Ozone Generator
45,228
251
54
About: Hi, my name is Britt Michelsen, I'm a Chemical Engineer especially interested in Computational Fluid Dynamics. To balance all the theoretical work I like to make stuff in my free time.
At some point last year my car’s air conditioning unit started to develop a bad smell, which is a sign that mold has formed on the evaporator. Unfortunately, this part is hard to reach and cleaning the evaporator coils is hence a big problem. I went through a set of commercial climate control cleaning products and found most of them pretty useless:
1) Two different disinfectants in spray cans that are sold as climate control unit cleaners: The spray cans are easy to use as you just put them into the car and let them spray their content while the ventilation is running. Unfortunately, the smell was back two days after their application. I guess the sprays are a combination of a perfume (they leave a strong lemon-like smell in the car) and am mild disinfectant like isopropanol. The latter one is not good for killing mold if it reaches the evaporator at all.
2) A spray can with a long tube to spray disinfectant and cleaner directly onto the evaporator. This is actually a pretty good system and preferred by most workshops due the simplicity and easy application. It actually removes organic matter from the evaporator and typically protects it with a good fungicide. However, you have to be able to reach the evaporator with the tube which in my case sadly wasn't possible. It would have meant a lot of extra work to make it accessible. Also, the ventilation shafts are not cleaned by this method.
Talking to a mechanic I found out that some workshops use ozone generators to deodorize such cars. They use it also to remove cigarette smells or other unpleasant odors. Due to its gaseous state, short lifetime and exceptional reactivity ozone can reach the radiator, reacts with the mold (killing it) and vanishes without a trace after some hours. As professional ozone generators and cleaning services are pretty expensive, I decide to build a simple ozone generator from cheap available parts.
So should you have a smelly room, car or van simply build your own ozone generator.
Step 1: DISCLAIMER
1st: In this instructable you are going to work with dangerous voltage (110/220 V up to several kilovolts) to create Ozone which is a hazardous substance. Make sure to always use a ground fault circuit interrupter during building, testing and using the device. Also, make sure that all metal casings are properly grounded. If you are not sure, I strongly advice to use a portable GFCI plug like this one to keep yourself from harm.
2nd: Ozone is a very aggressive substance which irritates and damages the eyes, throat and respiratory system at already very low concentrations of 1 ppm (0.0001 Vol-% or 2 mg/m³). Luckily, the substance has a very characteristic odor and the odor threshold for humans is below 0.1 ppm. This means that you will smell the gas well before it reaches dangerous concentrations. NEVER run the generator in an enclosed space together with living animals (including yourself, your pets,…) and ventilate the room for several hours before entering it again.
Step 2: What Is Ozone and Where Does It Come From?
Most of you probably mainly know ozone from the so called ozone layer, a naturally occurring layer in our atmosphere that protects life on earth from UV radiation.
Ozone is a molecule build purely from oxygen atoms. But in contrast to our “breathable air” oxygen (that consists of two oxygen atoms) ozone is built from three. Chemists call this difference in atomic constitution an allotropy. Although this difference sounds insignificant at first, the ozone molecule is much more active than our “standard” air oxygen. Also, Ozone is metastable, which means that it is energetically favored to dissociate according to the following equation:
2 O3 → 3 O2 ΔHf0= -286 kJ
To give you an idea of this value: The decomposition of 2 mol O3 (96 g of ozone) alone (not including any heat from reaction of ozone with other substances) is enough energy to heat 1 kg of water from 10°C to 80°C.
Step 3: The Science Behind It
As described in step 2 ozone is not a very stable substance that can decompose without any other partner into oxygen. Consequently, ozone cannot survive very long under ambient conditions and cannot be stored without major obstacles. To use it, it has to be generated on spot.
There are three major sources for ozone:
1st ) In our upper atmosphere ozone is build up by irradiating oxygen with energetic ultraviolet radiation. The highly energetic radiation cleaves the O-O bond and forms two oxygen radicals that react with other oxygen molecules to ozone. You can find a lot of detailed information about that on Wikipedia. You can buy UV based ozone generators mainly to disinfect water (e.g. here), but for our intended purpose of deodorizing a room the amount of ozone is typically too small.
2nd) In the presence of nitrogen oxides and volatile hydrocarbons ozone can be build up in the lower atmosphere, which is (in contrast to upper sphere ozone) harmful for humans, animals and plants. This phenomenon is typically known as “summer smog”. NO2 (which can be formed e.g. in combustion engines, fired heating systems,… ) is decomposed by UV radiation into NO and ozone.
NO2 → O + NO
O2 + O → O3
This process would essentially be completely reversible, however, in the presence of hydrocarbons (e.g. only partially burned fuel) NO is converted again into NO2.
R-CH3+ 2 O2 + 2 NO → R-CHO + 2 NO2 + H2O
With better combustion engines and exhaust catalysts the emission of hydrocarbons and NO2 (and hence also summer smog) has been drastically reduced.
3rd) Electricity: Do you know the smell of an old laser printer when operated? You will get the same near an electric arc or near a place where lightning struck during a storm. All have in common that high voltage is used to ionize the air. During this process large amounts of ozone can be generated. Most of the electrical ozone generators do in fact not use electrical arks (as those are bad to handle and lead to rapid material degradation) but corona discharges. Again, you can read a lot about those e.g. on Wikipedia.
There are some pretty impressive electrical driven ozone generators out there. I decide to go with these as they are quite cheap (around $30 and even less if you get them from China), easy to handle and generate an astonishing amount ~ 10 g/hour of ozone. This does not sound like much in the beginning, but keep in mind that for deodorizing cars rates of 0.5 g/h are enough and professional room cleaning generators are aiming for 5 to 10 g/h.
Step 4: Concept and Layout
As you can see in the picture, the layout is pretty straightforward: The ozone generator panels are put into a metal box together with some powerful fans (located in the backplane) that cool the whole system and transport the generated ozone to the outside of the box. A relay board together with an Arduino Uno board are used to control the whole system.
Two 5-position rotary switches are used to set the desired power level and runtime. To save some DIO pins on the Arduino we’ll use a resistor network and the analog inputs to read the switch position. The “start” button is used to start the generator (duh) and some LEDs indicate which panel is currently running and if the fans are on. A “boost” button is used to optionally have a strong start (both generators running continuously for 10 minutes) and a lower ozone formation afterwards. This can be useful e.g. for cars where you want to fill the room with ozone in the beginning and keep it at a lower level for a few hours afterwards.
The generator uses 220V AC for the ozone generator panels and powers a 12 DC converter for the Arduino Uno controller and for the fans. You will find a more detailed electrical layout later in the instructable.
You have to consider three important points in the layout:
1st) The fans need to be powerful enough to cool the O3 generators and transport new oxygen to the generator panels. I used two 80 mm 12V fans for servers. Also the 12V power supply has to be good enough to supply the fans, the Arduino and the relays.
2nd) High voltage (the O3 generator uses a few kV) means that voltage flashovers can occur. Keep cables at least 5 cm away from the panels and if you are using a metal enclosure (I used one for fire safety reasons) be sure to ground every part properly.
3rd) The high voltage generators produce some electrical noise that can be harmful to small electrical components. Be sure to keep the Arduino and the relay board away from the generators. I also found it helpful to put the AC-DC transformer in between those systems as the (grounded) metal case of the transformer acts as a barrier.
Step 5: Drilling the Front and Back Plane
I used metal holesaws to drill the openings for the buttons, the power cable, the air inlets, the LEDs, and the fan outlets into the metal front- and backplane. I found it very helpful to put the metal backplanes between two pieces of wood to keep them from bending and used a printout of my intended design to position the drill.
Step 6: Electrical Layout and Code
I have attached an image of the final layout as a guideline. You can find the electrical layout in the second picture. The Arduino code to control the system is given below.
I have tested the generator two months ago, by putting it into the passenger cell of my car, guiding the power cable through an open window (seal the slit with tape) and turning the air conditioning on. If you have an active carbon based filter in your ventilation system you will have to temporarily remove it since otherwise it will capture most of the generated ozone. After letting the air circulate for 120 minutes while the generator was running on the lowest setting I unpluged the generator (you can also set the timer) and opened all doors to air out the passenger cell. After 4 hours the ozone smell was gone and the whole car smelled as good as new. Until now the moldy smell has not returned.
So if you are having the same problem, give this method a shot.
Explore Science Contest 2017
Runner Up in the
  • Fandom Contest
    Fandom Contest
  • Woodworking Contest
    Woodworking Contest
  • Gardening Contest
    Gardening Contest
54 Discussions
MY FRIEND, TAKE CARE DOING AND USING OZONE O2 or O3 .... CLASS OF BASIC CHEMISTRY: Oxygen is the common element to react in the RED-OX chemical reactions making this in this way a very corrosive agent. I had long time ago one of those and everything that was metal got rust and rusted all staining and completely damaged.... It is too dangerous too for our lungs in high And lots of exposure to this Chemical Compound.... Try to use a little doses, no more please... The project is cool, but watch it my friend!!! : D
He said that at the very beginning, "Friend". and OF COURSE HE IS NOT GOING IN A CAR FULL OF OZONE!!!
Ozone is a an energized oxidation molecule !
As such it will prematurely age Art paintings and ancient manuscripts which is why it is so good at rapidly eliminating offensive odors (Excepting cat urine)..
Also, while I'm at it, I was just thinking that a whole home unit that could be installed in the A/C & Heat air intake for the whole house. I wish there'd been an instructable for something scaled to general usage.
How would someone modify this to make a simple ozone generator for the home, like the ones that can be bought in the store. I guess since it can be ramped down, I'd have to research the specs for safe ozone levels, it wouldn't need but one generator, and instead of 220, just upconvert from 110 to 220. And I suppose a little math would give us the ratio of output of the O3 IC and desirable levels... it that enough?
oldfatnbroke
1 year ago
Call me a "nit picker" but I can't help it. Its not the condenser that is causing your "stinky" A/C in your car because it is not inside the car. It is located under the hood right in front of the radiator. It is the evaporator coil that is located in the "heater" box under the dash where the offensive smell comes from. What causes the problem is usually leaves and other plant material that gets trapped in the heater box and gets saturated with water when the A/C cooling cycle is used. I'm sure you have noticed the water that drips under cars during warm weather. There is a drain hose with a "flat" end that lets the water escape from the box, the flat end is on it to keep insects or anything else from crawling into it. To clean the trash out of the box you will need to reduce the end of your garden hose as small as you can, 3/8 of an inch (9 mm) is about as big as you need. Drill a hole as high as you can in the box where the evaporator coil is located. WARNING! If you drill a hole in the heater box DO NOT jam the drill into the box or you will damage the evaporator coil of the heater coil! Get somebody to hold the drain tube open, just squeeze the sides so the hose opens and then squirt water in through the hole you drilled in the box and let it drain out through the drain hose. You can use the coil cleaning products at this time. After washing out the box you need to plug the hole you drilled or stick a piece of duct tape over it, if you do not plug the hole you will have air (hot, cold or ambient temp) blowing into the car while it is being driven.
This is not hard to do just be careful drilling the hole!
MimiE091209oldfatnbroke
Reply 1 year ago
Glad you posted this because my head was about to explode with the condenser/evap mixup!
Thank you.
GTO3x2oldfatnbroke
Reply 1 year ago
Was also going to comment that they probably meant the evaporator coil.
nulla.nome
11 months ago on Step 6
Nice write-up! However, if one want the system to stop when the total timer expires, I suggest the following changes to the source code:
1. In function loop() add the line:
if ((systemActive == 1) && (totalRunTime > totalTime)) { Serial.println(F("Total timer ended")); startStopSystem(); }
2. In function startStopSystem() in the conditional statement if (systemActive == 0) add:
totalRunTime = 0;
3. In function dutyCycle() change:
totalTime = totalTime + 1; to totalRunTime++;
Alan25
Question 11 months ago on Introduction
I just recently purchased a 10g ozone generator. Is it possible to use a dimmer switch to control the amount of ozone that is generated?
lolbert21st
1 year ago
It would be cool if we built a giant one to repair the ozone layer
dknape
1 year ago
Great looking and great deign. I am wondering if you could share with me the measurements and source of your project box.
I see your concern regarding providing a parts list but would like to still request a list if you would be willing to share it with me.
BennyOne
1 year ago
Great job! I use a small ozone generator designed for hot tubs to sterilize and deodorize lacrosse equipment. It just has 2 small ports, where hoses are press-fit on. I put the long end of the ozone discharge side into a trash bag with 1 players' worth of equipment and tape the bag closed. Let the ozone pump run for 20 minutes or so, the bag puffs up, and then pull out the hose and shut down the pump. Once the bag collapses over the next hour or so, I year it open and hang up the gear.
Anyone who's ever been near lacrosse or hockey equipment knows how strong the smell can get, but ozone completely clears it up. I can imagine is works perfectly in a car's ventilation system!
CassaniBennyOne
Reply 1 year ago
I was looking at this project to create a small Ozone Generator that would do a single pair of cleats/shoes and maybe a pair of shin guards. I figure that it would only take a few minutes to get the stink out.... If I built to look like a toaster oven (that sealed) it would not take up much space. Thoughts?
BennyOneCassani
Reply 1 year ago
I've thought about building some sort of cabinet too, or maybe using an old fridge. One of the problems with ozone is that its a rapid oxidizer, and any metal connectors or hardware - not to mention the box itself, if metal - will rust very quickly. Maybe make it out of plywood & glue and paint the whole inside with Flex Seal? It sounds like yours would be pretty small and therefore a great test case - build it and post it please!
JeffD51
1 year ago
Very well done! I've made 1 corona discharge plate myself MANY years ago and used the ballast from a neon sign. It was very dangerous but sure cranked out some O3.
My next try was via uv hid lights inside a piece of pvc backed by a pc muffin fan. Those work great, but can't compete w/ corona discharge plates for output. I've seen the exact idea sold as ozone cannons. If you only need to clear the air a little, these may work better for that app., but not for killing molds imo.
JohnC430
1 year ago
ok, i found the "plates" i did not notice the link.
In the winter we have the heating running and in the summer its the cooling so the house is more or less sealed from the outside "fresh" air with the internal air circulating throughout the house, and diffusing thru the closets and bedding and curtains. we cook and the stink permeates every nook and cranny of the house. I open the doors and windows in the evening and thru the night to "air out" the house. I think one of these running at low power for a few minutes after we have our meals will help clear the air after the "peak stink" hours.
BrittLivJohnC430
Reply 1 year ago
Yes, sorry. I decided to not publish a "stuff you need" list like I normally do, since I wanted people to read the whole Instructable before starting to build something that might harm them unless they take precautions.
