PVC "2 Shot" Rubber Band Pistol
1,478
11
About: Innovative Projects, Diy's, Life Hacks
In this Instructable, we'll make a 2 shot rubber band gun from PVC pipes.
Step 1:
I put a pipe bending spring in a PVC pipe.
Then I heated the pipe with a heat-gun and bent it. When the pipe had cooled, I removed the spring.
If you don't have a spring, you can fill the PVC with sand, it will also let you bend it without folding it.
You can also use a hot sand, that way you won't need a heat-gun.
Then I cut it shorter.
Step 2:
After heating one end of the pipe, I used a grinding stone drill bit to enlarge the end.
Step 3:
I drilled a hole for the bolt and cut one for the "trigger"
Step 4:
I used a small tube to make a "trigger", After heating it up, I shaped it the way I wanted.
Step 5:
I drilled holes for the bolts and used a rotary tool to make some adjustments.
Step 6:
I covered the bolt with heat-shrink tubing to make it smoother (avoid saw effect)
I applied some grease and put on a spring.
To make sure the nut does not come loose, I glued it to the bolt.
Step 7:
With a help of a small magnet, I was able to put nuts on bolts
Step 8:
I drilled a hole for the bolt.
A cable terminal was used to make another part of the trigger. (I don't know the technical name)
And again, I used glue, so the nut does not come loose.
Step 9:
I made slots for rubber bands
Step 10:
I attached the bolt to the trigger
Step 11:
A larger PVC pipe was used to make a handle.
After heating it up, I squeezed one end of the pipe with a clamp.
After some final sanding, the handle was attached.
Step 12:
Our rubber band pistol is ready.
As said before, it can shoot 2 shots.
Press the trigger to release the first rubber band......press it stronger to release the second.
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
