IOT BIT (Formally Known As PiAnywhere V1.31) 4G & LTE Hat for the Raspberry Pi
30,069
88
48
About: Altitude Tech LTD is founded by professionals and students in the area of robotics, electronics and product design, which makes the team the heart of the company.
IOT BIT 4G & LTE Hat for the Raspberry Pi
4G (100 mbps down/ 50 mbps up) – Ultra fast internet connectivity for your raspberry pi, excellent for large downloads and video streaming.
TheIOT BIT 4G & LTE Hat for the Raspberry Pi Beta provides 4G mobile data for the Raspberry Pi mini computer. Our intelligent HAT module provides your Raspberry Pi with mobile data, GPS positioning information and battery support. This is the perfect module for hackers, scientists, and creators as it gives your Pi powerful connectivity wherever you are. Simple plug out module into your Raspberry Pi and start playing.
Find out more & order at https://altitude.tech/shop
The HAT can integrate easily with the software on your operating system giving you access to general internet data through the mobile network. Using our API this hat gives you the ability to send SMS (text) messages. We also give easy access to the GPS onboard which exposes location data.
HAT Features
  • Supports any nano sim. Slot your sim card in and get going
  • 4G Mobile Data for the Raspberry Pi
  • Easy set-up, with a single terminal command setup our software to streamline Pi Anywhere with your Raspberry Pi.
  • Wake up your Pi or trigger events with text messages.
  • Optional external antenna for better reception.
  • High-efficiency power regulation up to 3 amps.
  • Use for external projects with a solar panel and battery pack.
  • It can be used in conjunction with our Sensly gas monitoring HAT
Step 1: Whats in the Box?
Step 1: Parts in the box
  • GPS Antenna
  • 1 4G antenna,
  • 1 3G antenna.
  • USB cable to connect to the Raspberry Pi.
Step 2: Put PiAnywhere Together With the Raspberry Pi
  • Raspberry Pi wall plug Into IOT BIT to power both IOT BIT and Raspberry Pi. ( You don't need to also plug in the Raspberry Pi).
  • Put the 2 antennas and the GPS antenna into IOT BIT.
  • Sim card into the IOT BIT (which you can buy from any major sim provider )
  • USB into the modem to connect to the Raspberry Pi.
Step 3: Setting Up the Raspberry Pi
Components needed for the Raspberry Pi to be operational:
  • Raspberry Pi 2 or 3.
  • Monitor.
  • Mouse and keyboard.
  • HDMI Cable.
  • Raspberry Pi Charger.
  • SD card (more than 8GB is required) with the latest version of Raspbian Jessie.
The guide to setup the Raspberry Pi software can be found at https://www.raspberrypi.org/learning/hardware-guide/
The latest version of the Raspbian Jessie can be found at https://www.raspberrypi.org/downloads/
Step 4: Connect the IOT BIT With Your Raspberry Pi
  • Connect the 40-pin of the IOT BIT with the 40-pin of the Raspberry Pi.
  • Connect the USB from the modem of the IOT BIT to the USB Slot of the Raspberry Pi.
  • Connect the Raspberry Pi charger to the power pin of the IOT BIT, the IOT BIT will power your Rasberry Pi.
  • For the IOT BIT to power, the Raspberry Pi, press the button that states PWR (power) in the IOT BIT.
Step 5: IOT BIT Easy Setup
There are multiple ways to get this up and running. The first is to download the disk image and flash it using Win32 Disk Imager. You will need an SD card that is 8GB or bigger. The link for the download is below:
https://download.altitude.tech
To use turn on the IOT BIT by plugging in the power cable to the USB port labeled 5V Power. Next, we press the button marked btn to turn on the modem. We then connect the other USB port to the raspberry pi and finally turn on the raspberry pi by pressing the pwr button.
Also, you can use IOT BIT on a windows system. All you have to do is use these drivers and install them: https://drive.google.com/file/d/0B4StAjolU_LeVjRx...
Step 6: Downoad and Install the Software.
Once the 2 boards are connected successfully and the power LED is on. The next task is to download the correct software for the IOT BIT to work with the Raspberry Pi. Using the latest version of Raspbian Jessie is recommended.
Open the terminal and type:
This should take around 30 minutes to complete as installing the kernel headers takes a long time. But once this is completed and your IOT BIT is connected via USB to the Raspberry Pi you should be able to run
  • lsusb | grep Qualcomm
And see a Qualcomm device connected. As a final check you can also run
  • ls /dev/ttyUSB*
And see 5 usb devices connected these are the virtual com ports for the modem.
Step 7: Set Up Wvdial and Connecting to the Internet
One of the important features of the IOT BIT 4G is its ability to connect to the internet using the mobile network, but for that, it needs to be configured to do so. This step will cover the link between the IOT BIT and the internet using the sim card information.
Now we need to configure the wvdial.conf file to enable IOT BIT to connect to the internet using your sim card. You will need the USSD code used to fetch the sim cards registered number. For example, on giffgaff this code is *99#. Or you can just use the sim cards phone number if you can't find the USSD code but just remember you will have to edit the file to change the number if you change the sim.
So we will need to open the file found in the iotbit_Install folder called wvdial.conf using a text editor of your choice.
  • sudo nano /home/pi/iotbit_Install/wvdial.conf
Then add to the file your USSD code or phone number in the 'Phone =' field. Then save and exit the file by pressing ctrl+x then y
We now need to move this file to the correct place to the system can find it.
  • sudo mv /etc/wvdial.conf /etc/wvdial.conf.bak
  • sudo mv /home/pi/iotbit_Install/wvdial.conf /etc/wvdial.conf
  • sudo wvdial
This last step takes around 30 seconds. If successful, you should be connected to the internet with your Raspberry Pi. Congratulations!
Step 8: Setting Up the Network Interface to Use the Modem Automatically
To enable the Pi to connect IOT BIT to the internet using the mobile network automatically, we use the following steps.
First, open the file called interfaces using:
  • sudo nano /etc/network/interfaces
Then add the following lines at the bottom of the file:
  • auto ppp0
  • iface ppp0 inet wvdial
Then reboot the Pi, ensuring that the PiAnywhere is on and the Modem USB port is connected to the Pi.
  • sudo reboot
If successful when the Raspberry Pi boots you should be able to connect to the internet using your IOT BIT.
Step 9: Enable the GPS
The IOT BIT has the GPS feature, but it needs to be activated. First, minicom needs to be installed in order to test the GPS. This is done by using the following command:
$sudo apt-get install minicom
This is a terminal that operates in the command window, enter the minicom terminal using:
minicom –D /dev/ttyUSB2
In order to operate the minicom press CTRL+A and then Z, this will show all the different options that can be used. The echo local will need to be enabled. This is done by pressing CTRL+A then E. Once this is enabled you can enable the GPS this is done by typing inside the minicom terminal:
AT+CGPS=1
It will show a message of Ok!
The to get the information of the GPS location use the following command:
AT+CGPSINFO
Step 10: Congratulations!!!!
You have now gotten IOT BIT working, and you can do some amazing experiments with it. We are also running competitions for Instructables. If you buy an IOT BIT from us Pianywhere.com and you write an instructable about your project then we will give you up to 100% of your money back depending on the quality.
When you finish just tag us in it so we can take a look.
2 People Made This Project!
  • Build a Tool Contest
  • Warm and Fuzzy Contest
  • Organization Contest
48 Discussions
Hamids
Question 7 months ago
thanks for sharing this projet, however is it possible directly connect the camera directly with Sim7100 and have video streaming while control the Sim7100 module with host MCU?
Hamids
hi
is there any schematic or eagle file for any development board of 7100E series ?
ZachB70
1 year ago
Just got mine up and running. The clocking of the SIM card is a factor I think for some and is not obvious. When the sim is installed correctly the blue network light flashes as opposed to being constantly lit.
I found for AT&T (US) that adding a APN init line was required to make a connection.
I have also got the GPS running ( downing the Modem and issuing the init command worked for me) and plan to use gpsd and traccar to do location tracking.
Thus far I am only seeing 10Mbps/3Mpbs speeds, but it likely is my locale.
In general a very nice HAT. I would LOVE to hear from @Altitude Tech on how to bypass the buttons and do auto startup for both the network and the PI. This is going to present a real challenge for a remote box. I did read about the microcontroller option below, but that seems like a horribly complex solution to what can likely be solved in firmware.
AndyG149ZachB70
Reply 8 months ago
anyway you can help me understand how you got gps working? I can bring down the dialer and then bring up minicom or run an active dialer and then bring up minicom. I've tried on USB1 2 and 3 and no matter what situation or combination I cannot get a 'OK' response for activating the gps module. This board has proved to be very finicky with regards to process of activation. I'm curious how you made this work?
mdaigle61
10 months ago
Hello Everyone, I finally succeeded with the IOT-BIT 3G with a Bell Canada account (i.e. North America version) ... After many trials, I finally figured out that the SIM card has to be inserted the cut corner facing the antenna connectors... which is not the "normal" standard since the corner cut should be located on the right side of the slot. Make sure that the "contacts" are facing the down :-). As explained into another post, the modem is working when the blue led is flashing. I think IOT-BIT is a good product and has been well designed. I'm also a hardware manufacturer and customer service should always be the first value of any serious company... If Altitude Tech may insert this value into their day-to-day work (i.e. answering emails, helping people to use their product, etc.) this would be a terrific product and they would sell a lot of them... Hope this will happen... I would order several dozens of them. Cheer, Mike (Montreal, Canada)
tarugg52
Question 11 months ago
I have the Americas version of this device (USA), to be used to add remote communication / file transfer capabilities to a sensor deployed several miles from my location. Are there any current suggestions/recommendations for SIM cards that will work with the device?
ramomi
Question 1 year ago on Step 7
hi
after wvdial configuration
I get error
--> WvDial: Internet dialer version 1.61
--> Initializing modem.
--> Sending: ATZ
ATZ
OK
--> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
ERROR
--> Bad init string.
--> Sending: ATZ
ATZ
OK
ERROR
--> Sending: ATZ
ATZ
OK
ERROR
cbaquol
1 year ago
I purchased this device under the impression that it would work on any US carrier (because it says that it does in the product description) and after countless hours of setup, and countless more communicating with the Verizon rep, and a week of waiting for approval, I was told this cannot be added to the Verizon Wireless DMD and is NOT approved to be used on their network. I have reached out to Altitude for support while I was troubleshooting and never heard a peep once. I would stay away until this is further developed and the product description is updated to reflect accurate information. Please refund my money ASAP.
My unit isn't working and PiAnywhere (Altitude.pw) isn't helping. They stop responding my emails 10 days ago.
This instructable steps didn't worked. The vendor states the firmware need to be upgraded but it isn't working too.
I feel my money has been wasted.
$ dmesg | tail
[ 30.287958] usbcore: registered new interface driver usbserial
[ 30.288013] usbcore: registered new interface driver usbserial_generic
[ 30.288060] usbserial: USB Serial support registered for generic
[ 30.302848] usbcore: registered new interface driver Gobi
[ 30.302910] usbserial: USB Serial support registered for GobiSerial
[ 30.302922] GobiSerial: 2011-07-29-1026
root@raspberrypi:/home/pi/PiAnywhere_Update# ls /dev/ttySO /dev/ttyAMA0
/dev/ttyAMA0 /dev/ttySO
root@raspberrypi:~/PiAnywhere_Update $ ./Update.sh
Enter the path to the update file e.g /pi/Pianywhere.binary or if it is in the same folder use Pianywhere.binary with the path
/home/pi/PiAnywhere_Update/PiAnywhere-10-05-17.binary
Can't init. Ensure that BOOT0 is enabled and reset device
Traceback (most recent call last):
File "stm32loader.py", line 436, in <module>
bootversion = cmd.cmdGet()
File "stm32loader.py", line 118, in cmdGet
if self.cmdGeneric(0x00):
File "stm32loader.py", line 115, in cmdGeneric
return self._wait_for_ask(hex(cmd))
File "stm32loader.py", line 91, in _wait_for_ask
raise CmdException("Unknown response. "+info+": "+hex(ask))
__main__.CmdException: Unknown response. 0x0: 0x1
I got erros from the usb port everytime, pianywhere was delivering a broken usb cable :(
But with a right one everythings is working (i hope) :)
ZachB70ThomasB425
Reply 1 year ago
My cable just had the same issue. It worked fine for a couple months and then failed. The symptoms were overheating and high current draw on the Pi as well as kernel faults and hard locks of the pi. If anyone experiences these symptoms do check the usb cable!
ZachB70
1 year ago
Has anyone else noticed that the download site is down? I have also not received any responses from their support email address.
ThomasB425
1 year ago
They send the wrong RF Adapter Cable SMA Female Connector to ipex for the GPS Adapter. Thats very annoying, because you did not get any answer if you contact the support. I've bought some cable by my one, but that must not be a option when ordering something.
John Doe Junior
1 year ago
Raspberry Pi 3 does not detect 4G HAT when connected to USB. Several different OSs are tested, but with the same result. All USB ports in RP3 are tested OK with other hardware.
The same documentation is available on all pages, as in this guide. Neither RP3 nor 4G HAT has the "pwr" or "btn" buttons.
There are very very long response times from the support. I feel left to myself.
ZachB70
1 year ago
Does anyone know whether its possible to query the power state of the device? I would like to be able to determine whether the device is on battery power or ac.
slayracker
1 year ago
* Gps module everytime needs to be activated.
for myself, i fixed the issue by adding the following line to crontab.
echo "AT+CGPS=1" > /dev/ttyUSB3
* Another poor thing, PiAnywhere always must be activated by manually pushing 'btn' button and then 'pwr' button. Its not useful for remote installation instances.
I hope there is a way to make it manually on power up. ?
* I bought pre-installed SD card. On advertisement, it was written that ''SAMPLES'' but there were no sample on it. No script. I couldn't find anything?
* GPS initiliazing very fast. As given instructions on the page for different model i see. For 4G/LTE, /dev/ttyUSB1 is GPS Echo for NMEA stream. You can see the stream basicly with " $ cat /dev/ttyUSB1 " command (without quotes) easily. ttyUSB2 is Modem, ttyUSB3 is GPS terminal for AT+ command/query.
Tested with gpsd and initialstate, works well.
* Preloaded SD card comes with hostapd and isc-dhcpd-server.
You can easily use it as WiFi - 3G/4G dongle by adding a conf file for hostapd and modify dhcpd.conf. Default on dhcpd.conf gateway written like 192.168.42.255, don't forget to change this otherwise you wont able to route default traffic trough raspi.
I am planning to write useful tutorials for the product.
But need more information about few things ;
- Auto boot/start option as i mentioned above ?
- Modem AT+ set, or at least more specific details about chipset to find out full list of commands. To enable disable 4G/3G function.
- More information about all virtual interfaces /dev/ttyUSB0,1 etc.
Also have few advice ;
- A housing for sale might be good.
- Given USB cable is simple ugly cable. A slim and nice one (as pictured above) would be more useful and looks nice.
MaximeA7slayracker
Reply 1 year ago
I would also love to find a way to automatically boot up the Pi and start the modem. Having to press on the buttons is a pain in the ass and prevent me from initializing it remotely. If you find a way to do that, that would be greatly appreciated.
ZachB70MaximeA7
Reply 1 year ago
I second this. Is there a alternate firmware or some AT command way to bypass the button?
EE_RobMaximeA7
Reply 1 year ago
So auto power up is actually pretty simple if you don't mind adding a little micro controller in your box. what you do is solder some wires to the resistors next the buttons, use a DMM to figure out which side is directly connected to the switch. Then you just write a quick sketch for the Arduino if that is what you want to use which does this every time it boots up:
pseudo code:
Void setup
digital pins for almost all arduinos default to low
Digital write the modem switch pin high for 250ms
Digital write the modem switch pin low
wait 10 seconds for the modem to boot up
Digital write the pi pwr button high for 250ms
Digital write the pi power switch pin low
Note that the modem needs at least 10 seconds to fully boot up and connect to the network, if you don't allow 10 seconds before turning on the Pi the auto connect code you added in the steps above will not work.
If you purchase a 3.3V micro controller than you can literally solder the wires from the micro digital pins to the button resistors on the piAnywhere. If you use a 5V micro then you will need to use a logic level converter like the one offered on spark fun P# BOB-12009.
Please note that soldering onto the piAnywhere could cause damage if you don't know what you are doing, so do the above at your own risk.
As you probably guessed from the sketch above the modem and the pi pwr buttons go high when you press them, and are low otherwise. Soldering onto the side of the resistor that is directly connected to the button is very important, otherwise if you solder onto the ground side of the resistors you will short the microcontroller digital pin to ground.
One final note, you must tie the ground on the PiAnywhere to the Arduino ground so that they are at the same reference level. This is done by simply running a wire from the piAnywhere header (they have the same pinout as the Pi it plugs into) to the Arduino GND pin. So basically you just need a GND wire, a wire for the modem power, and a wire for the Pi Power that go between the PiAnywhere and the Arduino.
I've been using this method to turn on the modem and Pi remotely for a few weeks now without any issues.
PhilippE9slayracker
Reply 1 year ago
Did AltitudeTech get back to you? I've successfully set up the modem, it works perfectly with a Taoglass antenna after I've disabled the SIM PIN and switched off wifi network access. It was even a breeze to set up a wifi hotspot using the LTE connection. However, as I'd like to install the RPi with this hat in remote location automatic power up is crucial. AltitudeTech unfortunately didn't get back to my support request yet.
