One Dollar Rubber Stamp
943
19
6
I wanted a rubber stamp that looked good and didn’t cost much. I am not much of an artist with an X-Acto knife so I tried something I haven’t seen done before. The premise is to print a mold and squeeze a rubber eraser into the mold. Nothing outlandish. Fortunately this method doesn’t require anything sharp so it is safe for kids.
You will need:
  • 3D printer or laser engraver and media
  • Polymer eraser
  • Sturdy clamp
  • Block of wood at least as large as the eraser
Erasers cost less than one dollar at the art stores but I had perfect results with a four pack of polymer erasers from a dollar store. Printer filament isn’t free but even then the rubber stamp should not cost more than one dollar. Plus, after you have a mold printed you can make unlimited stamps from it for $0.25 each. You can make an entire alphabet for $6.50.
Step 1: Print
Some images are animated.
Download the files from this step or from Dropbox.
For this example I have included a stamp with my emblem.
I have also included an OpenSCAD file for rendering the Instructable’s robot as a stamp mold. This should help anyone who wants to make a custom stamp.
The OpenSCAD file, robotStamp.scad, imports an image, robotCropped.png*, with the surface() function and sizes it with the scale() function. It is important that the files be saved in the same location. The Dropbox file puts them in the correct order for you. Add your own PNG image by copying the file in to the same folder then changing the file name to match. Now you have a custom mold.
Print the file at a size no larger than the eraser.
*I got this image from here.
Step 2: Boil Water
Boil two cups (0.5 liters) of water. Add a pinch of salt if you are heating water in the microwave.
We want to be able to completely submerge the eraser. Use more water for more erasers.
Heat the eraser for at least five minutes. The water doesn’t have to be boiling during this time.
Step 3: Clamp
  1. Shake water off the eraser. Use chopsticks, or better yet, tongs.
  2. Place the hot eraser on a table.
  3. Place the mold on the eraser so that the mold will make an impact on the eraser face.
  4. Place a piece of wood over the mold.
  5. Clamp the pieces together as tightly as possible. The hot eraser will flow into the mold and take its shape.
  6. Allow the eraser to cool while clamped. This make take some time, I recommend letting it cool overnight.
Step 4: Make Prints
Remove the clamp and reveal your new rubber stamp. You are ready to test.
Cheap stamp pads can be found at dollar stores which are little more than ink soaked pieces of cheap foam. But they work.
If your eraser bulged over the edge of the mold it will be problematic and leave marks on the paper. Fortunately erasers can be shaped just by rubbing paper on them. You still don’t need a knife. Just rub paper over the offending bulge and it will erode the way erasers are meant to erode.
Step 5: About Me
Thank you for reading. I write incessantly at my blog, 24HourEngineer.com
You can find this project there including the parts I messed up and how I mistakenly printed the mold backward thinking it was a good idea. There are some projects with 3D printers and some without. There are some projects with programming and some without. There are some projects with only simple tools and some without. All of them have lots of pictures, even the parts I mess up.
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    6 Discussions
    nax
    3 years ago
    I think I'm going to try this, but without the 3d printer step (because I don't have one) using coins or wire or maybe cut shapes out of mat board or ... I'm going to let this brew in my brain for a while, and I'm sure more ideas will come to me.
    And when I have a math class to teach (I'm studying to teach math, grades 5-12) this could come in REAL handy. Each kid could have his or her own name stamp for homework, or we could use them to make quick little graph forms on plain paper.
    24Engnax
    Reply 3 years ago
    Oooo, I like the idea of using wire to form symbols. Since you mentioned graph pads, a lot of old paper cutters, the ones with a giant blade on the right, have surfaces with the grid cut into them. It may be too fine to accept an eraser but it might work.
    Good luck!
    jeanniel1
    3 years ago
    OMG - so easy! I've always wanted to make more rubber stamps, after taking a class in graphic arts in high school (eons ago). Now I can do it without dealing with bakelite!
    24Engjeanniel1
    Reply 3 years ago
    Absolutely. Let's see what your skills produce.
    Uncle Kudzu
    3 years ago
    Wow! That's a great idea! I sometimes carve vinyl erasers, but your method would never have occurred to me. Very impressive result. Thanks for sharing this!
    24EngUncle Kudzu
    Reply 3 years ago
    Let us know if you make something cool!
