PCB Board Holder in 20 Minutes
2,331
52
About: A long time Instructables lurker.. now pleased to be an Instructables worker,...as in; doing instead of doodling. This is easier now that I am 'semi' retired with more time to do stuff. My grandson is bec...
This is a simple but effective design that is a real help in assembling and soldering PCBs.
Supplies:
Step 1: What You Will Need
The idea of this Instructable is to demonstrate what you can put together quickly from easily available parts.
I used a piece of scrap wood as the base.
Two of the rear covers from a PC ( I have dozens of these and always thought they might be useful one day)
A few parts from a cheap constructor set or Meccano ( mine came from two kids sets that I bought in a pound shop)
Some clips ( mine are again from the Dollar store or Pound shop and came in a set of 10)
A few wood screws and a screwdriver should be enough to do the whole project.
Start by screwing down the PC covers spaced the width of your PCB apart.
Step 2: Clip Assembly
I simply bolted the clips onto the arms using the right angle pieces.
You could just as easily use Bulldog clips.
Step 3: Mount the Arms
Using the photo as a guide bolt together the arms, the cross pieces into the supports.
Step 4: Check Spacing
I used a plastic spacer that was in the toy pack as a friction mount.
Step 5: Ready to Use
Just clip your PCB in place.
Step 6: Ready to Roll
Your PCB can now be easily flipped so that you can mount components then turn it to solder.
Step 7: Soldering On
This really is a huge help when soldering.
I hope you can adapt this simple design to your own available parts.
Soldering becomes much easier when everything is securely held in place.
Enjoy
    • Classroom Science Contest
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    3 Discussions
    JodyF1
    1 year ago
    I haven't found clips like that anywhere! Where did you get them? (Bulldog or crocodile clips aren't my thing). Thanks!!
    GregariousJodyF1
    Reply 1 year ago
    If you search Amazon or eBay using the description in my instructable you should find them. They are used for electric racing cars and are often referred to as Tamiya battery connectors. One of the replies to this thread says that there are better ones and so maybe you will find those.
    GregariousGregarious
    Reply 1 year ago
    OOPS Very sorry
    I just noticed that I replied to the wrong question here...my apologies.
    However, most of my wrong reply still applies...
    The clips were obtained from my local Poundshop (Dollar store) and were in the garden section.
    I know that they are generally available online via eBay and Amazon if you search for 'plant clips'.
