Mini Pcb Cutter
2,137
23
6
About: radom diy projects
diy a mini pcb cutter
Supplies:
Step 1: Meterials
i use meterials from printer,hdd,cd rom.
1,2 are from a 2.5'' hdd
3 is from a cd rom
4 is from a printer
Step 2: Disk Holder
  • place the ball bearing to the axis (must be fit perfectly)
  • add instant glue carefully
  • place (the other thing with the screw) (must be fit perfectly)
Step 3: Bearing Holder
  • place the motor
  • make a paper mold and fill it with hot glue (attention to the ball bearing)
  • place off the paper mold
Step 4: Cover
  • screw 4 screws (adjust the right height)
  • place 4 magnets at the top off the screws
  • find a nice plastic for cover and glue it with hot glue to the magnets
Step 5: End
  • connect it with a power supply.
  • the motor must run opposite the disc's screw
this runs on 32v (printer's power supply/motor)
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    6 Discussions
    jmatsson
    1 year ago
    i would guess that the melt glue that is used to hold the axis would get warm from friction and get out of shape?
    A more heat stable solution in the same spirit is some self setting silicone rubber perhaps, (or a piece of acrylic with a hole drilled).
    Otherwise I like the project a lot. Good job!
    andreash79jmatsson
    Reply 1 year ago
    You are right, until now it is ok but it could have better materials
    thanks a lot!!
    TomK32
    1 year ago
    Nice idea, though a simple gear would help to lower and hide away the motor and while you are at it, a suction fan underneath the board to avoid the dust getting everywhere would make it just perfect.
    andreash79TomK32
    Reply 1 year ago
    thanks for the idea ..the dust is a problem!
    better with gears or belt, but i don't have ! this i make is easiest...
    TomK32andreash79
    Reply 1 year ago
    one problem i had last year was cutting the same width a few times, a few holes to mount a guide (a metal piece you'd mount a cd drive with in a pc does the job) helped with that.
