PAPER MASQUERADE
827
About: I have a dream & i hope i make it, Its a long way ahead, But someday.. I'm a short film maker, still in the making & i want my work to reach max people I'm a hobbyist, an artist, a craftsman ; My dre...
I am so glad i stumbled across this innovative platform.
This is my first instructable
(And if it helps, when reading imagine J lo's voice)
Someone once asked me, if you could get an unlimited supply of any one thing; what would it be?
I often ponder on this,
But so far the Answer has always been the same:
PAPER
The amount of intricate detailing, fascinating 3d structural aspects or designs that can be done out of a flat sheet is limitless.
And then you get colour,texture, printed,ladden with glitter and sparkle; there's just no stopping you.
IMAGINATION is the key........ There's just no limit.
Go paper cray !!!
Step 1: VISUALIZE IT
Think to yourself what is it gonna be?
Sketch it; Sketch multiple explorations; be creative; have fun.
Step 2: IT'S DECIDING TIME
Give it dimensions according to your model (meet akshada: 12 years old),
And decide on material and colour palette according to your finalized Sketch.
I'm going with the design i sketched just a few days before....i never thought that I'd be doing it so soon.... So on the Sketch i just wrote ONE DAY.... I'm so glad that day came soon :-)
Step 3: MATERIALS
Gather the tools required
And get set go:-
1. Paper lots and lots of paper according to your colour selection and theme.
2. Drawing pencils and a scale.
3. Cutter and a pair of scissor.
4. Craft Glue, glue gun, stapler and pins.
5. Sparkling glitter.
6. Decorational pearls and rhinestones.
7. More paper ;-)
8. Measuring tape.
9. Lace or ribbon and ball chain.
10. Paper tape.
Step 4: BASIC LAYOUT
According to your dress design
Prepare a paper base for the inside which will hold all the parts together
My first attempt was to make a paper cage but it didn't turn out quite that well (image 1: what not to do) .
so i scrapped that and taped textured paper together to make a large piece and cut it in a layout of skirt and again taped everything to make a skirt (image 2: that's perfect)
Step 5: CUT, STAPLE, REPEAT
First draw a unit model.
This is the one I'm working with,
I required 90 Unit models to go all the way around the bottom.
Cut, staple and repeat.
These units are going to make the skirt in layers like petals of a Rose.
Keep them aside while we do the rest of the detailings.
NOTE:
PLUG IN SOME ELLIE GOULDING (music)
cuz it's gonna take some time.
Step 6: THE BODICE
Let's make the upper portion of the dress
Material?? You guessed it; PAPER
Take measurements of your model
Make a demo layout of bodice from newspaper
Make the necessary adjustments
Then finalize it. I kind of just played around with it and tried two bodice patterns
And chose the adjusted fitted one.
Go with your design.
Step 7: THE NECKLINE
My design has a halter type neckline which i want decorated like a necklace.
I used rhinestones, large pearl halves and drop beads.
Step 8: THE REDDEST OF ROSES
Cut 6 circles in decreasing sizes.
Fold each in halve three times.
Cut each in a nice curve to form petals.
Open them up.
Cut segments to have 8, 7, 6, 5, 4, 3, 2(remainder of 5 petals) ,1(remainder of 6 petals) number of petals respectively.
Stick them to form cones.
Curl their petals.
Stick all layers together to form a Rose.
Add a pearl in each to finish off the look.
Repeat in size of your choice and choice of your colours.
Note: time consuming.
Plug in some SELENA GOMEZ (music)
Step 9: THE SPARKLING MONARCH'S
Take coloured papers, Fold in half
On half side Draw the butterfly Outline.
Cut using a pair of scissors to form a silhouette of butterfly.
Then Sketch the intricate detailing.
Hand cut them to form a netted design using a cutter.
Apply glue to the end portions of the wings or as much as you want..... bathe them in glitter i.e sprinkle glitter over glue. Tap to remove excess. Let dry on a book kept open at an incline to give 3d shape.
Soooooo mesmerizing
WE ARE GOING TO KEEP ONE BEAUTIFUL BUTTERFLY ASIDE FOR LATER USE ON A SURPRISE ELEMENT I HAVE IN STORE FOR YOU GUYS !!!!!!!
Plug in some TROYE SIVAN (music)
Step 10: THE SPIRAL ROSES
Cut circles according to size of your choice.
Using a pair of scissors keep rotating the circle while cutting to form a spiral and stop at the end to keep a circular portion, this will be used as the back to glue the Rose.
Pinch the beginning edge and roll while squeezing till you reach the end portion. Then release to let it expand a little.
Stick to the end using glue.
Let dry... You might need to apply a little pressure for a while until it starts to dry and hold in place.
Finish off with a off-white or bronze pearl in the centre.
Repeat in various sizes and colours.
Step 11: THE SURPRISE
I have always been one for dramatic flair, but what is a masquerade without a MASK
Surprise!!!!!
Take rough measurements for your Mask,
And Sketch the design.
Cut a rough prototype and trim as needed.
Cut the edges of the nose and stick using tape to form a protruding or 3d nose,
then when your happy with the outcome stencil it on glitter paper.
Cut it and paste on the paper prototype from earlier to get the 3d form.
Cut out the shape of eyes.
Decorate the mask:-
I used a stone chain to form lower linning of the eye, a black 3d outliner to form the upper lining with a cat eye and to give it a kajal look and a pair of fake eyelashes for increased drama.
I added three golden ball chains using masking tape to hold them in place and glue to stick them to the mask
I ended up tying the 3 of them to give a double curve. And on the other side a ribbon with golden pearls.
On either ends poke a hole and pass a ribbon through and tie a knot.
And finally i topped it off with the butterfly we set aside in step 9.
Step 12: THE ASSEMBLY
Bippity boppity boo !!!
Bring out the big guns; the glue gun and glue on all the parts together onto the basic layout to form a beautiful magical paper dress.
Step 13: ADMIRE THE RESULT
Have a fun photoshoot to commemorate your feat:~
" BEHOLD THE WEARABLE SCULPTURE. "
Paper Contest
Runner Up in the
Paper Contest
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    16 Discussions
    Vapowritejessyratfink
    Reply 19 days ago
    Thank you sooooo much.... I'm very happy you like it xoxo
    VapowriteYogendraS21
    Reply 5 weeks ago
    That means a lot ...... Thank you for appreciating
    snehalvispute61
    5 weeks ago
    Oh! What a creation.Superb. Keep pondering for implementation of innovations.
    seamster
    5 weeks ago
    Well done! Such a clever and creative project, you should be very proud! : )
