Paper Marbling With Food Dye and Shaving Cream
3,937
206
6
About: Just a girl who spends her days crafting! I love creating new things out of duct tape, clay, or anything that can be made into something new!
A quick and easy way to marble paper!
Supplies:
Step 1:
Step 2:
~ Supplies ~
~ Ruler
~ Food Dye
~ Shaving Cream (make sure it is foam)
~ Painters Tape
~ Envelopes/ Paper
~ Plates
~ Tooth Picks or Spatula
~ Tray
Step 3:
Start by taping off any areas of the paper you do not want to be marbled. Since I started by marbling the flap of the envelope, I also used a different piece of paper to help cover up the area I wasn't marbling.
Step 4:
Cover the tray in a layer of shaving cream. Then, add a few drops of food dye onto the shaving cream. Next, take the spatula or the tooth pick and mix the food dye with the shaving cream. I use the tooth pick when I want to create more of a pattern. Using the spatula will create more of the marbled look.
Step 5:
Next, press the paper on top of the shaving cream. Then, pull up the paper and take the rule and scrape the shaving cream off. Let dry before using.
Dyeing for Color Contest
Third Prize in the
  • IoT Challenge
    IoT Challenge
  • Fandom Contest
    Fandom Contest
6 Discussions
Slippery arm
2 years ago
In second grade my science teacher used the wrong kind of shaving cream,it did not work.in conclusion Always use foamy stuff
nanaverm
3 years ago
Wow! I didn't know you could use regular paper & food dye for this! Thanks!
It's spectacular on glossy or photo paper.
craft within reachnanaverm
Reply 3 years ago
Thank you! I'll have to try it on the glossy paper! I've also seen where people use the same technique on fabric.
kandiceaz
3 years ago
I just have to try this for our next charity card event. thanks so much for sharing.
rflowers2
3 years ago
I can't wait to give it a try, thanks for sharing :-)
Tait_Clements
3 years ago
I love this idea and it's numerous other applications. I'll have to see if I can add it to my growing list of things to try. :)
