Photography Light Box Tent
12,070
354
If you are an enthusiast photographer, you probably have
tried couple of lightning techniques before. One of the most common tools that product photographers use is the photography tent which we will make in this project.
For the 2D-design we will be using Inkscape because it’s free and easy to use software (you can download it from: https://inkscape.org/en/ ). We will also use BoxMaker (http://boxmaker.connectionlab.org/) to design our tent box. Then we will cut the parts using CNC machine (we used MDF wood)
Note: This project was made by (Jafar Alobaid ) in FAB LAB Dhahran
Step 1: Requirements
• MDF wood (Thickness 12mm)
• Vinyl paper
• Duct and black tape
• 3 natural daylight led bulbs ( or any alternative)
• paper scalpel or craft knife
• Tracing paper
You'll also need:
CNC machine.
Step 2: Making the Box
So, for this step we will make a 50 X 50 cm box using
box maker. We will adjust the faces of the box so that each one will become a frame except the one that will be in the back (Background) and ground one as well.
Note: we used 12mm MDF wood. Just make sure to adjust the material thickness according to what you will use.
After makingthe box we will use inkscape to edit it. So, it will look like this
Step 3: Step 3: Making the Lights’ Arms:
There are couple of different ways to design the arms. But we will go with the easiest and the most practical. we have attached the designs and the dimensions with this step.
Step 4: Wiring the Light Bulbs
You can just wire it just like what we did in the pictures.
Note: the current we have is DC. Just make sure to know the difference between the AC current and the DC current.
Note: we wired each light bulb alone. they are not connected in one wire. it's up to you if you like to connect them all in one single wire or make them separate.
Step 5: Testing the Product
Here is the final product with some results.
Note: The sunglasses photo was taken by iPhone 5 camera.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    2 Discussions
    NeilP9
    2 years ago
    If you use 5 sheets of translucent corrugated plastic card then you don't need any cardboard box. Just buy 5 pieces, cut them as you wish, with equal sizes to
    make a cube or different sizes to make a box of different sided
    dimensions - mine has a rectangular cross section.
    You can stick the box together with scotch tape or cloth tape.
    One sheet where I live cost me a dollar equivalent, which is in Thailand BTW.
    Or you can put pins through the thickness of one side down the elongated channels in the other piece.
    NeilP9
    2 years ago
