PVC Bicycle Luggage Rack
2,123
21
4
A PVC luggage rack for bicycles that doesn't rely on mounting points on the frame.
Step 1: Background
As you can see from the picture, my road bike does not support bolt on pannier racks. While I could buy rack that would get around this, they are more expensive than I'd like. Given great success I've had in the past with a PVC surfboard holder for my other bicycle, I decided to make a low cost and minimalist as possible rack to hold my camping gear for future bikepacking adventures.
Step 2: Materials Required
32mm PVC pipe (length varies on the size rack you wish to build)
X4 32mm T joints
X4 32mm 90 degree joints
PVC cement
~6m of paracord or other strong non stretchy rope
Step 3: Cut the Pipe to Size
For my rack in particular I cut the pipe to the following lengths (formatting corresponds to layout in the image)
5.5cm
4.5cm 6.5 cm
21.5cm 21.5cm
12.5cm
9.5cm 9.5cm
14.5cm
The non-symmetry is to compensate for the T joint not being a true T
Step 4: Seat Post Mounting Point
It just so happens that the through internal diameter of the joints I was using fit snugly over my seat post.
If you are not so lucky you can either try heating the joint with a heat gun to make the PVC malleable to shape over the seat post
or
cut a slit in the joint to allow it on the seat post with either room to expand over a bigger post or contract over a smaller post. This then can be held in place with hose clamps
Step 5: Gluing the Structures
The first structure is the two T joints joined perpendicular to each other.
Use pencil marks to line up the position of the structure so you can quickly get it in place when gluing as you will not have a lot of time before it sticks.
Paste the inside of the tube with PVC cement and push the pipe in until in position and repeat.
The second structures are the two halves of the rack bed.
Using the same procedure as before, create the two halves as shown in the image.
Step 6: Final Assembly
Apply PVC cement to the bottom two pipes (furthest from the seat post) ONLY.
The connection at the T joint attached to the seat post is supposed to pivot.
Step 7: Attaching to the Bike
Slide the seat post into the mounting point of the rack and then into the bike frame.
Using the paracord, tie around one corner of the rear of the rack.
Thread through the rails of the saddle and pull tight to desired angle of the rack.
Tie off on the opposite corner of the rack.
The remaining paracord will be used to further secure you gear or alternatively you could cut it here.
Step 8: Finished
Check your knots are secure and your done.
The pivot point and stretch of the parachord over your gear acts as somewhat of a suspension when going over bumps.
How you mount your gear is up to you. I will likely cut some tarp to line the underside to protect from dirt and fold over the top to protect from rain.
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    4 Discussions
    Antoinevélo
    1 year ago
    Whaoo, genius and sure ultra light.
    Thanks
    Crucio
    1 year ago
    Pretty innovative design! I'd be interested to know how it holds up over time and how you'll improve it in the future. I wonder, though, does it slide around?
    D.A.NCrucio
    Reply 1 year ago
    Thank you! Yes I agree, I will be taking it on longer journeys as free time arises and maybe a V2 will be in order. As for sliding, when it is loaded it really doesn't. There is a very slight side to side movement but nothing more than I've felt wearing a large backpack. The longer tests will determine if it's a problem though.
