PYRO DETONATOR 2 Igniter Detonator Fireworks Pyrotechnics
73,277
292
187
About: I would really like a lot of tips for my projects Thanks LARS
Device which can detonate or ignite just about anything you want it to. Made for safe ignition of fireworks but with some skills you can make this fine case and put anything you want on the end of it.
Heres the link to the PYRO DETONATOR 1: https://www.instructables.com/id/Detonator-box-Ignition-box-Fireworks-Pyro-box/
Step 1: Getting Started
So firstly these are the things you will need.
A hobby case, I used the one you see in the picture
A toggle switch with red cover
7.2 volt rechargable battery with plugs on the end (rc car)
Push switch (red)
Key switch (with keys)
Jack plug (not quite shore which one it is, you see it in the picture)
Jack plug socket with lock
pull ties (tiewraps)
Led with fitting
Drill
Isolation tape
Sticker maching
wire
30 meters of wire(more or less)
Step 2: Measure THEN Drill
Firstly measure out the width of the switches and choose the right drill. Drill the holes in the top and the side, one for the arm switch, one for the fire switch and one for the power key switch.
Then drill four holes in the bottom so that you can put 2 zip ties through them and hold the battery from the bottom. If there are not already (like in my box) drill a hole for the master power wire to pass through (wire directly from the battery) For the LED drill a small hole next to the key switch.
Finally for the Jack Socket you need to drill quite a large hole.
Step 3: ------Wiring-------
So now you have full access start putting in all the switches and see if it all fits, maybe edit a little with your dremel. Choose if you are going to sodder your wires to the contacts inside the detonator or you are going to hot glue it. I hot glued because you can take it off easily so you can change things easily. Now when your done with that start with the 30 meter wire and jack plug, connect the wire strand to the jack plug neatly and tape over it.
Step 4: Finishin UP
So everything should be about ready now, charge your battery and try it out with a small copper wire piece, leave the box open to check for any failures (shouldnt be any).
Now close everything up and make it neat. Use some Isolation tape to make the box look really neat and I used a sticker machine to print out the FIRE and ARM stickers. I like the look.
Now just plug in the plugs from the battery, turn the key flip the cover, flip the switch and press....
That how simple the PYRO DETONATOR 2 really is.
    • Organization Contest
    • Tape Contest
      Tape Contest
    • Pie Contest
      Pie Contest
    187 Discussions
    JamesG33
    2 years ago
    Just making sure, you added the key for more looks, cause you already had the red toggle switch.
    JamesG33erica5
    Reply 2 years ago
    Thats actually not that hard. It just depends what kind of wireless you want. You can do it the really easy way and get one of those wireless doorbell kits, open it up and assemble to your stuff. putting the motion sensor on your end, and the doorbell that dings on the other. The motion sensor will send a signal to the doorbell up to 300 feet. put the motion sensor on a circuit you can close and open when you want, and your fire button could be a switch that pushes open a door revealing the sensor. Idk, just some quick thoughts. lol.
    tweekout28
    3 years ago
    im using 3 pin toggle switches.. im trying to wire multiple wires.. id like to be able to have 5 or 6 switches and be able to shoot them of individually.. can any body help me?
    laminatedsamurai
    11 years ago on Step 1
    How about that sweet-looking key switch? I've been looking all over to try and find one, but all I was able to find is a momentary switch: you need to hold it to keep the current flowing. Any others were all from these Chinese bulk ordering sites that the minimum order is 500, and I don't even know if they're the right ones. Anyone I ask about this, even at a hobby store, look at me like a grew another head out of my ar-...well....out of somewhere.
    any good electronic's store will have various key switches.....radio shack used to to have them, but they don't anymore....
    jimmy deangizmogadjet
    Radioshack is a dissapointment, they can barely even be considered as an electronic store anymore. Last time I went there I asked for magnet wire and they looked at me like I was insane.
    Same thing happened to me too, but instead they gave me a roll of speaker wire and told me it was the same thing.
    bwpatton1laminatedsamurai
    Reply 10 years ago on Step 1
    Try either ebay or elliot electronics (wholesale or retail) 12volt ones are easier to get but finding a 120 volt switch is harder.
    OLD COMPUTERS... get some old Pentium 1s most of them have key switches L.E.D and L.E.D displays speakers and etc.................
    ebolson
    5 years ago
    Where can i find the jacks
    ebolson
    5 years ago
    How to wire jack and wires
    oeng huat
    6 years ago on Introduction
    Hi, why do you need to use a jack plug? How do you connect it?
