Paper Mache Dinosaur
3,623
63
21
About: Im a St. louis based artist. I primarily paint but can be found dabbling in a lot of different mediums.
Here is the finished product first.
Step 1: Chicken Wire
I started off with a rough shape using chicken wire.
Step 2: Lots of Newsprint and Lots of Flour/water Mix.
I had a newsprint pad lying for sketches. I cut it up into strips and used that for layering the paper mache.
Step 3: Raising the Cowl
I decided the cowl was to short. So i cut some more chicken wire and laced into the existing cowl and covered it in more paper mache.
Step 4: Adding Definition
I used rolled up bits of aluminum foil to add depth around the eyes, horns and beaks and covered it with more paper mache.
Step 5: Mounting
I had a table top that I had left over from a previous project. I had bought it from Home Depot for about $10. I also had small trash bin in the basement. I attached the two using some screws and balanced the head as centered as possible. I then used a lot of duct tape attaching the head to the base and at the same time forming the basic neck shape. I then covered it with more paper mache.
Step 6: Adding Detail
I wanted to add more detail to the eyes and mouth area. I again used what I had lying around which was a fire based clay. It really shrunk and cracked on me which i used drywall mud and countless time sanding. I should have used a paper clay with less shrinkage and saved a lot of time.
Step 7: Primer
After sanding half a day away I finally got it to where it was acceptable and laid down a coat of spray on primer
Step 8: Painting
I then brushed on "Metal Effects" copper paint by Modern Masters Inc. and applied a blue aging patina to the skin and used a layering of paints on the horns and beak. After the patina did its thing I went back and with more copper to balance out the piece. I added a meaty sawtooth hanger and attached it to the wall. Let me know if you have any questions.
Justin King
www.justinkingdesigns.com
Step 9: Finished Shots
Here it is hung in all its paper mache glory!
Papercraft Contest 2017
Third Prize in the
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    21 Discussions
    PardoByNight
    2 years ago
    I love the oxidizing copper look it has, it adds a really cool look
    pokiespout
    2 years ago
    Great job sir, glad you've made it to the finals!
    shazni
    2 years ago
    Amazing!
    Fuzzy Monkey
    2 years ago
    Can't believe it's paper! WOW :O
    Mad Props
    2 years ago
    Nice work. Love the mettalic paint!
    JustinK133mikeyb3178
    Reply 2 years ago
    I have this one for sale for $800 its roughly 36" x 36" x 27"
    ronanryJustinK133
    Reply 2 years ago
    I can't see your entrie ???
    (or else, i don't know where to vote on this instructables)
    JustinK133ronanry
    Reply 2 years ago
    Yeah I am not sure, it says Ive entered, maybe it takes a bit before it updates?
    JustinK133ronanry
    Reply 2 years ago
    it looks like there is a vote tab on the top right of the instructable.
    aekent
    2 years ago
    Looks great. Thanks for sharing.
    Anirudh Ralhan
    2 years ago
    That's so freaking AWESOME!!!!!
    chechos84
    2 years ago
    the final middle photo looks Bad-Ass :)
    tomatoskins
    2 years ago
    Wow, you have done some amazing work! Thanks for sharing!
