Pedal Powered Sling Shot
This is a giant sling shot that I built at Penn State.  The sling shot is pulled back by pedaling on a bike that is connected to the frame.  Yes, it would be easier to just pull it back by hand, but the purpose of the project was to have something pedal powered. It was actually very difficult to load the slingshot by pedaling, even in the lowest gear.  It would help if the back wheel was much smaller in diameter, but we did not have enough time to retro-fit our bike.  To keep the rear wheel from unwinding under tension I just jammed a piece of pipe into the spokes.
I did a rough design of the sling shot in SolidWorks before starting the build. The frame of the sling shot is built out of black iron pipe.  This was the simplest material to use, since I knew what lengths I needed and the hardware store threads the end of the pipe for free.  The sling shot band is latex tubing, also available at the hardware store.
The pouch is made out of duct tape.  I have tried other materials for pouches in the past (on other slingshots) like old towels, place mats, t-shirts, etc.  But the duct tape has proven to be the strongest and easiest to fabricate.
To fire the sling shot, I made a quick-release out of some wood and a linch pin.  The quick-release did not work as smoothly as I had hoped, but it got the job done.
Here is a video I made showing the sling shot "kicking" field goals.
Supplies:
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    35Timmy
    6 years ago on Introduction
    like the creativity and constructiveism now that's using your head great just like some of my ideas execpt i never had invented a pedal powered slingshot.
