Origami Rubiks Cube Stand
4,120
28
quick and easy custom Rubiks Cube stand
Step 1: Materials
-8 cm square paper
-Decorations (optional)
Step 2: Lets Get Started!
first make two diagonal folds from corner to corner. Then unfold. Your paper should now have an x all the way acroos your page
Step 3: Folding Step 2
ok, now start with the right edge and fold it to the center of your page. when you unfold the page should still have an x but now it also should have a line on the right side.
Step 4: Folding Step 3
Repeat the last step for the top,bottom, and left side. now the page should have an x and a square. Flip over the page
Step 5: Folding Step 4
fold the page in half down the middle. Only crease half way down. use the picture as reference
Step 6: Customizing
after you make the crease begin to push down on the crease. as you push down two sides should come together. Note: if you want to decorate now is the time. The purple area is what will end up being the sides. you can write your name or put whatever you'd like
Step 7: Review
here is a top and bottom view
Step 8: Form the Pyramid
Flip over the stand. you should now have a pyramid shape and at the bottom there should be a flap. fold the flap over to secure the shape
Step 9: Final Step
Flip the stand back over again . at the top it should come to a point. carefully push down on the point until you reach the creases
Step 10: Finish
finished! Just like that you have a cool custom Rubik's Cube stand.
Makerspace Contest
Fourth Prize in the
Makerspace Contest
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    2 Discussions
    AnneA60
    3 months ago
    Thanks I was looking for a stand for certain sized rocks in our rock collection, and this is best I’ve seen. I modified a little: the inner square (before you collapse to triangle) is folded from thirds. The sides of the base are folded at eights and quarters, tucked under and corners hidden.
    JustPureLincoln141
    1 year ago
    Thanks! It was very effective in organizing my cubes!
