POV Arduino Fidget Spinner
13,436
170
25
About: I'm a content creator. I make open source projects and videos for said projects. My goal is to create free and open knowledge for everyone.
I've always wanted to make a persistence of vision device, but never got around to making the usual clock or desktop display. I decided to take it to the next level and install it on a Fidget Spinner. Why not right?
I designed all aspects of the project. It is an Arduino using the SAMD21 MCu, a shift register controlling the LEDs, and some Hall Latches and magnets for encoding the spin. I wrote a simple program to have some fun with it, but I will continue to improve it.
This project required knowledge in surface mount soldering, unless you somehow managed to get me to send you a completed board(Maybe!)
You also need to know how to install a bootloader on the SAMD21(I have another instructable on this) and how to program the firmware using the Arduino IDE. Of course you can just write your own programs if you so choose!
This project is on HackADay.io and GitHub
Supplies:
Step 1: Watch the Video!
Step 2: Get the Parts/Tools!
Parts
Materials
  • Solder Paste
  • Solder Wire
Tools
Step 3: Solder on Components(Warning Surface Mount!)
Add the solder paste, either by hand or with a stencil. I did it by hand as per usual for low quantity boards.
Step 4: Solder on Bottom Components
The bottom components can all be done with a soldering iron. They are easy enough. The USB port is a bit tricky though.
Step 5: Program the Board
You will need to add the Arduino bootloader to the board using the programming header. I've shown this in a previous instructable of mine and will not be detailing it here. It is covered in many places online.
After the bootloader is on(I use the Sparkfun SAMD21 Bootloader) you can program the Arduino Fidget Spinner using the program I have pieces together/written.
Check out my other instructable for more info on this: https://www.instructables.com/id/Arduino-YouTube-Play-Button/
Step 6: Test Out the Board
Lets see those LEDs blink!
Step 7: Install Batteries and Firmware
Now its the scary time to put in the batteries and install the firmware using the Arduino IDE. Goodluck, hope no magic smoke comes out!
The Arduino Firmware requires a few libraries. I have included everything in a zip file. There is also a GitHub Repo with all of the files and info: https://github.com/IdleHandsProject/POV_Fidget
Step 8: Assemble Fidget Spinner
First you need to install the small magnets into the cap. Only 2 are required and they need to be right next to each other, with opposing polarities. (NS/SN)
Next Take the circuit board and install it in the 3D printed parts from Shapeways.
Use the plastic threading screws to mount it. Easy enough! Make sure its turned the correct way, the USB only goes through one place.
Step 9: Spin!
Look! It works!
It looks a lot better in person, the camera causes the skipping of the lights, which is not visible to the human eye.
The program I wrote has a number of different modes like RPM and Spin Count. It also goes to sleep when it sits for too long(25 seconds) so it doesn't much power. You need to press the red button to wake it up. You press the blue button to change the current menu option. Some write things, others display metrics.
Step 10: Support These Projects
If you would like to support my projects, Consider subscribing to my YouTube, becoming a Patron, and following on Instagram.
YouTube SeanHodgins
Patreon Sean Hodgins
Instagram
Be informed the moment a new project comes out!
Invention Challenge 2017
Runner Up in the
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    25 Discussions
    ChrisA359
    4 months ago on Step 10
    Glorious tutorial man. So how about sending me a complete board? You would be helping out a fellow Maker who's teenage daughters are breaking him financially...no worries though. Great instructable.
    SimonH36
    1 year ago
    The first Instructable which has inspired me to make something, thanks :) I ordered some PCB's from a low-cost supplier, and they've arrived! Now to order the parts and start assembling. I may try to modify the design to use tri-colour LED's later.
    Note to others - there is no need to use solder paste and an oven for soldering SMT components; Thin solder and a fine soldering tip is all that is required (and a magnifier if you're over 40 like me)
    Alexisgm97SimonH36
    Reply 1 year ago
    Hi! What low cost PCB supplier did you find? Share it with us please!
    SimonH36Alexisgm97
    Reply 1 year ago
    Hi,
    I used "pcbgogo" - USD12 approx for 10 PCB's shipped to UK!
    Alas, I haven't purchased the parts yet though.
    faisyl
    1 year ago
    Thanks for the great instructable!
    I had some questions about the build and BOM. I got the PCBs and used the published BOM. On the PCB, there's an extra LED, Q2 and resistors R13 and R14, neither of which are on the BOM. Also C3 is larger than the PCB pads. C3 can probably be fixe by hand. Not sure what to do about the missing components tho. This is my first SMD build and I want to get it right.
    Ben-DIY
    1 year ago
    Dude, this is awesome.
    First I thought "Hey, cool headline, let's check". Then I saw the beginning of the video and I was "oh, he just assembles something he bought" and in the I was "wow, he created everything, designed the pbc and the body and let it been manufactured on an industry quality". Super awesome! Most of the time you see bread boards or prototype pcb here. This would obviously not work in such a small scale. Sadly I can't solder smd. I don't have the tools, so my circuits are always on normal, homemade pcb. Btw: nice set of tools I can see in the background ;-)
    Anyway: nice work, I like it 120%. You have a new follower ;-)
    MakersBoxBen-DIY
    Reply 1 year ago
    I was a bit intimidated by doing SMD at as well at first. I've got an Instructable project if you want to try just the very basics: https://www.instructables.com/id/I-Can-Surface-Mount-Solder/
    seanhodginsBen-DIY
    Reply 1 year ago
    You can absolutely do SMD components. I know you can. I use a $20 "toaster oven", but I would recommend spending another $20 and get one with convection.
    If you can hand solder, you're just a tube of solder paste and a toaster oven away from making the jump. I would even say its actually easier than TH. You will be absolutely surprised when you try how easy it is. Its very hard to hurt the components/board.
    I've been making SMD boards for a few years now, those cool tools you see? I only got them a few months ago. Before that I pretty much just had a multi-meter(and occasionally steal some time with my works oscilloscope for trouble shooting) and a good soldering iron. Having a good soldering iron helps you fix any problems with the components after reflowing, a cheap hot air station makes things even easier for fixing and would be a good purchase as well. Some things are hard to fix without it. I don't need to use it very often though.
    Ben-DIYseanhodgins
    Reply 1 year ago
    Thanks for your nice words and you trust in my skills! To be honest, I never made any researches on how to solder smd. So from your video it looks like:
    a) put some solder paste
    b) place components
    c) put it in the over (for some time at some temperature ^^)
    d) solder the other parts the "conventional way"
    Is it really that easy? What time and temperature do you recommend? Regarding convection: couldn't you build a metal fan and add it to your oven by yourself? DIY-style ^^
    From tool side I have a upper-medium class soldering iron from Ersa. I could need a good regulated one, but mine has a good temperature for pcb soldering and I have several exchangeable tips. But if it will break one day (already several years old and still good) or I can give it to my kids. I also have a cheap logic analyser and an atmel debugger which is super helpful. I still miss an digital oscilloscope. You have a Rigol, right? DS1104Z, right? It looks like one. How much was it? 600USD? Quite some money... But I really need something similar sooner or later :-) time to save some money ^^
    But first I will check to get into smd soldering. One last question: where do you order your pcb? I know pcbway.com, they are quite cheap (5€ for 10 pc of 100x100mm) but have some shipping costs (up to 5 times pcb costs) to Germany.
    seanhodginsBen-DIY
    Reply 1 year ago
    Its really that easy. The hardest part is not putting too much solder paste, which if you do will need to be removed by a soldering iron after.
    Temperature, my oven is set to its highest setting "240C/450F". It doesn't actually hit that temperature. I turn it on and just watch the boards, after they have all flowed, I wait a few seconds, shut it off, and pull the tray out to let them cool. I normally have a computer fan blowing on them to cool a little faster. I could put a metal fan in, but it wouldn't be worth the hassle and the cost of the fan, since so many models have them for a little bit more money.
    Yeah I recently purchase the Rigol, its only $400 US actually. https://www.amazon.com/Rigol-DS1054Z-Digital-Oscil... quite a good deal and if you feel like it, can easily make it 100mHz.
    I order my PCBs normally from PCBway.com - They're so fast and good quality that its worth the shipping. I normally pay about $5-10 for the boards, and $20-30 for the shipping. Just the way it goes! If you have a few projects on the go at the same time, then you can lump the shipping together. That is what I normally do.
    seanhodginsBen-DIY
    Reply 1 year ago
    ringmasterow
    1 year ago
    This is a great project! How do I make use of the board files you have provided? Where did you print your board? How can it be cut to shape? Too many questions! I'm happy to go through the process of building it all myself, but I have no idea where to start. Can you provide some hints/directions? Thanks!
    seanhodginsringmasterow
    Reply 1 year ago
    The files are meant to be opened in KiCad if you want to change things, the Gerb files/zip file can be uploaded to a place called PCBWay or OSHPark who will make your boards. The board files include an "board edge" file so it will be cut out the way you see in the video.
    If you want to start by trying to make a working board, order a few of the boards, get the components, and start there. Its a bit of a learning curve if you have never soldered(or surface mount soldered) before, but we all start somewhere.
    bratan
    1 year ago
    Great job man! I made my some time in February, but never figured out how to get sync it with magnets and hall effect sensors. Sorry you not the first to make POV spinner, but there were some guys before me as well :) Forget about Kickstarter, there were bunch of similar projects that never got funded :( Appreciate open source!
    Alexisgm97bratan
    Reply 1 year ago
    Cool! I would really like to have the schematics and .brd files! Could it be possible?? Thanks!
    SidA2
    1 year ago
    I always wanted to try and make one of these, but I couldn't figure out how to make the LEDs sync up properly with the speed of the spinner
    AlexanderM130
    1 year ago
    Do you have one set of circuit boards left as you told in the video?
