Pentagon Ufo Fire Bowl
4,426
51
4
When we tidied up our workshop, we found a couple of old steel plates, but what to do with it?
We got the answer when we were sitting in the garden at the night and when it was going to be cold.
So we went to the workshop next day and build this awesome fire bowl out of old steel plates.
This is our first instructable and we hope it isn't to bad :D
Step 1: Materials and Tools
For this project you need:
  • some steel plates with a thickness of about 5mm
  • an angle grinder with a grinding wheel and cutting discs for steel
  • a welding mashine (we used a gas shielded welding mashine)
  • something to measure the angle
  • a ruler and a pencil
  • clamps to hold the pieces on the desk
Step 2: Cut Out the Parts
You need:
1x bottom plate
5x sides
3x feet
Cut the parts out with the angle grinder and grind the edges in case they are sharp.
Step 3: Assemble the Frame
Weld the sides together with an angle of 108°. For this we cut a piece of wood to 108° to use it as a stencil.
Step 4: Adding the Bottom
When you finished the frame successful, you can add the bottom. Before you weld it, test out if it fit perfectly. If it does'nt (like in our case :), grind it until it does. Weld the bottom on every side like in the picture.
Step 5: Put on the Feet and Finish
Mark the middle of the bottom and sketch three lines for the feet with an offset of 120°. Weld them on and if you want, paint it with some fireresistence paint.
If you like this project and want to hear more from us, follow us and vote for us!
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    4 Discussions
    CarlS110
    1 year ago
    I'd put some holes in the bottom for drainage. It'd be a shame to have it rot through in a year or so.
    mxx
    1 year ago
    Nice design and very useful!
    seamster
    1 year ago
    This looks excellent! I need to make something similar. Thanks for sharing your process :)
