Packing Tape Image Transfers
42,296
58
19
In this instructable, I'll teach you how to transfer laser printed or photocopied images to packing tape.
This process also works with hot glue or clear caulk -- the transfer won't be as clear, though.
Supplies:
Step 1: Materials
You will need:
- packing tape
- scissors
- the image you want to transfer
- a basin
- water
Step 2: Printing and Cutting
Print out the picture you want to transfer. This method works with laser printers, and photocopiers -- I'm just not sure about inkjet printers.
Once you've printed your picture, cut it out to save paper.
Step 3: Tape
Tape over your image. I suggest at least two layers of tape, to prevent the tape from seperating.
Once you've taped up your picture, you can trim the edges of the tape.
Step 4: Soak and Rub
Fill your basin with water, and soak your image in it.
Once you've soaked the image for a while, rub it's back. The paper should come of easily.
Step 5: Finished!
You're finished!
Now, go find a use for your paper pulp.
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    19 Discussions
    batvanio
    2 years ago
    Be a little more specific. What water use, how long you hold it ...
    RickS238batvanio
    Reply 3 months ago
    I use hot water with a little soap in it. The key is to get the paper wet enough that it will ball when you run your finger over it. Then dunk again in the water and rub some more. Total time to remove paper is less than a minute.
    batvanio
    2 years ago
    I do not get. I used inkjet printer and keep it in hot water. Friction fell and paper and ink.
    janey west
    2 years ago
    Help ! I tried this, I printed "Treats" soaked it water for couple min. then pealed off the paper and nothing. What am I doing wrong ?
    rsk11584
    7 years ago on Introduction
    wow nice idea i will post afterwards that for what i used this :)
    nickhallen
    7 years ago on Step 5
    Yes, when they dry they are still fairly sticky.
    Ok, now that I've said that, I realize that you could stick the tape to whatever you want. So yes, in a way, you can transfer it to "something else".
    GorillazMiko
    11 years ago on Introduction
    That's so cool! Great job, I am going to try this out for sure. +1 rating. (added to favorites)
