PVC Drill/Tool Holder
8,658
350
9
About: Howdy, I am a bit of a tinker gnome. I like playing with hardware/technology along with making stuff I want out of old stuff I have or find. I should warn you that I am like Dog from "Up". There will be ...
Howdy Instructable readers.
I have moved over to Steemit.
Please follow my future projects over there.
Thank You https://steemit.com/@motinkergnome
2 People Made This Project!
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
9 Discussions
Yonatan24
3 years ago
That's a really good idea! I wish I had enough drills so it would as efficient... ;)
CosmiChild
3 years ago on Introduction
Finally found a way to store some of my tools! I will make it for sure and use skepticaljay's advance.
Thanks a lot for this idea.
ggallen103
3 years ago
would work for hairdressers as well blow dryers, curling irons, etc
dmwatkins
3 years ago
Great idea! Is there anything you could mount to the drill forward of the trigger to keep it from being depressed? I'm sure that would be different for each drill... Or if the drills have the type of direction switch that prevents the trigger from being pulled when the switch is halfway in.... but that would require people to go to oh so much effort when putting it away (sarcasm)
MoTinkerGNomedmwatkins
Reply 3 years ago
Thanks for the concern.... I actually tried to jam it in there with a battery to see if it would start the drill. Yes if forced it will spin however the trigger spring tension was more than enough to stop the drill so I just didn't worry about it. And being pointed in a safe direction even if it spun up with a bit it would not hurt anything.
Now that you mention it the Ryobi drills and drivers both have the halfway directional safety. But I usually keep the batteries in the chargers as they maintain the Lithium Ion Packs.
I laughed at your effort comment.
skepticaljay
3 years ago
I really like this. you could also line them with some foam for a more secure and quite.
