PVC Back Massager
991
10
About: A community of family fun, DIY, How-to videos, and Homemade creativity. We hope you can get inspired to make new projects, and possibly learn a little along the way.
PVC Back Massager
If you like getting a back massage but it just does not happen often enough, then here is a great tool you can make that will allow you to give yourself a message.
If you would like to see the Video version along with a few other ideas, follow this link: https://www.youtube.com/watch?v=GfRBIHslnjE
Parts Needed: (All 1/2 inch PVC pipe and fittings)
- (1) 6-foot long pipe
- (2) 3-inch long pipes
- (2) Tee Connector
- (4) End caps
Tools Needed:
- PVC Bendit Tool (Found on Amazon: http://amzn.to/2wlDZBK affiliate link)
- PVC Bending Forms ā€“ Homemade (optional)
- PVC cutters
- Heavy Duty Clear PVC Cement (Found on Amazon: http://amzn.to/2wlDZBK affiliate link)
Just remember that PVC is only a form of hard plastic. It can and will break if too much weight or force is applied and injuries can occur. Use of content for personal projects is at your own risk.
Supplies:
Step 1: Bending the Pipe
Bending the Pipe
Using the PVC Bendit tool, I heated the pipe to make it bendable.
I then placed it in a homemade form to allow it to take an almost ā€œSā€ shape.
(You can use other stationary objects to bend the pipe around.)
When it cooled, it retained the shape.
The heating process can be performed with a heat gun, but the end result will not be as nice of a shape.
Make sure to only heat the PVC pipe outside.
DO NOT burn PVC pipe, it is not safe to breathe.
Step 2: Adding Handles
Adding Handles
On the inside of the pipe as it started to straighten, I made a mark on both ends.
I then cut the pipe in half at these locations, making three separate pipes.
Using Tee connectors facing away from each arch, I connected these pieces back together.
I added 3-inch pipes to the Tee connectors for handles.
On the open ends of the pipe, I added end caps for safety.
I then used PVC cement to glue the Tee connectors in place because they kept coming loose.
Step 3: Using the Massager
Using the Massager
The massager is easy to use.
Just grab a handle with each hand, swing one of the arches over your shoulder and begin to rub on your back.
It really feels good.
An additional option would be to add a tennis ball to the ends for added comfort.
Enjoy your Back Massager
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    2 Discussions
