Paper Electronics: Conductive Paints, Inks, and More
93,779
588
45
This Instructable is all about the amazing technology of paper electronics and conductive materials. Instead of using stubborn wires and your rusty soldering skills to painstakingly connect components, why not use paint and glue? This tutorial will share various recipes to create your very own conductive paint, tape, glue, and ink. Using a maximum of 3 easy to find ingredients, these simple materials are easy to make. All of the conductive materials explained in this Instructable are based around the conductive paint (step 1). Using increments of different chemicals, the consistency of the paint can be changed from thick to thin (glue to ink). At the end of the Instructable a simple project will be shown using conductive materials (step 5). There is also a step that is dedicated interfacing conductive materials with kits and teaching classes and workshops.
Even though commercially available conductive materials work great, they are a wee pricey and often need to be ordered online. Another disadvantage of commercial products is that they are usually only available in conductive paint form.
To start off, I would like to share some of the science behind the main ingredient used in the conductive materials; graphite. Graphite is a mineral and a form of pure carbon. Graphite is very conductive and is sometimes used in arc-lamp electrodes. Because of its conductivity, graphite is the primary candidate for making conductive materials. Its other bonuses include being easy to obtain, mixing well with paint, and coming in a very fine powdered form.
Here are the supplies needed to make the conductive materials in this Instructable:
- powdered graphite lubricant- from from Ace Hardware or other hardware store
- black poster paint- from local craft store or from Amazon
- paint thinner- from local hardware store or from Amazon
- popsicle/mixing sticks- from local craft store or Walmart
- mixing cups- I used styrofoam cups from grocery store
- measuring spoon- baking spoons will work
To complete the ink and stamping steps and the project, you will need these additional supplies:
- light emitting diode (led) available at local Radioshack
- 3-volt coin cell battery- available at grocery store
- sponge- some type of sponge, I got mine out of an old printer ink cartridge
- airtight vial- any type of airtight container will work
- airtight plastic container- possibly tupperware or old food container
- paper
Now that the materials have been gathered, it is time to begin making conductive materials!
Warnings: Some of the projects and instructions in this Instructable use paint thinner. This chemical produces nasty fumes that probably aren't very healthy for you. Perform all projects using paint thinner in a well-ventilated room. I am not responsible for any accidents that may occur while using this Instructable.
This Instructable is submitted for Powell Cubs for the Instructables Sponsorship Program.
Supplies:
Step 1: Making Conductive Paint/ Base Material
     The first part of this tutorial features conductive paint. The paint will be the base of all of the other materials that are explained in this Instructable. The paint makes an ideal base because of its consistency. To make glue you add slightly more graphite powder, and to make ink a few drops of paint thinner is added... but onto that in later steps.
     Conductive paint sticks well to most materials, especially paper and cardboard. Anything that the poster paint will bond to, the conductive paint will as well. I have found that this mixture of conductive paint flexes well on paper. However, sharp creases and folds will lead to a crack, usually causing a shaky connection. The conductive paint will turn out to have the same flexibility as the paint that is mixed in.
     As a general rule of thumb, use this paint in low-medium areas of stress to ensure a reliable connection. For higher stress applications resort to one of the conductive inks mentioned later in the Instructable.
     The two materials used in conductive paint are powdered graphite and the poster paint. After much experimentation, I found that a mixture of 2 parts powdered graphite to 1 part black paint worked exceptionally well.
Instructions: Using the measuring spoon, measure out two spoonfuls of powdered graphite and pour it into a mixing cup. Add 1 spoonful of the poster paint. Mix well, making sure all of the graphite is added.
Application: Slather heavily onto the material (i.e- paper, cardboard) in the desired pattern using a paintbrush. Make sure that all lines are coated evenly. Allow a few hours to dry before using. Store remaining paint in an airtight container.
     When dry, the conductive paint has a very low amount of resistance. After several tests, I calculated the resistance to be around
115 ohms per centimeter.  If the circuit schematic calls for a small resistor  (<115 ohms), it would be alright to omit it. I found that when you connect a new 9-volt battery to a painted line (of conductive paint) and attach a digital multimeter on the other side, the voltage detected is 9.27-9.28 volts out of 9.29-9.30 volts. In sum, there is a very minimal amount of voltage lost when using conductive paint.
Step 2: Conductive Glue and Tape
     Now that the base paint has been concocted, other materials can be made. In this step I will highlight the making of conductive adhesives. Conductive tape and conductive glue will be shown.
     Conductive Tape: Conductive tape can be used to bind paper and cardboard together, as well as connect components for a quick and easy prototype. I would not suggest using conductive tape for permanent or moving circuits, as it will become loose over time.
Instructions: Paint a layer of conductive paint onto thin strips of paper. Wrap around the desired object tightly, ensuring a good connection. To store the tape, place the painted strips side by side in an air tight container or bag.
     Conductive Glue: Conductive glue can be made by adding more dry materials to the original base.  It could be used to create a binding substance for numerous sheets of paper, cardboard, etc. Glue can also be used to attach electronic components to the painted lines in a schematic. It bonds well to most materials, including the metal leads of components, paper products, and plastics. Since more graphite is added to the original base to make glue, the glue will have even less resistance, depending on the amount of graphite used.
Instructions: ​Mix up a batch of the base paint (2 parts graphite, 1 part black paint) in a mixing cup. Keep adding graphite powder, one part at a time, until the glue reaches the desired consistency. I found that 4 parts graphite to 1 part of paint was about the right consistency. Adjust the consistency to your desires.
Application: Using a paintbrush, slather the mixture on the component lead or desired surface. For thicker mixtures, use a mixing/popsicle stick to place a dollup of glue on the material. When gluing a component, ensure that the glue is contacting the lead of the component and the line of conductive paint. Allow a few hours for the paint to dry before using the circuit. Store in an airtight container.
Step 3: Conductive Ink
     Conductive ink is another necessity in the field of conductive materials. Ink's thin consistency makes it perfect to apply to paper and cardboard. My initial experiments in the conductive materials field were focused on conductive ink. I tried to mix water and graphite together. However, I soon found out that graphite and other conductive metals/minerals were not water soluble... the graphite would always settle to the bottom of the water, no matter how much mixing was done. Eventually, I gave up on ink and moved onto paints and glues.
     After succeeding at these, I came back to ink. My spark came when I was searching through the mess in our basement for more black paint. I saw a jug of paint thinner. Paint thinner is a solvent that is usually used to thin oil-based paints. It can be made of mineral spirits, acetone, naphtha or other nasty chemicals. To reiterate the warning in the intro, always use paint thinner in a well-ventilated area.
     Conductive ink is much more flexible then conductive glue, and works better in high-stress applications. Conductive ink can be used in all sorts of applications.
     Once again, using the base paint described in step 1, paint thinner is mixed in. As might be expected, the paint thins into a ink-like consistency, depending on the amount of paint thinner used. After being made there are a number of ways that conductive ink can be applied. For a stamp/inkpad method refer to step 4.
Instructions: Mix up a batch of the base paint in a mixing cup. Add 1-2 parts of paint thinner to the mixture. Stir well with a popsicle stick. The substance will cling to the sides of the cup in long droplets. Just keep scraping the drops off the cup until well mixed. Add paint thinner until the concoction reaches the desired consistency.
Application: Insert a paintbrush and scrape the cup. The ink will be sucked into the paintbrush and off of the cup. Apply the conductive ink to the desired surface or refer to step 4 for a tutorial on a conductive ink pad stamp. Store in an airtight container.
Step 4: Conductive Ink Stamps
     You know those cool stamps that you press onto a piece of paper to leave a meticulous ink pattern or lettering? Your teacher might have used one to stamp a "Good Job" on your worksheet when you were in school. Soon after creating the conductive ink, I realized that it should be applied in a different way then the paint. Instead of using a paintbrush, it would be fun to stamp circuitry onto a piece of paper. Using a stamp, you can neatly press a "printed" circuit board onto a piece of paper.
     In this part of the Instructable, I will demonstrate how to acquire your own stamp, and make a proper ink pad loaded with conductive ink.
     If you do not want to make your own stamp, you can customize and purchase professionally made rubber stamps from many online sites such as here.
Even though these stamps are pricey, if you are going to be making a lot of the same circuit board, these would come in very handy. Another idea for stamping is to use locally available stamps. You could stamp letters and use them as the wiring in your circuit. These stamps are available at your local craft store.
Instructions:
The stamp: Since stamp-making is beyond this instructable, search the Internet for a tutorial on how to create your own stamp. A great collection of tutorials can be found here.
Create your stamp in the pattern of your desired schematic. For places where components connect, make circles for easy interfacing with conductive glue.
The ink pad: Insert the sponge in a air tight container with the lid removed. Mix up a batch of conductive ink as described in step 3. Try to make a ink of a very thin consistency, such as a consistency  nearly as thin as water. Mix it well and collect it in a brush. Paint the ink onto the sponge until it is soaking with conductive ink. If the ink is not absorbed, the ink is not thin enough.
Application: Press your stamp into the ink pad, ensuring equal coverage of ink. Push the stamp down onto the desired surface and pull up. If the desired area is not coated well, stamp again over the same spot. Repeat until the stamped area is all black and without visible paper.
     Stamped circuits may be subject to a slightly higher resistance then normal brushed paint or ink because not as much ink is put down onto the surface. The resistance all depends on how much ink is put down during stamping and how wide the stamped lines are.
Step 5: Making a Simple Circuit
     Now that all the recipes for the conductive materials have been shown, it is time to use these in a circuit. During this step, I will demonstrate how to build a simple circuit using conductive paint, ink, glue, and conductive tape. The circuit consists of  an led and a  3 volt battery. A resistor is not needed in this circuit.  You will also need all of the previously mentioned conductive materials and a piece of paper.
     Instructions: First, paint or stamp two parallel lines about 1/2 inch apart on a piece of paper. Attach a 1 inch piece of conductive tape to both sides of the 3 volt coin cell battery. Center the battery on its edge and press the tape onto the corresponding lines. Make sure that the tape and paint are making good contact. Next, use conductive glue to attach one of the led's leads to the other end of one of the painted lines, noting proper polarity. Remember that the flattened side of the led is the negative lead.  Bend the opposite lead of the led so that it is not touching the parallel line. Allow the circuit to dry. Finally, to turn on the circuit, press the bent lead down onto the painted line. This will close the circuit, and the led should turn on.
Step 6: Kits!
     During this Instructable you have learned how to make conductive paint, tape, glue, ink, and stamps. You are probably wondering how else you could use your new knowledge. Conductive materials are a great way to make kits. Whether you are teaching a large group about electronics or just a few people, pre-made kits are an essential teaching tool for a hands-on experience. Conductive materials supply many advantages for making kits.
     First of all, conductive materials are perfect for kids/adults who are new to electronics. When teaching an electronics class, it would be much easier if the kits did not require soldering and jumbles of confusing wires. Instead of messy and often irreversible solder, conductive glue would solve the problem with a fun and easy way to attach components. Conductive painted wires would provide an easy layout of the circuit. Students could easily be able to see what connected to what.
     Another pro of using conductive materials in kits is circuit boards. Instead of spending long hours and tons of money creating traditional circuit boards for the class, paper circuit boards could be mass produced using the stamping method. Identical boards could be created in an efficient manner.
     Overall, paper electronics would make the perfect materials for kits. Teaching classes would be made easy, and budding electronic geniuses would have the opportunity to experiment with the cutting edge technology of conductive materials.
Here are a few things that could be included with kits:
- paper
- conductive paint, ink, tape, glue
- stamps/ or materials for a diy stamp
- paintbrush
- electronic components
Step 7: Conclusion/Other Ideas
     During this Instructable you first learned how to make conductive paint. Then, from there, the tutorial went on to explain the process of making conductive tape, glue and ink/stamps. With these conductive materials you now have the ability to make your circuits cheaper, thinner, easier, and more flexible. Hopefully you will be able to apply these materials to your future projects and experiments. As an ending note, I would like to share some of my ideas for more things that could be done with conductive materials. Since it is a fairly new technology, there are loads of things that could be developed. Here are a few:
- a conductive ink printer
- colored conductive materials
- paper components, electronic components that could be stamped onto paper
- interactive paper business cards or newspaper
- transparent or translucent conductive materials
     Thank you for reading this Instructable. I hope that you have learned a ton about conductive materials and their applications. Thank you
-icecats-
Pocket Sized Electronics
Third Prize in the
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    45 Discussions
    c8yin
    2 years ago
    Thanks for the detailed instructable. I'm trying to make some connections on a piece of fabric that will potentially be subject to a good amount of bending. I tried using a commercial carbon paste, which resulted in very good conductivity, but the lines of paint I drew broke immediately upon flexing. You state that the carbon 'ink' was much more flexible than the paste- do you think a dilution of my carbon paste in paint thinner or acetone will suffice for my purpose? How did you test that the carbon ink was superior for higher-stress applications? Look forward to your response!
    icecatsc8yin
    Reply 2 years ago
    It would definitely be worth a try. Any type of flexing material will probably be hard on conductive ink/paste. You could try mixing the graphite with some kind of flexible glue. Also, have you considered conductive thread?
    c8yinicecats
    Reply 2 years ago
    Okay. I tried a greater dilution today, and the lines didn't crack...but they also didn't really conduct. I'm going to go back and apply some more layers. maybe try widening the line width to decrease resistance (though I don't know how significant that will be). I have also been looking into conductive thread and tape- my partner wants to try the paint, so I'm seeing if I can make it work, but realistically I believe those options will probably work better.
    banman11
    3 years ago
    Very interesting instructable. It has given me some food for thought.
    I have an old ffc cable that has a few worn out traces. This cable is specialized and a generic comerecial replacment is not available
    Maybe a fine piece of sewing string doped with this mixture might work. The traces are thin.
    Do you think this is a possibility?
    Thanks for sharing this .
    clarkr6
    3 years ago on Introduction
    Great tutorial. I have some questions below...
    I am trying to repair a DVD remote keypad that has worn a lot of the conductive material off on the underside of the rubber/silicone pad that makes contact with the PCB and creates a circuit.
    The cost of commercial conductive epoxy or even the inks make it expensive/uneconomical to repair. If this formula of yours is conductive enough to work on an infrared LED it sounds like a great solution.
    Question: will this formula for the ink or glue adhere enough to a rubber/silicone keypad for use without wearing off or cracking in a short period of time?
    If not I will probably look at using a thin copper foil with superglue to put on the underside of the pad.
    Thanks.
    icecatsclarkr6
    Reply 3 years ago on Introduction
    The conductive material highlighted above should work with your application. Extended flexing would probably take its toll on the paint though. It would be worth a try (under $5.00).
    clarkr6icecats
    Thanks for the help. Would you suggest the ink or the glue application for the longest durability on a keypad?
    rajesh32035
    5 years ago on Introduction
    thank u so much.i tried it but i am getting a very high resistive paint(about 30kohms).
    how can i reduce its resistance?
    newage2014
    Hello!
    I want to make a flexible heater 20W/12V with this paint. Is it possible?
    Verticees
    Of all the Instructables I have seen, this may be the coolest!! Great job on this!! However, I have had another idea for conductive tape which mimics the conductive tape made by professionals. Maybe you could add some sort of clear (but conductive) adhesive to the back of a strip of aluminum foil, which is already conductive. This way, you can have conductive tape with less resistance! It may not be too strong, but it still may work. Anyways, great job on the Instructable!
    ac-dcVerticees
    Reply 5 years ago on Introduction
    1) It's not even usable for 99% of circuits. The resistance is too high and the durability very questionable because it's going to heat up with that high a resistance.
    2) You can't just slap this on aluminum foil because aluminum foil immediate forms an aluminum oxide layer on it (even if you polish it away or use lye) that is non-conductive. There are ways to get it to work but there is no sense in doing any of them when silver or copper would work much better.
    ... but actually, what works even better when it's possible is to use real wire or a PCB. There's really no point in trying to avoid learning to solder if learning electronics prototyping. It's not even a time saver since waiting for glue to dry takes longer than soldering a few joints.
    icecatsDCengineer
    "When dry, the conductive paint has a very low amount of resistance. After several tests, I calculated the resistance to be around
    115 ohms per centimeter. Even though 1 centimeter of standard 22 gauge hookup wire has a resistance of about 2 ohms, the 113 ohms difference will barely make a difference in the circuit. If the circuit schematic calls for a small resistor (<115 ohms), it would be alright to omit it. I found that when you connect a new 9-volt battery to a painted line (of conductive paint) and attach a digital multimeter on the other side, the voltage detected is 9.27-9.28 volts out of 9.29-9.30 volts. In sum, there is a very minimal amount of voltage lost when using conductive paint." Thank you
    ac-dcicecats
    115 ohms /cm is a HUGE amount of resistance, which is why conductive paint is not normally made in this way but instead with silver particles.
    22 gauge hookup wire does not have 2 ohms /cm, that is a measurement error from your multimeter contacts, leads, and the physical touching of the probes or clips to the wire. Actual resistance of 1 cm, 22 ga. wire is about 0.001 ohms.
    You cannot measure voltage like that, it has to be voltage powering a load. 115 ohms is completely unacceptable for any circuit except those that just happened to need the particular amount of resistance that causes and ironically enough the only thing I can think of at the moment that would call for that would happen to be powering a ~20mA LED by a 9V battery.
    longwinters
    5 years ago
    I love this idea my mind is already thinking of ways to put it to use
    In the past I have used stained glass copper foil tape but this has so many more possibilities
    mastergabe
    5 years ago on Step 7
    sorry i meant to say indium tin oxide
