Penny Knife
4,985
42
7
Welcome back! I have just made a small knife out of a penny! It isn't good for much more than letter opening but it's still pretty cool! This may be illegal where you are though it isn't here cause Canada doesn't have penny's anymore. Let's get into it. I also made a video! I will make one for all my coming instructibles! So make sure to subscribe! https://youtu.be/QCSlhZ5Kta4
Supplies:
Step 1: Marking and Drilling
Glue all of the penny's together then mark three dots about where I did. Then drill with a 1/16 drill bit on those holes. Use a drill press but if you don't have one then you can use a normal drill bit the bit will probably break. Since mines broken I can't show the drilling.
Step 2: Cutting the Penny
Next you need to disconnect the penny's from each other once you have all the pennys apart you need to cut the middle one down the center so that one hole gets cut off. Remember what holes line up to each other
Step 3: Cut the Blade
You can cut the blade out of a shingle cutting razor blade. One of the curved ones cut it and grind down so that it fits into the half penny. Also grind the back so it's round and can fold.
Step 4: Add Pins
Then you can add copper wire as pins to hold it all together. Just push them in and cut them. Then hammer them down so they are flat.
Step 5: Done!!!
Sorry that this isn't like my usual ones guys.
  • Fandom Contest
    Fandom Contest
  • Arduino Contest 2019
7 Discussions
mhdguy
2 months ago
just a quick note: do not carry something like this in Canada as any blade under 30 cm in length is illegal to have if it does not look like a traditional knife thus making belt knives comb knives and coin knives illegal but oddly enough a cane sword would still be legal
mrsmerwin
2 years ago
if you add a jump ring, it would look nice as a pendant.
ZiggyBaggins
2 years ago
I made an instructable exactly like this one about a month ago. Did you find Miller Knives tutorial, too?
TheTutor11
2 years ago
I am not sure if it's legal to destroy our pennies
TheTutor11
2 years ago
Hmmm no pennies. I will check with the federal reserve where I live.
DIY-Guy
2 years ago
Coin cutting is not illegal in USA, only defacing for the intent of fraud to change the value of a bill, such as adding a zero onto a one dollar bill to change the apparent value for fraud.
Coin art is legal, you do own it completely and it's yours to do with as you will.
