Phone Charging Station
74,707
682
18
The aim for this project was to reuse some scrap wood and an unused charging cable. I despise tangled wires, regardless if they are from my headphones, chargers or other technical devices. Therefore I wanted to create a little, neat looking charging station, which i can put on my desk.
The whole project is cheap and easy to make. Furthermore can it be completed within an afternoon.
Supplies:
Step 1: Gather Your Materials and Tools!
Materials:
  • Scrap wood
  • Charging cable
  • Velvet tape (optional)
Tools:
  • Saw (some kind of saw, I used a chopsaw)
  • Sandpaper
  • Sand Paper
  • Drill
  • Adequate safety gear
Step 2: Make a Plan
If you want to make your station perfectly suitable for your own smartphone, you have to measure the dimensions of your phone. So you start off making some measurements. At this point your project is completely up to you. Be creative, you can make whatever shape you want. I wanted mine to have a simple and minimalist design.
Step 3: Rough Cut and Gluing
I wanted mine to be about 4,5 cm in height, however my scraps are just about 1.5 cm high, therefore I cut out three pieces, which are roughly the desired size, to glue them together and achieve the right height. To glue them I used some wood glue and some clamps.
Step 4: Final Shape
As soon as the glue has dried, I cut the block into my favoured size using a chopsaw. After that I had a nice little wood block with 6 neat surfaces.
Step 5: Cutting the Slot
To give the phone a good support, I marked a slot onto the wood, where I could later on stick the phone into. To cut it out, you can either use some machinery, like a chopsaw or a mill for instance. Nevertheless you can do it the old fashined way, by using a hacksaw, as well.
Step 6: The Conduit
Now comes the more tricky part, however it is not too bad. If you want to hide your cable inside the block, you have to drill a canal, which lets you insert the cable and is just big enough to fit the port, but is not visible from the outside. This step requires some patience, if you want to make it perfectly. If you drill the hole a little bit too big, so that the port does not hold by itself, you can fix it by using some super glue. Do not forget to try if the phone fits, before you fix it permanently.
Step 7: Footing (optional)
To cover the base I used some spare velvet tape. Simply cut it to size and stick it on. This lets it look even more valuable.
I hope you have enjoyed my little instructable, and maybe try it out yourself.
  • IoT Challenge
    IoT Challenge
  • Fandom Contest
    Fandom Contest
18 Discussions
langallssoybillc
Reply 2 years ago
near field communication (NFC) technologyand the smart tags that work with NFC.
NFC isn't a fundamentally groundbreaking technology. Like Bluetooth and WiFi, it's a wireless radio communications standard. In the wireless world, NFC's closest relative is actually RFID (radio frequency identification).
afifdanish
3 years ago
great idea dude
Albert BorlandMarianoM3
Reply 3 years ago
No I did not do anything to alter the cable. I just drilled the hole in the bottom to be big enough to insert it with a little bit of gentle force.
Ismegordo
3 years ago on Introduction
What a FANTASTIC Idea.
I an thinking that I use this idea and convert it to suit my iPad.
It really is a Great Idea
Thanks for Sharing
P.s. I will Post some pics, after I have Completed
SteveB36
3 years ago
I made this for my old phone a few months ago
JayS9
3 years ago on Step 7
Nice job! I've got a few pieces of mahogany sitting around that I might do something similar with! My only change may be to groove out the conduit cable into the middle section of wood beforehand to keep the bottom clean and flat. Then still in from your phone groove into the pre-made channel. Thanks for the ible!
rafununu
Simple and "design" !
NFC is a very good idea as well.
ewagstaff
3 years ago
nfc tag on top would be. a nice little add-on. making it so as that nfc turns your phone on silent, sets alarms, etc.
Jaii
3 years ago
...can elegantly be made as a personal gift with receiver (individual or/and org's) name engraved...
dsexton8
3 years ago
Very cool. So many possibilities
