Overhead Bookcase
So you have a shed, or a treehouse, or even a finished home.
You also have a lot of books.
You can't put more books on the walls because the walls are full, or it's a small building (shed, treehouse), and space is at a premium.
What about
bookcases
on the ceiling.
This sounds silly.  But the ceiling is one of the last unused spaces in a building, books don't take up space you'd otherwise be using if they're there.
Here is how to put books on your ceiling.
Step 1: Preparations
Materials:
Wood, or other building material (you could use clear, hard plastic, or glass if you figured out how, to make it better).
Screws, nails, etc.  An attaching thing.
Books (or cds, dvds, etc).  Sorted basically by size.
Rafters, joists, etc make it easier to mount.  If you're trying to find studs under sheetrock, it'll be harder.
Tools:
Drill/Screwgun.
Drill bits.
Hammer (if you end up using nails).
Tape measure.
Environment:
Semi-exposed rafters, as you can see that I have, make this job pretty easy.  Floor joists, as visible in a post-and-beam house, would work well as well.  A flat ceiling will take a little more work, especially if you don't know where things can be securely fastened.
Step 2: Basic Idea
We're going to cradle the books as follows:
The books will be tipped.
One "stick" of wood goes under the bottom of the book.
One "stick" of wood goes along the spine (unless you have very tall books or wildly different size books in one case).
These pieces of wood are attached by secondary pieces of wood to a rafter, on both ends.
The rendered images are cutaways, and not actually how I attached it either, they just give the general idea.
Step 3: Begin
Remember to hold the book of whatever size case you need right up in the workspace frequently.
I was able to attach my bottom cradle piece directly to the rafters in a couple spots.  You probably won't be able to.
You need to hold the book in place with one hand and with the other, measure how long your attachment pieces need to be.
Then cut and fasten them.
I ended up using nails to fasten to the rafters, as my drill was almost out of battery.
Step 4: The Cradles.
Once the attachments are in place, attach the cradle pieces using whatever method you see fit.
Step 5: The Books!
Put in your books.
Now, this is kind of like an igloo - it only works when it's done.  You should probably have all your books near at hand, because one book won't stay in the case by itself - it'll fall out.  The bookcase needs to be full.  Just hold one hand to the side of the books while you fill it.
In the previous incarnation of these bookcases, I used a weak bungee cord as a bookend, looped around the cradles.
Step 6: Additional Cases, Info
Oh, and make sure, if you're doing one case right on top of another, that you have room to get your books out.
One of the great things about this is that you don't have to make them all the same way.
My first case, as you can see, has attachments on the insides of the rafters.
But after that, sometimes it makes more sense to put the attachment pieces on the outside of the rafters.
Or one each way.
Or attach directly to to another cradle.
Whatever!
Also:
I have one case with deep books in it, of varying heights.
It has two spinal cradles.
Future:
For a more finished look, also a look where the spinal cradle does not get in the way of reading the title of a book - maybe a short, wide piece of glass, or hard clear plastic?
Or instead of a 1x1 wooden stick, a thinner metal rod?
Attachments could be via chains/ropes if the ceiling is high!  You could even have the cases set up so you could raise or lower them that way.
    • Weaving Challenge
      Weaving Challenge
    • Paper Contest
      Paper Contest
    • Pocket Sized Contest
    3 Discussions
    Finally a way to add bookshelves to our treehouse.
    We have a lot of books on tree houses, and it would be good to have them inside.
    Bravo.
    Simple + Sensible + Useful = Brilliant.
    gwylan
    7 years ago on Introduction
    Very sensible, I think! Of course, I've been using ceiling bookshelves for some ten years now myself. My house is very small, and I'm a book-lover, so I really had no choice.
    My situation is different, however, so I used a different theory. My shelves are simply boards suspended from the bottom of my bed loft, using loops of baling twine attached to eye-screws, one shelf on either side of each crossbeam. The twine shows no sign of wear (I am knocking on the nearest piece of wood as I write this, of course) after all these years. I do occasionally have to straighten the shelf holding the big books, which stick out beyond the 5.5" wide shelf board and tend to tip it outward. Total cost was near zero, as both boards and twine were salvage.
    It's nice to see someone else's take on the problem.
    caarntedd
    This is pretty cool. I have no need for it, but I might just do it because it looks good. It should be easily adaptable for lots of other stuff besides books. Thanks for sharing.
