Pallet End Table
226,786
1,451
19
About: I like to design and build random things.
Below are directions for a simple end table made from pallets.
Step 1: Find Pallets
Find free pallets from Craigslist. If not available, you can purchase them locally for very little money.
When searching through the pallet stack, look for the pallets with the most usable wood. The length of the slats is ~ 3 feet. The thickness varies from ½ to ¾ thick. The width of the slats can vary from 2.5 to 6 inches.
Step 2: Deconstruction
Breaking the pallets apart takes a decent amount of work. Use a jig or circular saw to cut the ends. Pry the wood from the center support. This should give you 8 to 14 boards per pallet. Remove nails from slats.
Before you start cutting, determine the best pieces to get the desired width (see drawing). I had multiple long pieces with cracks and/or damage down one side. I was able to cut the damage off and still have usable pieces.
Step 3: Cut Pieces
Cut pieces per drawings. After cutting, sand with course sandpaper to remove rough spots or major staining/paint…unless that is your desired look.
Step 4: Assemble Frames
Assemble the two frames (nail & glue). Note how it is put together – should be a square
Step 5: Add Horizontal Slats
Attach horizontal slats to frames (nail & glue).
Step 6: Leg Assemblies
Nail and glue legs as shown.
Step 7: Ready for Final Assembly
Step 8: Add Legs & Pins
Attach the legs as shown (nail & glue). Drill holes for the pins. Insert and glue into place.
Step 9: Final Product
Drawing File:
https://googledrive.com/host/0B21TbB8gGNQbX2dlNGdxR0NuOE0/end_table_RevA.pdf
Step 10: See Matching Planter Boxes!
If you liked this, see matching planter boxes.
https://www.instructables.com/id/Planter-Box-from-P...
Pallet Contest
Runner Up in the
Pallet Contest
4 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
19 Discussions
AdamH145
2 years ago
Forgot to say I used bolts that had been spray painted black instead of dowels.
mtairymdAdamH145
Reply 2 years ago
Nice. The bolts are a cool touch.
AdamH145
2 years ago
Made these for our new end tables. Thanks!
16, 9:32 PM.jpg
Shermtank28
2 years ago
Only wish I had some stain, but the goal was to make it for free. I didnt have a table saw for the cuts, so I had to rely on a jigsaw and a few planers, but I love it!
mtairymdShermtank28
Reply 2 years ago
Nice job! BTW, there are a few low cost stain options available. Search for natural stain on instructables.
I think I used 1 1/4 inch finishing nails. I use a nail gun (1.5" nails) for the planter box shown in the last step
Glenzito_46
4 years ago
Decided to use your idea as my first pallet project, worked fine, just found that finding straight boards is the biggest challenge, took me slightly longer and put my own spin on the dezign, thx for the info
mtairymdGlenzito_46
Reply 4 years ago
Yes, straight pallet wood is a challenge.
Good job. ​I like the color.
Glenzito_46mtairymd
Reply 4 years ago
Thanks, mounted some rubber feet yesterday and is steady as a rock
mtairymdgunnerjake81
Reply 4 years ago on Introduction
Yes, very similar. The dimensions have been modified. I also wanted something to match the planters.
