Paperduino Tiny
22,828
224
12
Build Arduino compatible board on piece of paper.
Paperduino Tiny is very cheap and easy to build Arduino compatible board with USB and software compatible with Digispark board.
Paperduino Tiny include an ATtiny85 microcontroller and come with USB interface. Coding is similar to Arduino, and it use the familiar Arduino IDE for development.
Can be build in 1 hour for aprox. 4 USD.
Specification:
Support for the Arduino IDE 1.0+ (OSX/Win/Linux)
Power via USB or External Source - 5V
Built-in USB (and serial debugging)
6 I/O Pins (2 are used for USB only if your program actively communicates over USB, otherwise you can use all 6 even if you are programming via USB)
8k Flash Memory (about 6k after bootloader)
I2C and SPI (vis USI)
PWM on 3 pins (more possible with Software PWM)
ADC on 4 pins
Power LED and Test/Status LED (on Pin1)
NEW - Paperduino Tiny build in case from Tic Tac mints - look to the pictures...
Getting started
Tools needed
Parts needed
Burning bootloader
Building Paperduino Tiny step by step
Installing Arduino IDE
My first sketch
Complete tutorial can be found in Paperduino WIKI.
Please vote for me in Arduino Contest. Thanks...
Supplies:
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    12 Discussions
    deguich
    2 years ago
    Paperduino WIKI offline ?
    jjsims
    4 years ago on Introduction
    am looking forward to making this. am new to the arduino world, but want to give it a shot.
    bill2009
    4 years ago
    Wow - excellent!
    bigwcharly
    5 years ago on Introduction
    Hi. Thanks for this nice project.
    I was wondering why you chose to use 3v6 zener diodes and actually if they are necessary at all? Is this to clean the USB signal or is there another reason? Many thanks!
    ok1cdjbigwcharly
    Reply 5 years ago on Introduction
    The USB datalines are in 3.3 V logic level. Zener diodes can limit the output voltage on D+ and D-. We recommend 3.6 V low power types, those that look like 1N4148 (usually 500 mW or less). Low power types are required because they have less capacitance and thus cause less distortion on the data lines. And 3.6 V is better than 3.3 V because 3.3 V diodes yield only ca. 2.7 V in conjunction with an 1.5 kΩ (or more exactly 10 kΩ) pull-up resistor. With 3.3 V diodes, the device may not be detected reliably.
    bigwcharlyok1cdj
    Thanks for your explanation. I've also found more information here about the need to pull the signal voltage to 3.3V:
    http://www.beyondlogic.org/usbnutshell/usb2.shtml
    Just for my understanding: Am I right that the capacitors serve to filter the supply voltage? I was also wondering why two capacitors are needed. I guess this has something to do with filtering different frequencies (e.g., the large cap filters out low frequencies, and the small one the high frequencies)?
    ok1cdj
    Resistor R1, R5 connected to LEDs can be from 330 ohm to 1500 ohms.. I'm using 1500 ohms for simplicity. In circuit are used only 2 values of resistors. When you have 330 ohm the current throught LED will be higher than with 1500 ohms..
    MakersBox
    Are the values for the LED resistors (R1, R2) correct? I would expect 330 ohm.
    dsur
    Good idea, but why you not present all steps here in instructable?
    Where can suggest some modification?
    For example install piece of copper tubule in holes, and solder component ends to it. Also using electrically conductive ink.
