Paracord Fishing Bracelet
5,887
120
10
You are in the woods hungry and cold. You lost your fishing pole in the nearby river. Luckily you had you survival fishing bracelet. It contains enough fishing line to help you fish for food until your rescuers come.
Step 1: Materials
You will need:
16 feet of paracord
200 feet of 50 lb braided fishing line
A knottology guardian expedition clasp
3 hooks about 3/4 of an inch long
A bunch of split rings
Other things you want to put in the clasp
Tape
Scissors
Lighters
Step 2: Start
Remove the inner strands of the paracord.
Step 3: Inserting the Fishing Line
Cut 20 9 foot strands of fishing line if you are using two colors. 10 17 foot strings if you are using one. Feed them into the paracord sheath. If you are using two colors burn one colors end and fray the other. Insert the burnt end into the other one and singe that end. You can also secure this more with a knot.
Step 4: Starting the Weave
Pull the cords down through the clasp and the pull the ends through the loop. Then, pull the ends up through the other side of the buckle. Now you should bring the ends back through the original clasp side. Measure your wrist. Pass one end behind the base and over the other cord. Then pass the other cord through the loop.
Step 5: Adding the Split Rings
Take the split rings and string them onto the cord. Then make a weave making sure the rings are in the middle.
Step 6: Adding the Hooks
Put tape on the hook then wrap the tape all the way around the base. Go down a little and repeat.
Step 7: Finishing
Wrap the last three weaves lightly and pull the ends through the top. Flip it over and pull the strands through the loose weaves tighten the weaves. Snip and singe the ends and fill the clasp. If you enjoyed this instructable please vote for me. If anything is unclear leave a comment and I will try to help!
Step 8: Making a Lure
Cut one long piece of fishing line and 5 3 in pieces. Also cut a 2 inch piece of paracord. Fray the cord a little. Wrap the long cord around the short pieces and the hook and then wrap it around the paracord and tie a knot to finish.
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    10 Discussions
    overcomer8
    4 years ago
    Awesome project! Can you tell me where to get clasps that open and you can fill..thanks!
    Survivorkidjr
    5 years ago
    Where do u get those kinds of Buckles and how much. I love the idea. Thanks
    DMANTHEROCK
    5 years ago
    I've been thinking of my own design for the ultimate survival bracelet for a couple of weeks now, and have some ideas. The way you incorporated all your parts was smart, but you could have weeved all of it inside, and instead of strippi g the paracord of its guts and lossing alot of strength, you could laid the fishing line in the center. I want to incorporate a knife, flint, and maybe a few other things into mine. gave me some ideas tho. thanks.
    anyonehavethisname
    5 years ago
    Thank you! The buckle you can buy from paracord planet or amazon. It costs a pretty penny. I have seen them for between 8 to 10 dollars.
    anyonehavethisname
    5 years ago
    Thanks. The swivels and split rings can be used to make traps and other things.
    guitarman96
    5 years ago
    Pretty good idea I do something less complicated just hooks and braid for me no swivels or split rings
    Mattakers
    5 years ago
    I like the idea of replacing the "guts" of the para cord with fishing line!
