Paracord Wrist Lanyard Made With the Snake Knot
1,225,499
1,970
121
About: No matter where you go, there you are.
This instructable will show how to make a wrist lanyard using paracord and the snake knot. The lanyard can be used to secure a key chain, knife, multi-tool, flashlight, cell phone, camera, binoculars, compass, etc. More projects, links, knot references can be seen on my blog page, Stormdrane's Blog.
Step 1: Supplies
You'll need about 4.5 feet of paracord(you may use other types of cordage if desired). The paracord I used is from the Supply Captain. I left the inner strands in the paracord, but you can remove them if preferred. If done in one color, it will be one continuous 4.5 ft length, if done in two colors, you'll need 3 ft for the primary color that includes the wrist section, and 1.5 ft for the second color that will show in the snake knot. Also used are scissors, tape measure or ruler, lighter, hemostats or needle nose pliers(not necessary, but they make it much easier), and a swivel clip, key ring, snap hook, cell phone lariat, carabiner, or whatever attachment you prefer to use.
Step 2: Attaching Two Colors of Paracord
If using two colors of paracord, you will insert one color about 1/2 inch into the other color. You may remove a small amount of the paracord's inner strands by pulling them out, trimming with scissors, and pulling the paracord outer sheath back over the strands, leaving room to insert the other color. For various projects, I've used three different methods for attaching two colors of paracord: melting, sewing, or gluing. The choice is yours, I usually sew them together, it doesn't matter as long as it's a good connection. It will be hidden under the first knot.
Step 3: Find the Center of the Length of Paracord
Take the center of the length of cord and bring it thru the attachment, I'm using a swivel clip. For this tutorial I'm measuring the wrist loop at about 10 inches from the attachment. The connection of the two colors will be just on the other side at this point.
Step 4: Making the Snake Knot
The snake knot will be made 'around' the wrist loop section of paracord, the loop strands being the 'core' of the knot. I've added a series of photos showing the steps I use. By using two colors, you'll see that I flip the lanyard over after making each knot, so that I'm working with the cord on the right side of the lanyard. I bring it under all the other cords, working the hemostats under the previously tightened knot and pulling the cord back thru. Then tightening up the knot keeping the cord from twisting and working it up against the previous knot. Again flipping the work over, you'll see two parallel cords of the same color which will be split with the cord on the right going under, around, and pulled thru with the hemostats, then tightened up. Continue this procedure until you've done about 10 snake knots(you can count them down either side.
Step 5: Count Your Knots
Once you have 10 snake knots you're almost done. You'll notice from the photos of both sides of the lanyard, that one side has the snake knots alternating all the way down and the other has a set of parallel knots at the top and botton of the sequence of knots. You'll always have those at the start and finish of the snake knots, I prefer to have them end up on the same side of the lanyard so one side appears to have a more uniform look, but it's not required.
Step 6: Trim and Melt the Excess Paracord
Use the scissors to trim off the excess cord and quickly melt the ends with a lighter so they don't fray.
Step 7: You're Done!
You can make a range of variations using less or more cord/knots. Shorten the loop for a double ended key chain or make the loop longer for use as a neck lanyard, a Lanyard Break-Away Connector could be added for the safety conscious. You can also add a wooden bead, skull, cord lock, etc. Visit my blog page for more knot related projects, links, and resources: Stormdrane's Blog. You can find ideas for other gear/gadgets to attach to your lanyard on EDC Forums.
18 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
121 Discussions
KirtS1
2 years ago
I must be dense... the photo's do not show the ENDS of your paracord...so to me it looks like you have FOUR pieces of cord to form the snake knot..... how you do that?
StormdraneKirtS1
Reply 2 years ago
You're seeing the loop end and the two working ends that are tied around the loop end. ;)
denacho
3 years ago
i am already lost on Step 2. i cannot get one cord into another. ugh!
Domsurfs
3 years ago
Hey mate there is a lanyard you have done with a snake knot and some sort of other knot. It is yellow and black. Could you please tell me how to do this type thanks
DavidL117
3 years ago
Cool, thank's!!
photo-30.08.15 20:50.jpg
chickybut1
5 years ago on Introduction
just wanted to say thanks again for the pattern. I made them as neck lanyardsRad"s FX lighting and production crew for with neon green and silver with reflective tracers. anyway we are doing the lights and sound for DANCEFESTTOPIA and we had "IMPORTANT" people coming up wanting to see them and asking where to get them. Anyway I thought that was pretty cool. Who knows I may get some orders from it all. Just wanted to share that story with you and say THANKS again. I made sure to let every body know that I learned this knot from your instructable.
chickybut1
the hardest part about these tutorials is that everything is right handed and I live in my own left handed world. any suggestions? I really need some. It is very hard to think right when all you know is left.
Stormdranechickybut1
Reply 5 years ago on Introduction
Some photo programs let you flip/reverse images, so if you're going by the instructable photos, you might try saving the images and flipping them to see if that helps.
With my dad being a lefty, I know the 10% of the population that's left handed do suffer somewhat in a right hand world.  :)
chickybut1Stormdrane
thanks for the advice. everyone in my family makes fun of me because I do everything backwards. according to them : )
normski2000
5 years ago
Great tutorial dude!
StormdraneGunner7800
Reply 6 years ago on Step 7
I've not tied the snake knot that way, but if you tied it around a separate loop of cord or start with making a loop first,  maybe like these slip-on type paracord bracelets, you could have the end finish right up against the start, where it may not be very noticeable and give the look of a continuous loop...
mbreukel
7 years ago on Introduction
really nice knot! just made mine, with woodland and black.
i was wondering, of you take enough cord, could you wrap things with it? like a lighter?
Stormdranembreukel
Yes, you can make the knot around other objects as the core of the knot, like a lighter, walking staff, flashlight, knife handle, etc...
