Pandahall Tutorial - How to Make a 2-Hole Seed Bead Flower Pendant Necklace
4,011
26
8
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
In this Pandahall tutorial, I want to share a 2-hole seed bead flower pendant necklace with you. Follow me to see how to make this seed bead flower pendant necklace.
Supplies:
Step 1: Materials and Tools Needed in DIY the Seed Bead Pendant Necklace:
2mm Blue Seed Beads
10mm White Round Pearl Beads
5x3.5x3mm 2-Hole Seed Beads
6x4mm Clear Abacus Glass Beads
Korean Wax Polyester Cord
Cord Ends
Silver Lobster Clasp
Silver Headpins
Silver Twisted Chain
0.3mm Tiger Tail
Needle Nose Plier
Round Nose Plier
Stainless-Steel Scissor
Step 2: Make the First Part of the Seed Bead Pendant Necklace
1st, cut a piece of 0.3mm tiger tail. Then, thread about 12 5x3.5x3mm white 2-hole seed beads to the tiger tail;
2nd, cross the left tiger tail through the rightmost white 2-hole seed bead and tighten (as shown in the picture);
3rd, cross the right tiger tail through the other hole of the white 2-hole seed bead (as shown in the picture);
4th, thread a 2mm blue seed bead to the right tiger tail. Then, cross the tiger tail through the other hole of the adjacent white 2-hole seed bead (as shown in the picture);
5th, refer to the above step to add more 2mm blue seed beads (as shown in the picture);
Step 3:
6th, add 3 blue seed beads to the tiger tail. Then, cross the tiger tail through the adjacent blue seed bead. Repeat this step several times (as shown in the picture);
7th, add 2 yellow 2-hole seed beads to the tiger tail and cross the tiger tail through the adjacent blue seed bead. Then, add 2 orange 2-hole seed beads to the tiger tail and cross the tiger tail through the adjacent blue seed bead (as shown in the picture);
8th, refer to the 7th step to add yellow 2-hole seed beads and orange 2-hole seed beads;
Step 4:
9th, refer to the 7th step and the 8th step to add another circle of yellow 2-hole seed beads and orange 2-hole seed beads;
10th, add a yellow 2-hole seed bead and cross the tiger tail through the other hole of the adjacent yellow 2-hole seed bead (as shown in the picture);
11th, add a blue seed bead and cross the tiger tail through the other hole of the adjacent orange 2-hole seed bead. Then, add an orange 2-hole seed bead and cross the tiger tail through the other hole of the adjacent orange 2-hole seed bead (as shown in the picture);
12th, refer to the 11th step to add blue seed beads, orange 2-hole seed beads and yellow 2-hole seed beads.
Step 5: Make the Second Part of the Seed Bead Pendant Necklace
1st, cross the tiger tail through the other hole of the yellow 2-hole seed bead. Then, add 2 blue seed beads, a 6x4mm clear abacus glass bead and 2 blue seed beads in sequence. Cross the tiger tail through the other hole of the adjacent orange 2-hole seed bead (as shown in the picture);
2nd, refer to the above step to add blue seed beads and clear abacus glass beads;
3rd, add about 12 blue seed beads to the tiger tail and cross the tiger tail through the adjacent clear abacus bead (as shown in the picture);
4th, add about 5 blue seed beads to the tiger tail and cross the tiger tail through the top blue seed bead. Then, add about 6 blue seed beads (as shown in the picture);
5th, cut two pieces of blue Korean wax polyester cords and two pieces of yellow Korean wax polyester cords. Hold them together and add the 2-hole seed bead pendant to the middle of the Korean wax polyester cords;
Step 6:
6th, add a cord end on the two ends respectively;
7th, combine one end with a silver lobster clasp through silver jump ring. Then, cut a piece of silver twisted chain and add it to the other end;
8th, combine a 10mm white round pearl bead with a silver headpin. Then, make a hoop on the other end and combine it with the silver twisted chain (as shown in the picture).
Step 7: Here Is the Final Look of the Seed Bead Flower Pendant Necklace.
Do you like this 2-hole seed bead flower pendant necklace? From the above picture, we can see that the 2-hole seed bead flower pendant is very shining. The main techniques used in this DIY project are just some beading techniques. If you like this seed bead flower pendant necklace, just have a try!
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    8 Discussions
    hinagiku
    2 years ago
    it looks amazing :O how did you learn these bead techniques??!!
    TanaquilL
    2 years ago
    That's beautiful. I'm going to try to make one. Thanks for sharing.
    DasiyDYoKidz
    Reply 2 years ago
    Thank you! Have a nice day:)
