. I like to fiddle with stuff and find out ways to control fire.
A long lasting oil lamp that can be made for free from parts found around the house
Step 1: Items
Okay you should be able to find all these parts around your house so it will be free
1. A 35mm film canister- I used a clear one so i could see the oil level
2. Fuel of some sort- Alcohol or oil, i used canola oil because it burns better and clean
3. A real cotton ball, cant be synthetic
4. Aluminum Foil
5. Sharp scissors
6. A source of fire
Step 2: Hole Punching
Punch a small hole with your scissors then cut a hole about 5 mm in diameter
Step 3: Making the Wick
Okay your going to make the wick now
Get your cotton ball and unravel it
Then start tearing a 3/8 in peice off
Lastly get the cotton and roll it between your fingers to make it a thick string
Step 4: Making a Heatsink
Fill the canister in oil, don't use vegitable oil because it doesn't burn good, about 5mm from the top.
Pull wick through the hole
Then you got to get your foil and get 4'x4' square and fold it over and over so u get the foil having 4 layers
punch a small hole just large enough for your wick in the foil a put it on the canister
You now have a Oil lamp that has a heat sink
Be sure to keep your wick about 1/4' long ne longer and black smoke will appear
You can also mix salt with the oil to make it burn brighter
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    22 Discussions
    blodefood
    11 years ago on Introduction
    The canola oil is good and very safe. If knocked over, it would likely self-extinguish. For this reason, I would not recommend alcohol for this project as it can be quite dangerous. This is a neat project and practical in case of power outage or for some inexpensive lighting options. Just a note about film canisters: NEVER, EVER use them for food applications! The silver nitrate from the film stored in them will leach into the food and could poison you.
    salanblodefood
    Not my post but it says it al so copying to this thread.
    Hi,
    I though some of you may be interested in seeing what Kodak have to say about the use of those canisters for other purpose than storing film. In a nutshell, there is no risk whatsoever with toxic leakage from the plastic, it seems to be pretty safe, altough they explain the plastic use is not FDA approved for food (this is in the States), there has never been any problems reported to the compagny.
    You can find the complete information here:
    http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=4205&pq-locale=en_US
    acer73blodefood
    Reply 11 years ago on Introduction
    Yes isn't the silver nitrate the crystals that change from the light touching them
    snook123
    9 years ago on Step 2
    you could shoot the lid with an airsoftgun
    knektek
    thanks for this instructable ( cuz i just wasted about 1litre of cooking oil) ...
    ert
    actually vegetable oil works perfectly
    Kryptonite
    10 years ago on Introduction
    I just made this, for cooking i believe Canola oil is the worst possible substance next to sionide, so I don't have any in the house. I felt pretty outta luck so I tried peanut oil, just a tip, don't. Either my cotton's not really cotton or peanut oil just isn't suitable, and I'm thinking it's the latter. Any ideas on methylated spirits?
    Nablec
    May I suggest adding some aluminum foil on the inside and on the bottom for a heat sink of sorts.
    acer73X_D_3_M_1
    No its burning the oil, I wouldn't let it stay lit for more then a few hours though because it will get hot.
    acer73X_D_3_M_1
    well then this wouldn't before you When i light it and leave it for an hour the only thing that happens is the plastic gets a little soft.
    pyro 45.5
    11 years ago on Step 4
    I cant exactly tell, do you fill the canister to the top, or half way, ect.?
    pyro13acer73
    i made one with alchohol and alot of salt and it works great, tho u do have to wipe the salt off the wick top every 30 min or so
