Paper Clip Connectors
2,271
15
About: I am a Senior in college studying Mechanical Engineering. My interests include woodworking, 3D printing, electronics and building computers
If you need some quick and cheap connectors for a project i found that paper clips work good. They are really cheap and they slide together and come apart really easily.
For my connectors i went and soldered the wire to them but you could also twist the wire onto it good and then cover it with hot glue
to connect the paper clips together just slide them together on the open end, you now have a good connection
If you need connectors that are insulated you can use paper clips that have a coating on them and just scrape off the coating on the sections that would make contact.
Hope everyone finds this useful
Electronics Tips and Tricks
Runner Up in the
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    3 Discussions
    acuchetto
    5 years ago
    Good suggestion about using coated paper clips with just the connecting portion stripped. The insulation, in general, would be my biggest concern. Other than when prototyping, have you found a good use for this type of connection?
    joshmt2012acuchetto
    Reply 5 years ago on Introduction
    Yeah ive used coated ones when im experimenting with speakers so that the connections wont touch
    shazni
    6 years ago on Introduction
    this is neat...i never would have thought of it. thanks
