Pen Gun
60,200
12
25
Here is a really simple pen gun than is quite powerful and has a range of 20+ feet. I finnaly got around to making this instructable so I hope its alright
Step 1: What You Will Need.
you will need,
1.cheap Bic roundstick pen
2.sand paper
3.very small nail
4.lighter, candle or small drill bit(same size as nail) and drill
5.Plastic report clip.(peice of plastic that clips onto papers to hold them together but you can use about anything that can fit in the pen, blocks part of it off and can be cut to size)
6.Retractable Sharpie. (we need the spring from it)
7.pliers
Step 2: Ready the Pen
Remove tip and ink tube.
Step 3: Remove the Ink Tube
Remove the ink tube
Step 4: Sand the Tip.
sand the tip of the pen so it can slide out of the pen tube easily.
Step 5: Savage the Sharpie
Take apart the sharpie and remove the very large spring that fits perfectly in the pen tube.
Step 6: Ready the Spring
put a small piece of tape on the sping so it doesn't fly out when fired.
Step 7: Fire! Fire! Yea! Yea!
use a candle or lighter to heat up the nail.
Step 8: Make a Hole
make a hole through the pen tube and cap with the hot nail. (here is where you can also use a small drill bit.)
Step 9: Make Spacer
cut your material (peice of binder clip, plastic etc.) so it is to size so it leaves room for the tip and fully compressed spring
Step 10: Aim and Fire
to load the gun just put the spring in the pen and jam the tip on the sping and insert the nail to lock it in place. to fire just aim and pull the pin
    • Epilog X Contest
      Epilog X Contest
    • Sweet Treats Challenge
    • Remix Contest
      Remix Contest
    25 Discussions
    inoname
    4 years ago on Introduction
    It is good but only fires up to 20 feats check mine it fires up to 80 feats at
    https://www.instructables.com/id/pen-gun-15/
    M4industries
    9 years ago on Introduction
     After a few weeks of refining our design in our spare time, my friend and I made one that shoots 120ft and fired a sharpened knex piece out of the pen casing. It shot through quite a few pieces of cardboard. We used 4 rubberbands as a membrane.
    mo5
    10 years ago on Introduction
    do you put the spring in first or do you put the pencil in first
    I made on of these once... the only difference with mine is instead of shooting pens i just fired the ink tube. Also, i used a rubber band instead of the spring.
    true, but think about it, how are they advanced? i can make a hole with my hand. now something advanced, like a helicopter, now we may have problems making a heli with a hand.
    true, u have a point. but like i said, how are they advanced? things like boats and aircraft are advanced, holes are the building blocks for those kinds of things. holes themselves aren't advanced in any way. they've been around before our solar system was created.
    I hate that commercial too. "Introducing the new advanced quick release system" They drilled holes in pills, I chew them, big deal. If they put microchip cellular inhancing nanobots in the holes... Thats advanced! Also, I have a tri pen that when you twist the clicky thing it goes from pen to mechanical pencil to computer touchpad pen. I'm looking for a pen shooting instructable I can mod with this so that I can have three rounds in one "clip". ~Peace
    badhacker
    11 years ago on Step 1
    looks kinda complicated for a pen gun but it so cool when it shoots!
    pyro22
    11 years ago on Step 6
    :-) yea I know. I have a dog and cat who were shedding at the time and we hadnt vaccumed for a couple days.
    tzual
    11 years ago on Introduction
    and.... do you put the yellow thing inside the pen and push it against the spring?
