Pallet Wood & Dowel Corner Gift Box
7,093
306
10
About: I like to make fun projects and document it all for my channel BCDesign on YouTube!
I made this pallet wood gift box with doweled corners for the Sterling Davis pallet wood challenge on YouTube.
I made the box with mitred corners and I was going to use splines to make the corners stronger but decided to use dowels instead.
I made a YouTube video of the process for my channel BCDesign
What you will need:
  • Drill
  • 8mm wood bit
  • Mitre saw
  • 8mm wood dowels
  • Wood glue
  • masking tape
  • 2 hinges
  • 10cm of chain
  • 16mm screws
  • Clasps to close the box
  • Sandpaper
  • danish oil
Supplies:
Step 1: Cut the Pallet to Size
  • Find a Pallet that is in good condition
  • I used a jigsaw to cut the best boards from the pallet
  • I needed enough wood for the 4 sides a top and a bottom
  • I used my mitre saw with a stop block to make mitred cuts for the corners.
Step 2: Glue the Box Together
  • I dry fitted the parts together before gluing
  • I used masking tape to hold the glued mitred corners together
  • I then added 2 awesome Piher clamps, make sure not to over tighten the clamps or the corners will slide apart
  • I left the box overnight for the glue to dry
Step 3: Drill 8mm Holes for the Corners & Base
  • I removed the box from the clamps and sanded the box from 120-320 grit
  • I then marked the corners and base where I wanted to put the dowels
  • Make sure you pick the appropriate size drill bit and dowels for the thickness of the wood you use.
  • Be careful when drilling the corners that you don't drill through to the inside of the box.
  • I used a scrap piece of wood clamped to the side of the box that the drill tip would exit to prevent tear out.
  • I then put glue in the holes and on the dowels and tapped them into position with a mallet.
  • I also drilled holes around the base and added dowels to strengthen the base.
Step 4: Add Hinges & Clasps
  • I marked out the position for my hinges
  • I then used a chisel to recess the area the hinge would fit in,this makes the lid sit flush when closed
  • Screw the hinges into place and make sure the lid closes properly.
  • I then marked the position for the clasps on the lid and front of the box and drilled pilot holes to prevent the wood splitting and secured them with screws
Step 5: Cut Chain & Finish With Danish Oil
  • I cut 10cm of chain and used a pliers to crimp the first & last links so I could secure it to the box with some screws.
  • I then applied 3 layers of danish oil sanding with 320 grit between each coat
  • I think the box turned out very nice and like the way the dowels look exposed on the outside of the box.
I made a YouTube video of the process please subscribe and thumbs up if you like it!
Link to my channel https://www.youtube.com/user/bazza866/videos
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    10 Discussions
    KanPo Studios
    3 years ago
    Excellent BCDesign.
    I was looking for a box to do an and give out for Christmas with goodies.
    Certainly a "favorite" and a must do project.
    Thanks for sharing
    Ray.
    BCDesignKanPo Studios
    Reply 3 years ago
    Thanks Ray please post a ible or pm me so I can see how your boxes turn out!
    ulma doctor
    3 years ago on Introduction
    super cool box.
    i'll be stealing the idea very soon, thanks for sharing!
    ClenseYourPallet
    3 years ago
    I really like the design of your box. I have never thought about using dowel for the corners like that. Very cool. Thanks for sharing
